Question about Tefal ActiFry Deep Fryer
Paddle rotoating wrong way - Tefal ActiFry Deep Fryer
Hotpoint wmdp62 drum paddles replaced and wont stay in
I would need to see what you did to understand this problem. I suggest you call a technician out to inspect the problem.
Jul 20, 2017 | Washing Machines
Why will the icemaker not stop making ice and nothing appears wrong with the paddle that is supposed to sense a full ice basket (GSS25WGTIBB)?
have you checked the paddle to make sure its touching the cubes to reach the off position.it may just need a small ajjustment.
May 15, 2014 | Refrigerators
Is the paddle supposed to spin
Your paddle won't turn. Your silver bucket is the one moving (turning) and not the paddle. It's working like it should. I thought the same before I found the lid (cover).
Jan 11, 2013 | Back to Basics -- Plastic Bucket Ice Cream...
Water dispenser for gsh25JSTA BROKE can I fix
All of you guys are wrong. What that person is saying is that the physical paddle used when you place your glass in the dispenser bay and press against the paddle....That's what's broken the paddle......
Jan 05, 2013 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
I just bought a new B6000C bread maker. I have not used it yet. The instructions say "push the paddle down firmly onto the shaft to secure in place". But, my paddles just sit loosely on the...
No, there is nothing wrong with your bread maker. The paddle is supposed to be somewhat loose so you can remove it after baking for cleaning. Don't worry your paddle and breadmaker are fine.
Jul 26, 2011 | Black & Decker B2000 Bread Maker
My breadmaker have two paddles,one seem like it doesnt have the power to turn porbable.what is wrong,i want to fit it myself.
Hi, This could be caused by 3 reasons. 1) The bearing on the paddle shaft is ready to fail and the paddle is sticking. Take the pan out of the machine and see if you can turn the paddle freely by hand. 2) The belt is slipping. Tighten up the belt in the machine. Belts and pulleys are in the base of the machine. Remember to unplug machine when you work on it. 3) Make sure the pan is seated properly in the machine. Good luck Hank
May 12, 2010 | Kitchen Appliances - Others
Drum paddle keeps coming off had machine blocage
Are you sure you have got the correct paddle, as there is more than one version, and also there is a right and wrong way to fit them.
Make sure you push it hard into the locating slots, you should feel it click into place, to be sure it is located properly, lightly pull it, and it should remain in position.
Hope this helps.
Dec 30, 2009 | Hotpoint Washing Machines
The plastic padddles in the drum keep coming loose I have so far had to replace 5 paddles
Are you sure you are getting the correct paddle, currently there are 3 versions of drum paddles, all different .
Also are you fitting them correctly, it is possibe to fet them the wrong way round, you must make sure that you push them in firmly until you can feel them click into place. after fitting , you should be able to pull on them without too much pressure wiyhout them coming straight out again
Trust this will help you with your prob.
Thankyou.
Nov 26, 2009 | Creda Washing Machines
Tefal ActiFry Deep Fryer Logo
234 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
