Question about Bose Cinemate 1 Sr Speaker System
Bose 1sr blinking red light - Bose Cinemate 1 Sr Speaker System
Bose sounlink mini battery blinking red light
If your Bose SoundLink Speaker's battery indicator is flashing red, this usually means the battery has less than 20% charge - and is need of charging. http://worldwide.bose.com/productsupport/en_us/web/article_235_indicator_lights/page.html
Nov 05, 2015 | Bose Audio Players & Recorders
Hi, just purchased new Bose Solo sound system. But when plug power on, there is no "tones" to indicate power is on, just slow and constant twitch sound.
REad the instructions carefully. Take the uni back to where you bought it and have the salespeople explain how it's used. Call tech support for Bose on their toll free number.
May 29, 2015 | Bose Solo TV sound system - Black
Red light on not green
helllllo.........red lite......[a] red lites means during the update if it lite red remove the thumb drive from the system ,unplug it from the wall outlet one minute +..then plug back in.make sure the system is power on[ showing green led] insert thumb drive....if problem persist call bose @ 1-877-335-2073us/1-877-701-2175canada.......bose-on see me on amazon for bose remotes bookbundler
Sep 01, 2014 | Bose Solo TV sound system - Black
I'm not getting any sound from a bose cinemate 1sr
You've either plugged into the wrong sockets, or selected the wrong input on the Bose, or the optical cable isn't inserted correctly or the cable is damaged.
Aug 27, 2014 | Audio Players & Recorders
TiVo will not control volume on Bose 1sr
1= clean the contacts batteries, do it with contacts cleaner
2= resolder the wires contact batteries
3= open the rem.control clean the keypads switch for dirty, corrosion, oxide, bad contacts, or open contacts test, remember they send infrared signal to the SYSCON to the receiver.
4= otherwise you must go to the repair shop TV for fix ti
5= try again, reset the code.
God bless you, SEE the diagram block
Jul 17, 2012 | Televison & Video
Bose QC 2 Noise Cancelling Headphones the red light is on. Should there be a green light if they are working?
No green light for QC2, just red. If it's constant the battery is charged, powering the noise cancellation, and, if connected to an audio device, conducting sound. If the red light is blinking, the battery is losing its charge.
Nov 18, 2010 | Bose ® QuietComfort® 2 Acoustic...
Bose Cinemate 1 Sr Speaker System Logo
114 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
