Question about Sewing Machines
U.S.A.#10 knitting needles is what size in Australia
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sewing Machines Master
  • 102,366 Answers
3 Suggested Answers
Mimito7
  • 128 Answers
SOURCE: what type of needle for knits fabric
Hi, depending on the weight of the knits, it can go from 9-14 but for knits, you need ball point needles .
Posted on May 05, 2009
SOURCE: My pfaff Tipmatic 1151 started skipping stitches on knit fabrics using any size needle, even pfaff needles. It sews fine on non-knit fabrics using size 14 or larger needles. I have checked all of the
are you using a ball point needle sewing knit or stretch?
Posted on Dec 19, 2012
What size is a knitting needle of 150 cm
point 9 cm, i. e. 9 cm
That is the conversion of size 13 knitting needle and has nothing to so with 150 cm
Needle size conversion chart
The size chart converts to mm. A unit chart converts that to the quoted CM.
Jun 02, 2017 | Sewing Machines
I am making half throw in the cable pattern also 2 cushions in aran wool how much wool would i need to buy
You deleted the last post as I was just about to post the answer!!
a set of aran knit cushion covers knitting pattern 99p ' to Knit ' Pinterest ...
https://www.pinterest.com/pin/353040058269560085/ Vintage Aran cushion cover set knitting pattern by knitcheap, £0.99 ... CUSHION FROM SQUARES - 250 grams of ARAN in Crafts, Knitting, Patterns ' eBay ... The possibilities for using sweaters for pillows are endless.... and would make great gifts! .... Many owl patterns on Ravelry, but don't have the seed stitch in the "body" ...
Double bed sized knitted throw - Knitting Paradise
www.knittingparadise.com/t-215627-1.html
  1. Cached
  2. Similar
I want to knit my nephew a double bed sized throw how many balls of double knitting wool 100grm balls of wool will I need please. ... im currently crocheting a large granny square bed over and currently am on ball 5 of 1000g aran wool just to ...
Knitting Calculator - LoveKnitting
www.loveknitting.com/knitting-calculators
  1. Cached
  2. Similar
The world's largest range of knitting yarn, patterns, needles, books and ... Circular · Single Point · Double Point · Interchangeable · Sets · For Children · Cable Needles · Crochet Hooks ... Convert between grams and ounces ... Roughly how much yarn will I need for a particular garment? ... Worsted, Aran, 10 ply, 4.5- 5.5 mm.
Estimating How Much Yarn to Buy - dummies
www.dummies.com/crafts/crocheting/estimating-how-much-yarn-to-buy/
  1. Cached
You need to know how much yarn to buy whenever you start a new knitting or crocheting project. You can figure out the yardage by using yarn calculations, ...
HOW MANY GRAMMS OF ARAN WOOL WOULD NEED TO KNIT TWO CUSHION COVERS Google...
Dec 27, 2016 | Sewing Machines
What size needles for bulky/12py wool?
It depends on your project. You need the size needle that will give you the stitch width and stitch length called for in the pattern. The pattern calls for a specific gauge, so you'll need to try out different needles, knitting a swatch on each needle size, and counting the number of stitches across and down to match the pattern specification. Does the pattern not give you a needle size? Needles come in either straight or circular in all various sizes as long as you stay within the same brand needle. (Needle brands differ from one to another, so try to stay within only one brand.) So a straight needle size 6 should be the same size as a circular needle size 6 (of the same brand).
However, although it may call for a specific size needle, you will still need to knit some test swatches because knitters usually knit looser or tighter, so one needs to adjust the needle size to accommodate those differences, ie someone who knits tightly may get 8 stitches to an inch, but a loose knitter may get only 6 stitches. But if the pattern says to cast on 48 stitches in for row 1, that means the 8 stitch gauge will yield a project that measures 6 inches wide (48/8=6). But a 6 stitch gauge will yield a project of 8 inches wide (48/6=8). The result would be one project will be 2 inches wider than the other.
But that is only half of the problem as you would still need to measure the number of rows per inch to get the length of the project. If there are more rows to the inch than specified, a garment with say an armhole that may be too small. If there are fewer rows to an inch, the result may be an armhole that is way to big.
Be very careful with your pattern and yarn selection. You will be much more successful if you stick to the number ply and yarn weight specified in the pattern, ie if the pattern calls for 2-ply 2 oz yarn, there may be some particularly difficult issues with substituting a 4-ply 4 oz. yarn. You may end up with a project that will not fit. For instance, you wouldn't want to use a heavier yarn to knit a baby garment. Baby garments usually call for baby yarn which is a specific ply and weight.
How to Measure Your Gauge in Knitting
earthguild com
3 Things You Might Not Know About Knitting Gauge Adjustment
Oct 30, 2016 | Sewing Machines
How do I cast off in knitting?
Take a needle several sizes larger than the ones you have used for the knitting - so the loops will be larger and the edge looser, knit the first two stitches onto the larger needle then use the tip of the other needle to lift the first stitch over the second one and right off the needle, so it is looped over the second stitch, but is no longer on the needle.
Knit another stitch and repeat the lifting over. I f you are casting off all the stitches continue to the end of the row and then cut the yarn, pass the end of the yarn through the last stitch and draw it up.
If you are only casting off part of the row then move the last stitch onto the right size needle and continue knitting on the stitches left in the row.
Dec 03, 2014 | Sewing Machines
I am sewing a knit fabric on my Lily 540 and it is skipping stitches like crazy. I have tried adjusting the tension and the stitch length with no success. seem to always have a hard time with getting even...
It sounds like you may be using the wrong needle. For knit fabric you need a ball point needle in order for it to sew correctly. A regular sharp type needle can cause the stitches to skip. Also make sure you have the right size for the type of fabric. Lighter weight fabric needs smaller size needle and thicker types need bigger sized needles.
Also make sure you have the right presser foot and the right pressure on the presser foot to get nice even stitches. A roller foot helps when sewing knit fabrics.
May 18, 2011 | Husqvarna Lily 540 and 550
What type of needle for knits fabric
May 04, 2009 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
