Question about Coby 8GB MID1065-8 Android 10.1" Tablet
Reset coby mid1065
My coby mid1065 will not turn on or charge. How to I reset it.
Why won't my Kyros tablet turn back on?
Is it charged? does charger work or battery still alive?
Watch this video and decide if can you do anything with your Coby
Factory reset on Kyros MID 7012 without using Settings
Jun 23, 2015 | Coby Tablets & eReaders
I can not turn on or charge my Colby tablet
Sounds like you have a bad battery or your charger isn't working.
Dec 27, 2014 | Coby kyros Tablets & eReaders
How to reinstall os on coby 7" tablet?
Usually on an android device access settings : sd card and storage : select erase all or restore or factory reset and device will be factory restored . If the OS is completely gone you may have to access an image from te Coby website and install from a laptop by cable .
Jun 12, 2014 | Coby Kyros MID80244G Tablet
Coby mid8065
1. Turnn completly off the tablet.
2. With the tablet turned off, holding the return button while turning on the tablet-pressing power button. Keep holding the return button until you see the Hard Factory reset screen.
3. Confirm the hard reset procedure. Once done, simply wait until process has finished-the tablet will restart. This process can take up to 30 minutes, so it's very important that the battery of the tablet is completly charged before attempting the hard reset. If you can connect it to the charger while resetting, even better.
Regards! If that helped, don't forget to accept my answer!
May 31, 2014 | Coby MID8065-8 - Kyros MID8065 8 8 GB...
Coby not working
May 28, 2014 | Coby Tablets & eReaders
My tabet wont turn on
First make sure your charger is working properly. Check it with a volt meter or use a friends charger that you know is working. Charge your Coby Kyros for 4 hours. Use a small needle and gently insert in into the "reset" hole on the back cover on the left side. Hold it down for 5 seconds then release. Try restarting your tablet. If these don't work, you will have to get professional help to check it out.
Feb 12, 2014 | Coby Kyros 716829701508 Tablet PC
My coby kyros tablet touch doesnt work
Try to reset the unit. the battery may be faulty.
Dec 10, 2013 | Coby Kyros MID7012-4G 7" Tablet, Telechips...
My tablet wont turn on it continues to blink but wont turn on
Try using a paperclip to reset it on the back, hold it in for 5 seconds, if that doesnt work:
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
Apr 20, 2013 | Coby kyros Tablets & eReaders
How to fix coby kyros mid1024
my kyros mid 1024 not charging i nick fix
Jun 06, 2012 | Coby KyROS MID10244G 101Inch Touchscreen...
My coby kyros won't turn on, won't charge, no lights are coming on
Mine does that to but all I ever do it just hit the reset button on the back and it turns back on.
May 18, 2011 | Coby Kyros 716829701508 Tablet PC
Coby 8GB MID1065-8 Android 10.1" Tablet Logo
48 people viewed this question
Top Coby Tablets & eReaders Experts
Fred Block
Fred Block
Martin Murray
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
