Question about Dometic WA3210 Compact Refrigerator
Dometic RM4223 does not want to stay cold
I hav a !998 flagstaff,pop-up camper with a dometic frig.Model # RM4223, refrigerant R717,serial #7330489.product#9211302-04,it's operating on 120vac ,but during the day it is pulling temp. of 50-57degr. installed in folding camper .Did get to 38 degrees over night, on a cool night plugged into 120vac in the garage.however it did not maintain temp the next day,as the day heated up .IT is not work on 12vdc n is not hooked up to 12vdc,and also could not get propane to lite. I dont think any propane was getting through. I.removed a tube,between gas inlet tube and a sort of gas control valve in back of unit,and found a small,white, filter like material inside this tube .Is That stuff suppose to be there and why?It seems to get cold during the evening, but starts to warms up as the day gets hotter.Does it cool according to the temperature outside?Do both the 120vac switch and 12vdc switch hav to be on when operating on 120vac? Does it alwys hav to be hooked up to 12vdc, if so why?Where can i get a manual and a diagram for this unit? I'd appreciate any help thank you john
  • 51 Answers
SOURCE: Dometic fridge
I would look for a ventilation problem. If the fridge is working at that level nothing wrong with electric. The unit needs air to move up and out the top to make the freezer work. It sounds like the air is only moving the wrong way out the lower vent. Careful it could just be a birds nest but it may be a large wasp nest blocking the roof opening.
Posted on Sep 07, 2008
  • 68 Answers
SOURCE: Dometic rm4223 wont run at all
Make sure you have 12 volt DC power to circuit board. If you do you need a circuit board.
Posted on Mar 19, 2009
  • 9 Answers
SOURCE: dometic rm4223 has leaked coolant. The
You need a new cooling unit. That ammonia smell means that your heating unit is shot, needs to be replaced, and there are a coupla ways to go here.
1) Order up a rebuilt (or new) online, and replace it yourself. (Handyman skill level:fair.) $500.
2) Go to an RV repair shop and have that done $700.00 - $100.00
3) Buy a new fridge. $1000.00 ++
Posted on Jul 26, 2009
  • 47 Answers
SOURCE: warm temps cause cupboard shelf above refrigerator to heat up
well thats normal mate you cannot prevent this ... perhaps try draging your fridge away from the wall so it sits about 100mm off the wall
Posted on Nov 11, 2009
kevin_getz
  • 1031 Answers
SOURCE: dometic rm2852 fridge nor freezer works. light
How old is the unit?
Posted on Jan 29, 2010
My refrigerator in my rv is a Dometic model rm461, and the freezer works but the frig doesn't get that cold, any answers?
check thermistors. door seals, air flow control knob, is the fan running without restrictions?
Mar 17, 2015 | Dometic Refrigerators
Owners manual for 1997 flagstaf popup camper
You will have to contact Flagstaff, but you also need the actual model number of your camper. You can also google a manual for a 97 Flagstaff model # _______
Sep 13, 2014 | RVs
Dometic rm4223 model does not run on 12v when traveling
You could contact me and I'll buy your old broken fridge, or you could buy my brand new rm4223 that is missing parts (but the cooling unit and cabinet are brand new, never used.
Sep 08, 2013 | Dometic WA3210 Compact Refrigerator
Replaced control board have 115 to board can't get 12v nothing lights on frig or in side where does 12v come from voltage is good in camper Couchman with Dometic md RM2652
The 12V comes from 2 wires that come from RV and affixed to a terminal block on fridge. Insure you have 12V at those wires. Also check the fuses located inside the main electronic board. ArctiCold Refrigeration We keep it cold 28659511-ac6f-4f0b-b8c3-c7ac7cf165ac.jpg 8e5a2b6c-5f1f-429e-8512-595071232c90.jpg
Aug 29, 2013 | Dometic Refrigerators
Our 1995 30FL Leisure Star camper Dometic fridge is not working. the camper is level. the Check light goes on after a few moments of turning it on.
Give Arcticold Refrigeration a call toll free tech support 1-888-782-6665 We will require the model number so please have that available. We will require more info to help with this problem such as results on electric, ect. ArctiCold Refrigeration We keep it cold da1720cc-2c8a-48ab-b560-ebb5655e2d6c.jpg
Aug 24, 2013 | Dometic RGE400 Top Freezer Refrigerator
The frig is freezing everything down to the bottom drawers. Water, soda hamburger patties in the frig were frozen. It seems to be okay the first day and then it turns into a freezer. Any idea what I should...
Dometic refrigerators don't have the best thermostats, especially the one with multiple source (AC/DC/Propane) . They are also prone to be more sensitive when the propane was just topped up and the pressure is high.
Don't get me wrong, I think the Dometic is a great refrigerator for campers, you just have to learn to deal with its issues.
Also make sure that you have one fuel source selected at a time, and not all of them!
Jun 30, 2011 | Dometic Refrigerators
Have dometic three way fridge in pop up truck camper that is cooling but not cold enough stays at about 50 degrees answers???
Find thermistor/thermostat that is usually attached by plastic holder at back on one of the fins in fridge compartment. Pull it off, and move it over to left 2 fins, then give 24-48 hrs and see if any change.
Jun 16, 2010 | Dometic RM2652 Refrigerator
Dometic rm4223 has leaked coolant. The refrigerator was running but not cooling as we smelled ammonia
Jul 11, 2009 | Dometic WA3210 Compact Refrigerator
Camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
May 15, 2009 | Dometic WA3210 Compact Refrigerator
Need manual for 1993 flagstaff cobra fold down camper
what type of wiring harness is require for a 1993 Flagstaff pop up trailer
Mar 24, 2009 | Sport & Outdoor - Others
Dometic WA3210 Compact Refrigerator Logo
517 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
