Question about Building Materials
Gate opens by its self
Gate opens automatically without remote being pressed
helder_benfi
  • 52 Answers
SOURCE: mobile press navigation key from it self and open message without i press anykey
virus or bad contact.( short circuit.) try to remove the cap of n95. and try to remove the navigation key, to see what apends after.
if you don´t want that, contact nokia assistence.
hope i have helped
Posted on May 20, 2009
  • 68 Answers
SOURCE: How to use 2 button remote for two mighty mule gate openers
Chamberlain products do not support a 318Mhz frequency that gto uses, so that remote will not work unless you get a liftmaster receiver or any other one that it uses.
Posted on Aug 10, 2010
rommelalilin
  • 2178 Answers
SOURCE: I am using a gto pro 2000 series automatic gate
The belt that drives the tray in and out is either broken or slipping. The belt is attached to a motor and as the motor spins the belt will rotate a pulley which drives the tray mechanism.
Posted on Nov 25, 2010
rickyrt441
  • 4399 Answers
SOURCE: My 2009 Toyota Highlander lift
Thanks for choosing FixYa and welcome to the site. You need to make sure that your fuse is not blown. Check your fuse box diagram for the location. If the fuse is fine, you may have a bad switch. There could be a loose wire or a bad connection to the switch.
Posted on Apr 20, 2011
  • 1156 Answers
SOURCE: My Elite SL3000 sliding gate is not responding to
Hi, Thanks for posting your Question.
When it comes to automatic usage of equipment or gadget that work with remotes sensors..It always malfunctions when water enters into it's electrical area..
Issues like this are have to be checked by an experienced Elite SL3000 sliding gate repairer..Water has enter either the coil area or the magnet that control the opening and closing function of the Gate..
It's not from the remote. That is if the battery of the remote still functions properly..
It needs to be serviced to clean the water inside and after cleaning it up, it will be ok..
Please make sure someone who has the experience should handle it. Thanks
Good luck ..
Posted on Aug 17, 2011
New FM502 Dual gate opener pressed remote which starts the second gate opening then the master moves a few inches stops. Hear 3 beeps 2 seconds 3-. .Conections are good to circuit board! What up!
reprogram the opening sequence in the control box
it should that the first gate opens then the second gate opens a few seconds behind it
closing is the reverse
you can program that only one gate opens
you can also program that one gate is a entrance gate where it opens until you stop it , then when you have passed through , press it again and it closes
read the operating instructions and follow the programming procedures closely
Oct 24, 2016 | Miscellaneous
Catch wont release
Check the relay that operates the lock on the controller circuit board. It probably is bad.
Oct 08, 2016 | elite , liftmaster Home Fencing
I have a 2012 Jeep Grand Cherokee that leftgete is not opening what can be the problem .."? The motor is working but is not lefting up.
Attempt to open manually. With the gate open use the remote to close. If the support pistons lose their gas pressure the gate will close automatically but not have the force to open Replace the gas piston on the passenger side.
If something is blocking the sensor will also prohibit the lift gate from opening.
Hope this helps?.
Aug 13, 2016 | 2012 Jeep Grand Cherokee Laredo 4dr SUV...
What is wring.?
The programming on your remote buttons probably got overridden. Just reprogram your remote's buttons for the alarm and gate .
Mar 29, 2015 | Building Materials
How do I dry out an electric gate opener that got wet?
what is the make and model of your gate motor or central unit it might have to be reprogrammed after you dry it with a hair dryer without the battery in it
Nov 12, 2014 | Home Fencing
Rear tail gate opens then closes again by it self
obviously a problem with the auto mechanism , is there a sensor located , see your owners manual, in a particular area that has to bee kept clear and you may have inadvertantly placed something over the sensor , just guess as something must be telling the tailgate to shut , with the age of vehicle is it still covered under makers warrenty ? i'll look into the sensor thing
May 25, 2014 | 2011 Ford Edge
Gate opens by itself at any time and doesnt close,,, any help ?(new d5)
I need more information on your automatic gate opener. What brand opener is it? What brand of remotes are included? do you have a keypad outside the gate? Roughly, how old is the machine? Have you had any electrical storms recently prior to this issue starting?
Sep 12, 2013 | Building Materials
I have a 2014 Audi 5. I have had no problem programming my garage opener but cannot seem to program my security gate key. I follow instruction with negative resutls. I even go to the gate and park in...
I had the same problem with my 2014 RS5. The solution was to keep pressing and releasing the gate remote until it was picked up by the Audi, instead of just pressing and holding the gate remote button. My gate has a Mighty Mule gate opener but the remotes are the same for most makes of gates.
Aug 20, 2013 | Audi A5 Cars & Trucks
My newly purchased home has a Beninca MS4 automatic gate opener but came with only one remote control (Liftmaster 371LM remote). I purchased two additional 371LM remotes online but do not know how to...
hi,
You have to oppen the motor control pannel. There will be circuit board inside it. In the circuit board you can see a Push button switch. It is the learn switch.
After powering ON press and release immediatly this learn switch. With in 30 seconds press and hold the button you wish to use until two click heard from the control board.
If you can sent me your email id through FixYa then i will sent the picture which shows the learn switch.
OK.
Aug 29, 2011 | Elite Sl 3000 Ul Sliding Gate Operator
Building Materials Logo
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
