Question about Braun Flex Integral 6550 Electric Shaver
Braun series 7 replacement head
I need a replacement head for my braun series 7 model 702 electric shaver
SOURCE: Braun battery replacement
Unfortunately this is almost impossible. The batteries are part of the circuit board, and Braun only authorize their service agents to replace the whole unit, and my local agent found that it had been discontinued. If you still want to have a go, two screws are hidden beneath the two grey plastic caps either side of the charging socket on the underside of the shaver which can be prized off quite easily. Once you have removed the screws, the small plastic section comes off. Now you can slide the outer casing off. A thin black cover at the back can then be unclipped, revealing the circuit board and batteries. The whole unit simply lifts out and would be easy to replace if you could find one! Rplacing the batteries would be far more difficult and risky. Good luck.
Posted on Sep 02, 2008
  • 5 Answers
SOURCE: how to replace battery on braun 7526 electric shaver
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Install new circuit board and reassemble
Posted on Jan 07, 2009
brector3
  • 1623 Answers
SOURCE: The braun 5510 shaver.. rechargeable or not
If working properly, model 5510 will work either from the internal rechargeable batteries or directly from the cord. If your shaver no longer recharges, it needs to have the rechargeable batteries replaced.
Posted on Feb 04, 2010
SOURCE: Braun Model 549 series electric shaver
broken screen braun 549
Posted on May 29, 2010
brector3
  • 1623 Answers
SOURCE: My Braun shaver 8585 has died. Foil, cable, box,
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Posted on Aug 23, 2010
How to replace battery braun shaver series 1
I don't know about this specific model of Braun shaver (I have a Braun Model 7526).
I have looked at the instructions for a couple of models of Braun Shaver, and the instructions are similar so it may help you to replace the batteries in yours.
Here is one of the instructions:
Braun 7526 battery problem
http://www.fixya.com/support/t1171024-braun_7526_battery_problem
Open the shaver:
3) Using a small torq driver remove the 4 screws
4) Open shaver
6) Remove and replace circuit board with batteries (or solder in the new batteries)
And here is a link to instructions for a few different ones:
http://www.fixya.com/support/t1094906-needs_new_batters_open_razor_7526
http://www.fixya.com/support/t6710169-change_battery_cost
http://www.fixya.com/support/t771258-braun_battery_replacement
Nov 16, 2015 | Braun Series 7 9585 Hair Trimmer
Correct replacement cutter head for series 3 340
braun series 3 combi 32S replacement foil and cutter blades pack silver color for electric shaver braun series 3 model 340 type 5775 parts.
Aug 29, 2013 | Braun Health & Beauty
Which shaver replaced Model 5814 XL electric shaver
philips norelco HQ5 replacement heads for electric shaver norelco 5814xl cutter blades replacement parts.
Aug 07, 2012 | Norelco Reflex 5814 XL Electric Shaver
I need to buy shaving heads HQ8
philips norelco HQ8 replacement heads for electric shaver norelco spectra 8800 series, norelco 7800 series, norelco 7100 series, norelco 7200 series.
Oct 25, 2010 | Braun Replacement Foil Cutter for Most ...
Can i get replasment foil and head
braun series 3 combi 30B screen foil and cutter block for braun 4775 blades replacement parts.
Jan 21, 2010 | Braun 4775 Electric Shaver
New head
Hello Brian, You can give the folks at www.electricshaver.com a try. They typically stock all the replacement and repair parts for most brands of electric shavers.
Here's a link to their site where you'll find part #5646768 for about $38 for a new set of the cutter head and foil (screen). It's always best to replace BOTH the foil and cutter block (head) at the same time, as any mircro burrs or nicks in the cutter blades will quickly ruin any new foil screen.
http://www.electricshaverstore.com/get_item_5646768_braun-foil-cutter-kit-360-complete-8000-series.htm
As you know, this is the simplest and easiest way to get an electric shaver back to a "like-new" shaving experience.
I hope you find this Very Helpful and best regards!
Nov 11, 2009 | Health & Beauty
Braun Flex Integral 6550 Electric Shaver Logo
35 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
