My sony projection tv model number KDFE42A10 It work's fine but after 10 minutes or so the picture will go out then the green will flash 49 times then the picture comes back on for awhile then does same thing again
  • 38 Answers
This is an easy problem. Your lamp is bad. Do not buy a cheap lamp. They are dim and won't last. I always recommend you buy the sony lamp. Also clean out all dust in back and side of tv..jeff the tv doctor
Posted on Dec 31, 2013
ctf1800
  • 4402 Answers
SOURCE: KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Posted on Jan 22, 2008
ctf1800
  • 4402 Answers
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Posted on Sep 14, 2008
  • 178 Answers
SOURCE: KDS-R60XBR2 power led blinks 4 times,
There are three fans the one that usually fails is located on top of the optical block and cannot be reached by the owner unless you take the set apart yourself. What is happening is that one of the fans are not spinning fast enough or has stopped altogether. The best solution is to replace all three fans cleaning may not be enough to get a slow fan up to speed, and the tech should blow out the dust in the duct work. This is what the tech coming out will (or should) be doing. Also some fans will have an intermittent startup, and cause this intermittently, so it is a good idea just to replace the fans instead of just cleaning them.
Posted on Sep 02, 2009
welcomejee
  • 10594 Answers
SOURCE: Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Posted on Oct 21, 2009
I have a sony projection tv the model number is KDFE42A10 Work's fine but the picture goes out and green light blink's About 49 times then picture comes back on after a few minutes it do the same thing...
It may be overheating check to see if the fan is running and the vents are not plugged with dust and or lint carefully clean out anything obstructing the vents and make sure fan is operating. Hope this helps.
Jan 01, 2014 | Televison & Video
I NEED LAMP MODEL KDFE42A10
GOOGLE the model number with lamp after it and you will find dozens of places happy to sell you one or more.
Mar 18, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
5 red flashs on power/standby light on kdsr60xbr1 screen blank,
Thats the error for lamp driver error. Which means the Ballast is most likely defective. You can get the replacement ballast for your model at the following link which comes with installation instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/kdfe42a10-ballast-assembly/cName/sony-parts
May 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Hi there, i have a sony rear projection..green and red lights flashing with no picture, cant turn tv on, any idea, it was working fine yestedray
Unplug TV from AC outlet for 10-15 minutes and replug it back and power up.
Let me know how old is this TV and have you replaced its Lamp>?
Jan 09, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony tv KDF55WF655
same problem... tv turns on and off repeadly while the green light flashes. seems as if the tv keeps restarting. please help.
Dec 13, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
