Question about Marantz RC5400 LCD Touchscreen Remote Control
Touch screen not working on maranz rc 5400 - Marantz RC5400 LCD Touchscreen Remote Control
HOw do I turn off touch screen on a Sony VAIO Tap 20 Touchscreen All-in-One Desktop Computer, Intel Dual-Core i5-2430M 2.4GHz, 8GB RAM, 750GB 5400 RPM HDD, Windows 7 Home Premium 64-bit
1.Press the Windows logo key + X.
2.Select Device Manager from the list.
3.Click the little arrow next to Human Interface Devices to expand the list.
4.Click the touch screen driver (in my case, NextWindow Voltron Touch Screen).
5.Right-click, and select Disable from the list.
6.Click Yes on the dialog box that asks if you are sure you want to disable the touch screen driver.
7.Restart your computer
When you want your touch screen to work again, follow the process above, EXCEPT when right-clicking the touch screen driver, select Enable
See the website
Turn off VAIO all in one touchscreen function disable annoying system...
Mar 07, 2015 | Sony VAIO VPCL23CFX/B All-In-One PC - 2nd...
How do i turn off a my sony all in one touch screen, i do not touch the screen for options, and its driving me crazy
  1. Press the Windows logo key + X.
  2. Select Device Manager from the list.
  3. Click the little arrow next to Human Interface Devices to expand the list.
  4. Click the touch screen driver (in my case, NextWindow Voltron Touch Screen).
  5. Right-click, and select Disable from the list.
  6. Click Yes on the dialog box that asks if you are sure you want to disable the touch screen driver.
  7. Restart your computer
When you want your touch screen to work again, follow the process above, EXCEPT when right-clicking the touch screen driver, select Enable See the website
S
SeS Turn off VAIO all in one touchscreen function disable annoying system...
Mar 07, 2015 | Sony VAIO Tap 20" Touchscreen All-in-One...
How do I know if my backlight on my LG tv is working
Wait until it is very dark. All lights out. Switch on. The screen should perceptibly change from black to dark grey. Perhaps you will see some light leakage near the edges where glass meets plinth.
And there is the T test where you touch the screen with the back of your hand after it's been on for a while. Although LED backlights are cold, they do generate some heat. So a perceptible change in temperature usually indicates that the backlight is functional.
Oct 06, 2014 | LG 47" 5400 Series LED HDTV - 47LN5400
Which atenna is required for FM on a Maranz 5600 receiver?
The best solution is a dipole outside that can be positioned to receive the signal that is most interesting, this dipole can also be installed near the TV and you can use the same cable for the descent of the signal, logically serves a coupler and a decoupler for the two different signals that must travel together from the roof to the power house.
Aug 30, 2014 | Marantz Audio Players & Recorders
The screen and standby light dont work but touch sensitive buttons still beep
Look for any loose contacts in power outlet, RC Jack, cable and connectors. In order to ensure, it is not caused by the input device, connect a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 22, 2012 | Televison & Video
The slide holder will not return after scanning. The little wheel that is supposed to move the slide holder just clicks but doesn't move the slide holder. I have to remove it by hand. By the way, this...
I have the 5400 II and have had similar problem. I found out, that it is essential, that the film/slide holder is clean and have a smooth surface. Specially on the edge where it touches the plain bearings. I have lubricated the whole holder with acid-free silicone, wich over time made the scanner work perfectly.
Brgds Per
Jan 01, 2011 | Konica Minolta Dimage Scan Elite 5400 II...
How can i get my bose rc-38t1-27 to work. i have
the electric cord id also an antenna. do not let the elctric cords touch other electric cords or it wil have interference.
Apr 14, 2010 | Bose RC-18S Remote Control
Error ""protecting" on maranz sr5400
The amplifier is being overdriven or components of the output stage are breaking down due to earlier overdriving.
May 17, 2017 | Marantz SR-5400 Receiver
My RC-8000 has no display...
Our screen does not beep but you can't see the display.
Aug 28, 2008 | Denon RC-8000 LCD Touchscreen Remote...
Error 5400
the 5400 error is telling you there was excessive temperature in the printhead, and this error code will stop all printing attempts.
Unplug the power from the printer and leave it off for a hour and then check the pins inside the carriage and clean them and clean the contacts on the back of the head.
May 31, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Marantz RC5400 LCD Touchscreen Remote Control Logo
Top Marantz Televison & Video Experts
Electro Med Services...
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
