Okay so my wifi box changed its name from NETGEAR43 to NETGEAR43-5G and now my play station will not pick it up I pressed scan and it won't find the new name and when I type it in it says it can't find it or I typed it wrong I've done this several times but it will not work it says "DNS error" what do I do?
SOURCE: yahoo mail login error
Im having the exact same problem. What do I do please to resolve it?
Posted on Nov 11, 2008
SOURCE: Won't play DVD's anymore : Wrong disk type error
when trying to play a DVD I get wrong disc error on the screen its a TRUTECH TV DVD Combo
Posted on Nov 19, 2008
33mlake33
  • 142 Answers
SOURCE: my ps3 HAS A dns problem
Whenever you are dealin with a DNS error, it is a problem on your internet service provider's end. Contact them for a solution. Thanks
Posted on Dec 31, 2008
localwonder
  • 6784 Answers
SOURCE: WRONG DISC ERROR WHEN PLAYING A DVD
HI,. this is a lens assembly fault. the lens is malfunctioning or, it may have stopped reading. this wrong disc code is just a universal warning that is concerning a fault if the main board doesn't receive any data(audio,video) when the disc is inserted.
Due to the integrated status of your unit, this will be a costly repair because, the entire assembly is combined together with the vcr section as well.
You will need to replace the entire assembly to fix this issue. the lens has burned out.
you can confirm my diagnosis by preforming a cleaning of the lens with a cleaning disc. if the unit continues to not read or play a CD after the cleaning, this will confirm my diagnosis.
Please rate and have a great day:)
Posted on May 23, 2009
SOURCE: "Failed to lookup DNS" error with Aluratek wifi internet radio
Here's the useless response from Aluratek customer support:
"Failed to lookup DNS, the password is case sensitive, if you are using upper lower case letters you have to key in the correct case otherwise you won't be able to connect your radio. Thanks."
However, Aluratek advised another AIRMM01 owner to obtain a newer modem. I bought a new Actiontec GT724WGR Wireless DSL Modem and that resolved the problem with my AIRMM01F.
Posted on Nov 02, 2009
Can't change channels stuck on 4 tried scanning it but it goes back to 4 won't change on the tv or a remote
When you run a scan the TV changes to every channel and tries to tune in a station. that is why it takes so long. If your TV is only finding channel 4, I would guess that is the only station strong enough for it to pick-up. You should check and / or replace your antenna and or antenna cable. Then re-scan the channels. with a better antenna, it should find more stations.
Most older Tube type TVs need a converter to pick-up digital TV, if you have a converter, make sure it is plugged in.
You should not be getting any stations without a digital tuner TV or a converter box.
The FCC site says this:
The FCC established September 1, 2015 as the date for the termination of all analog low-power television service. Since that date, analog television should no longer exist in the United States. Until that time, LPTV stations were allowed to continue to operate their analog facilities.
Jan 28, 2016 | Televison & Video
How do you manually change radio stations without scanning
press either up or down button on radio it will then start to scan hold it it will then let you pick station page 134 of owers manual tells how also
Jul 26, 2013 | 2000 Mercedes-Benz CLK
My xbox live wireless conection will not work, and the light on the wireless conector will not come on
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
X-BOX
On the x-box you will need to connect to the wireless network now.
Open the main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox and open System Settings.
2. Select Network Settings, Configure Network.
3. On the Basic Settings tab, select your wireless settings.
4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
5. If your network has wireless security, enter your WEP or WPA key.
6. Try to connect to Xbox LIVE again.
Trouble connecting to the internet on X-box ,Play station or WII ?
You can try to reduce the MTU settings on the router. if the MTU on the router is set to 1500 then change the MTU to 1365. Also you will need to open the ports on the router.
For X-box port numbers are - 53, 80-88, 3074 .
Jan 23, 2011 | Microsoft Xbox 360 Console
Ps 3 can't obtain IP address
You will need to reset your modem. Are you using wifi or ethernet?
Simple unplug your modem for a few minutes and then try again.
If this doesn't work, you will need to contact your Internet Service Provider.
Jan 20, 2011 | Sony Playstation 3 (PS3) Console
I wont to change my router from nat type 3 to nap type to so i can play with my playstation 3 online can you please fine a solution
Play Station
Now go to the settings page of the PLAY STATION
NETWORK SETTINGS ==>
INTERNET CONNECTION SETTINGS ==>
WIRELESS SETTINGS ==>
If you get confirmation screen displayed stating that you will be disconnected from the Internet. click YES ==>
select EASY ==>
select WIRELESS ==>
SCAN ==>
you will see your SSID ( wireless network name)==>
select the security settings ( router wireless settings)==>
enter the KEY ==>
select the IP address settings EASY ==>
save your settings ==>
Test the connection .
Jan 10, 2011 | Zyxel (91-004-361002) Wireless Router
Belkin Play N600. Acer Vista laptop. Wifi only, laptop wifi connects then disconnects. With ethernet connected the wifi and ethernet shows connected, when unplugged, the wifi will disconnect also.
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Dec 24, 2010 | Belkin Play N600 Wireless Dual Band Router...
My xbox360 scans and finds router but it will not connect. what is the problem?
Before connecting the X-box or play station or nintendo WII to the network, Make sure that you have all the wireless settings of the router.
if you don't know the wireless settings , then you will need to open the router set up to find the wireless settings.
For WII port numbers are ==> 28910, 29900, 29901, 29920, 80, 443.
For XBOX port numbers are ==> 53, 80-88, 3074
For Play station port numbers are ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
X-BOX
Click Here for more info
Dec 26, 2009 | Linksys WRT120N Router
Scan to pc not working in wifi
I'm not using WiFi, but the principle is the same if the issue is "PC Not Available" when you press the "Scan to PC" button, with USB, Ethernet, or WiFi connected printers.
Left click on the up arrow at the right hand side of the tool bar by the clock to show the "Hidden Icons." Right click on the icon for the Samsung printer, and select the
The scan to pc needs the path set properly. In my case, it was to "My Documents," but the "Scan and Fax Manager."
Click on the center top option for "Set Scan Button." Look at the right hand box for the destination listed. Mine was "My Documents."
Now look down half way in the window to the left for "Scan Property." Note the "Save Location" that is listed. In my case it was "My Scans," which is a sub folder of "My Documents" but the printer could not connetect to the sub folder. So, I clicked on the yellow folder to the right to select a different path. On the pop up window, click on its yellow folder and select the "My Documents" folder under the proper user's name, and then click okay. The path should now read c:\User\<username here>\Documents. Click okay.
Now when you press the Scan to PC button, it can find the path to the standard windows folder and not give the error of "PC Not Available."
The troubleshooting guide said to simply check the port. LOL. I'll work on seeing if I can get a sub folder to work later, but for now it's working okay. Hope this helps someone.
Craig
Oct 05, 2009 | Samsung SCX-4500 Laser Printer
Skifi xm
click on the display button until it shows the channel name
Aug 19, 2008 | Delphi SKYFi3 XM Radio Receiver
Lexmark 5400 series
Problem: Lexmark cannot retrieve applications list
I have the Lexmark X3550 with the WiFi option board installed (makes it same as the model X4550) and get the “cannot retrieve applications list” message on one of the five computers connected to my router (Linlsys WRT54G V8) and using wireless printing and scanning. Just like everyone else with a similar Lexmark WiFi printer/scanner, I can print wireless, but cannot get the wireless scanner to work on one of my PCs.
The fix, in my case, was to change the Lexmark network name as follows.
1. Launch Lexmark Imaging Studio.
2. Right-Click on “View or change network settings”.
3. Enter a new network name in the first box shown. (This box contained the correct network name for my PC, but another name was needed to make the scanner work. I simply added “-lex” at the end of the current network name.)
4. Right-Click OK. You should return to the Imaging Studio screen.
5. Close the Lexmark Imaging Studio window. (The tray icon should remain at the screen lower right.)
6. On the printer, press the Scan Mode button.
7. On the printer’s display screen, select the Computer Name that you entered for the new network name. Just use the arrow buttons until the exact name is shown.
8. Press the Check button. The display screen should show “Downloading Applications List”. Within about 10 seconds the message should change to “ *Scan to Computer ”. Wireless scanning should now work.
9.. Press the Start Color or Start Black button. “Requesting Scan” will be shown. After a few seconds scanning will start. The process is a bit slow.
10. After a while you may see an empty small Lexmark window onscreen. Later, the Lexmark Imaging Studio will appear onscreen, then change to show many options and features. An image of the scanned item will appear in a Lexmark window. Save and/or edit the image. Another scan can be done by pressing the printer’s Check button again. Be sure the correct computer name is shown on the printer’s display.
That’s it. A new computer name was the solution. Your PC and printer may require a restart (power off) after changing the “computer name”.
Regards, Fbyrd
Mar 12, 2008 | HP PSC 2210 All-In-One InkJet Printer
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
