Question about Husqvarna Chain Saw Models 371, 372xp
How do i assemble the throttle trigger and spring on a 372xp husqvarna chainsaw
The trigger, safety, and a spring all go together in the handle and I can't get them in the right place
slohry
  • 87 Answers
SOURCE: husqvarna 365 order to install trigger, throttle catch and spring
Here's a link to the husky parts list.
http://www.usa.husqvarna.com/support_manual_search.aspx?webecsearch=10527&O=true
Posted on Apr 10, 2009
dontbother10
  • 2220 Answers
SOURCE: Husqvarna 136 chain brake handle spring.
You can get an IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
I don't think this has the detail you need.
If it were me I'd visit my friendly neighborhood Husky chainsaw seller (not Big Box Store) and ask to look at the clutch cover with the brake installed (take a camera). I'd probably ask for a quote for their repair too. HTH
Lou
Your model is no longer sold. The seller will know what model replaced it and may be willing to explain the repair procedure for your saw you. Take the cover and loose parts with you.
Posted on Sep 07, 2009
  • 4088 Answers
SOURCE: installing throttle cable on Husqvarna 445 chainsaw
Try blocking the throttle arm on the carburetor in the wide-open position with a small stick, then deal with the trigger mechanism. In order to remove the cable from the carburetor, you need to remove the carburetor itself, then unhook the cable end at the throttle arm. Keep track of which fuel hose goes where if you do this. Hope this helps!
Posted on Apr 01, 2010
  • 4088 Answers
SOURCE: MY hUSQVARNA 365 372xp CHAINSAW
Likely, the saw has been run with straight gas--no admixed oil. When this occurs, the piston, ring(s), and cylinder wall will have been deeply scored. Remove the muffler and turn the motor slowly while watching the surfaces of the piston, ring(s), and cylinder wall. If these surfaces are not smooth, then replacement of these parts is necessary. (very expensive with parts and labor) Hope this helps!
Posted on Oct 19, 2010
  • 2239 Answers
SOURCE: I broke the throttle trigger on a 445 Husqvarna
The two halfs of the rear handle do not seperate, once you have removed the r/h side grip you can remove the throttle lock, you then need to remove the pivot pin from the trigger with a pin punch, the trigger can then be pulled down and out, you may need to disconnect the throttle wire from the carb if you cannot drop the trigger far enough to remove the wire from it.
Posted on Jul 02, 2011
Fuel mix
The oil ratio is 50:1
Here is the website: http://homeguides.sfgate.com/oil-fuel-mixture-farm-tough-husqvarna-chainsaw-83933.html What Is the Oil Fuel Mixture for Farm Tough Husqvarna Chainsaw
Aug 19, 2014 | Husqvarna Chain Saw Handle Models 362 365...
Trigger wire that goes to the carb is not working. what can i do to fix it?
There should be a safety bad on ths handle that you hold down so that you can pull the throttle trigger. Check to make sure you are depressing it enough or that it is actually unlocking when depressed.
Sep 08, 2013 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
I can't figure out how to re-attach the throttle wire to the carburetor and handle on my husqvarna 235 chainsaw
To re assemble the carb, connect the throttle wire into the r/h side of the carb, there is a small hole in the throttle spindle, thread the wire into the spindle from the out side and twist so it stays in the spindle, you must do this with the carb off the saw, now push the carb with the wire connected back onto the two studs from the cylinder, refit the black air filter box, fit and tighten the two 8mm nuts, re fit the torx 20 screw into the top of the filter box, re fit the orange plastic plate on the r/h side of the crankcase, now re fit the the back handle and spine assembly, fit the three torx screws back through the anti vib springs and into the crankcase, if not already done remove the three screws securing the l/h side rear handle half, hook the other end of the throttle rod into the trigger, refit the handle half.
Mar 21, 2013 | Husqvarna 235E - 16" 34cc Consumer Gas...
I think you call it the throttle trigger i dropped and it broke i cant give it the gas
You need to rplace the trigger, if this is a 350, start by removing the throttle lock on the top of the back handle, gently open up the slot where the latch fits, at the same time pry the rear end of the latch up, it will pop up at the back, once up pull the latch toward the back of the saw and away, now knock out the roll pin that the trigger pivots on, once out pull the trigger slightly back and down, it will just pull away, replace with a new trigger and re fit the the roll pin, push the throttle lock latch back into the tank and push the back end down to lock it into the tank, make sure the spring locates into the latch. adw1_11.jpg
Sep 18, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Brand new Huskie 450e used for two days and the throttle is now broken. The actual trigger itself feels like it isn't attached to anything anymore. Is it an easy fix?
In the 400 series of Huskies I have fixed, the handle comes apart with several screws. Sounds like the simple problem might be in the handle/trigger assembly. The more complex problem is if the throttle linkage rod popped out of the throttle. The outside trigger interacts with a black plastic insert and spring that provides pressure outward to keep the throttle low. This assembly connects to a thin metal rod that looks like the path a drunk would take doing a sobriety test after too many martinis. The rod goes into the housing and connects into a hole in the throttle assembly, then is locked in place with a plastic piece that slides down to keep the rod from falling out. In order to see this area, the cover needs to come off. I'll be honest. The last one I had, the rod fell out of both ends. It took me two days of pondering, playing around, cursing, getting up and walking away, then coming back to finally figure out where the ends went. The blue plastic piece had slid down, covering the hole, so I was at a loss as to where it attached to the throttle. NOTE: When removing the handle, try real hard to keep it together until all screws are removed. THEN VERY CAREFULLY begin to take it apart, looking in from the top of the handle. You might get one good glimpse of how the parts fit together before they fall apart on you. Husky does have a good website for exploded view diagrams, but sometimes they leave a little to be desired for 2-Dimensional art vs. 3-D Reality. Good luck.
Sep 13, 2011 | Husqvarna 450 e-series 18" Chain Saw
My 031 stihl chainsaw trigger is stuck in a full open postion, is it a spring or what
Expose the carburetor and try pulling lightly on the throttle cable--if it won't pull, the trigger assembly is probably full of sawdust. In that case, remove the handle cover over the trigger (record the position of all parts before trying to take anything apart to clean). You should be able to see any blockage, clean it, and re-assemble it correctly. Check the trigger operation at the carburetor to make sure that it is traveling fully from idle to full speed. Hope this helps!
Nov 19, 2010 | Husqvarna Garden
The engine idles way too fast and will not correct with the sow speed adjustment
Make sure that you are adjusting the idle speed screw, not the idle jet screw (L). If you are adjusting the proper screw, then it is possible that the throttle trigger assembly in the handle has a load of sawdust/dirt that blocks proper return to idle. Take the handle apart carefully, and make notes on how the parts go back together. Check at the carburetor throttle assembly to make sure the throttle arm returns fully to the idle speed screw when the trigger is pulled and released slowly. Check the throttle spring as well to make sure it is undamaged. Hope this helps!
Sep 24, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Installing throttle cable on Husqvarna 445 chainsaw
Mar 31, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 365 order to install trigger, throttle catch and spring
Mar 23, 2009 | Husqvarna Garden
Poulan 3400 chainsaw throttle trigger
Its a missing or broken spring in the handle(trigger). If you look inside the handle you should see a circular spring around the post of the trigger. This spring returns trigger to idle position. If its missing or broken the trigger won't spring back.
Oct 12, 2008 | Poulan Garden
Husqvarna Chain Saw Models 371, 372xp Logo
271 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
