Question about Kyocera Mita (km-c850d) All-In-One Printer
Paper Jam/Kyocera C850/C850D
Paper jam on left side of printer. Have followed instructions in manual but no change..
  • 417 Answers
There will be a piece of paper stuck in there follow the instructions again opening every door on the left side. If there is not some paper the likely thing is that the paper sensor is jammed open or the light reflector sensor is dirty or the last thing is one of the sensors are faulty.
But I know these machines very well and the sensors rarely go faulty so I'm 98% sure there will be just a small piece of paper stuck in there. (It may be between the two doors or stuck behind a guide.
Posted on Jan 02, 2008
My kyocera KM 1815 keeps saying "paper jam 00 open left cover and remove paper jam but there is no jam
Hi
Check all the paper movement from the tray, left or right cover, front cover, if so then remove jammed paper. Otherwise the paper sensor spring guide missing or fell off from its original position. Check carefully where the sensor locate. paper sensors detect all the paper movement in the machine during copying or printing, so locate the place in the machine which the paper usually jammed, see the screen of the machine, it will locate the place where the paper jammed mostly. Sensor not return to it original position that is why ( remove paper jam keeps blinking)
Aug 11, 2014 | Kyocera Mita Office Equipment & Supplies
Kyocera paper jam duplexer
The duplexer unit is located at the bottom of the printer. You have to remove the paper cassette first. Second, tilt the printer a little on the back side. In place of paper cassette, you will see an iron plate with a green handle in the left. Push down on the handle and the plate will go down. You may find paper jam there or pice of paper stucked. Release the handle and put back the printer and paper cassete, then open top cover and close it down. You may have paper jammed also under developer unit, or in the fuser section. Verify there, if the first solution won't solve the problem.
Apr 07, 2014 | Kyocera FS2020D ECOSYS Monochrome Laser ...
Paper jam error
could be a stuck, failed, or out of place sensor. recheck all sensors in paper path(s) carefully
Sep 19, 2013 | Kyocera Office Equipment & Supplies
I keep getting the message that there is a paper jam in my Kyocera Mita fs-1900 printer and I do not see anything
Download the user manual from the manufactures website, I provided the link below. Jam removal instructions start on page 4-12. If you follow the instruction and the printer still indicates a jam then you may have a bad switch or a switch that is stuck down.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=10156&rid=2569
I hope this is helpful,
Shawn
Feb 15, 2011 | Kyocera KM-F650 Plain Paper Laser Fax
Kyocera FS4020DN is showing paper jam in display with directions of how to resolve this issue. There is NO jam-and directions have been followed numerous times-printer has been restarted -numerous...
After removing paper tray, above the paper tray slot, on the bottom of unit, left side, is a green tab. Pull metal flap down, remove paper, and your in business. That is just my experience with my friends unit.
Oct 16, 2009 | Office Equipment & Supplies
Carriage jam
Soooooo ... call for service
Feb 21, 2018 | HP Photosmart D5360 InkJet Printer
Kyocera FS 1920 paper jam
Please install printer cartridge with drum unite properly.
Aug 24, 2009 | Kyocera Mita FS-1920 Laser Printer
Paper jam
Did you try the door in the back of the printer?
Pull the paper cassette out then pull on the green handle to pull out the feed unit.
Jan 02, 2009 | Kyocera FS-C5015N Laser Printer
Duplexer Jam
remove cassette and look on the left side underneath and lower green mark metal flap and check paper path
May 13, 2008 | Kyocera FS-3900DN Laser Printer
Kyocera Printer FS-1800 plus - paper jam Can't find the printer manual. Please provide steps to clear the paper jam and reset the printer.
Hi, first of all,pull out paper tray and check any paper,or scrap jammed.When paper tray is pulled out,open paper transport unit-You have green handle on the right side of machine,in the place of right side of paper tray.Pull out paper transport and remove paper.Just close paper transport unit and paper tray,open and close top cover.
Nov 29, 2007 | Office Equipment & Supplies
Kyocera Mita (km-c850d) All-In-One Printer Logo
185 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
