Question about Sony Black 2000 Watt DJ Shake Sound System - LBT-SH2000
Need manual for Sony Black 2000 Watt DJ Sound System-LBT-SH2000
Manual for sony lbt-sh2000
Toufic Malek
  • 9 Answers
SOURCE: sony lbt w300
To isolate the source of the problem disconnect all speakers and turn on the unit, if it works that means that you have to check cables and speakers. If the problem remains that means the problem is with the unit. Professional technician is required: The problem is at the power output section (Defective out put IC or Voltage error?) Good Luck Toufic Malek
Posted on Sep 25, 2007
SOURCE: sony self lbt-lx5o push power portect comes on how to resolve the problem
Likely a problem with the amp. Buy a new one and don't run it on full power for too long. Mine got shagged when I had a party and maxed it out for 2 hours.
Read it could be excessive solder on the amp circuit heating up too much then obviously not working after it cools since the connection is messed up when the solder changes shape.
Posted on Aug 26, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony compact disc receiver LBT-D990
KSS-213D lens has soldered joint to protect laser diode from static voltages damage when it shipped. You need to unsold laser diode protection joint and then try.
Posted on Oct 01, 2008
  • 150 Answers
SOURCE: i have a sony 3 disc changer mini hifi stereo
I do not have any experience on your type of hifi but i reckon dest error refers to "Destination error" the 3 disc changer has a default home position of the disc carousel that it goes to when first starting up. I would suggest that somthing is preventing the cd mechanism from getting there to it's home when it starts up. This could be from a cd or foreign object jam, broken motor( or worn motor) broken or dirty sensor that detects where the mechanism is or broken cable connecting the two.
The key to finding this out after you fix the jam, would be to note if the mechansism is travelling, whether it sounds forced or if it's not moving at all. this will tell you whether it's motor or sensor related.
As I said I don't have any experience on this one, perhaps someone more qualified could comment...
Good Luck!
Posted on Jan 17, 2010
SOURCE: Hi there I have a Sony LBT XG100AV Stereo System,
I have the same unit, although it's a bit old now. I used to get that problem, and the protection system is to protect the unit from over-heating, and the main cause is its because the unit is getting hot and/or there isn't enough air going through the rear of the unit. I found a fan or better air flow helps.
Posted on Apr 04, 2011
I have a sony lbt d550 cassette player that needs new belts. I need a picture of how to install the belts or how they are configured.
Below is a link for the service manual! The cassette dismantle is on page 9. from what I see there is a plate that covers access to the belts, that is if Your lucky! the plate is shown in the first picture on page 9, sorry I have worked on other brands, and some of them You have to do a lot of dismantling to even get to belts! Hope this helps You! Regards!
Sony HCD A295 HCD D550 LBT A295 LBT D550 Service Manual
Jul 14, 2017 | Sony Audio Players & Recorders
Sony LBt-d307 user manual
I could find the HST-D307. Just with Google and it was the first hit.
Should be the same manual as for the LBT, but I can't see that.
http://diagramas.diagramasde.com/audio/HST-D307%20Service.pdf
Jun 26, 2014 | Sony Ps-lx49 / Ps-lx49p Stereo Turntable...
My sony hi-fi lbt-sh2000 component sound volume does not increase after long hours playing
example you play music high base and thin you give a high volume.have a automatic sensor inside the player to low the high base.
Feb 06, 2013 | Sony Main Body Of Lbt-Sh2000
How do u turn off the cd player to get a better reception for the radio?
That's not even recommended. Why do you think that would help?
http://www.retrevo.com/support/Sony-LBT-XGR6-manual/id/268ci276/t/2/
Re-orienting the antenna would give better results.
See Page 12:
Jan 24, 2011 | Sony LBT-XGR6 CD Shelf System
Sony lbt d560 has no sound
look at your amp connection so you may need to re-smoldered it or your amp is shot.
Sep 05, 2009 | Sony LBT-D570 Shelf System
Sony LBT-XB55AV 3 in 1 sound system pre amp left
Its usually all in one module, its the heart of the system and its usually docked to an aluminium dissipator... Unsolder it with a wick and bring it to your nearest electronics parts reseller, or look for it on the web...
Aug 04, 2009 | Audio Players & Recorders
Finding an Instruction Manual for Sony stereo system
How do I remove the protect mode from my Sony LBT-LX5 Stereo?
Dec 04, 2007 | Audio Players & Recorders
Sony Black 2000 Watt DJ Shake Sound System - LBT-SH2000 Logo
347 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
