I have an lg roboking. It starts works briefly and then stops and says please check the wheels.
Everything has been cleaned and checked.
SOURCE: DYT 4000 Lawn tractor won't start
I solved the problem after buying carb and fuel pump rebuild kits.The carb kit didn't fit anyway, but didn't need it. The problem was in the fuel filter. I had forgotten the problem happened when I ran out of gas. Inside the fuel filter is a washer held in place by a spring. Without fuel it apparently lost pressure and the washer slipped out of place about 1/2", which was enough to let all the gas through that could. The rebuild kit had a new rubber gasket. I won't let it run out of gas again.
Posted on Aug 11, 2009
SOURCE: Water Wheel won't keep turning
Replace the Idler and drive wheel. Even if it looks good the grove in the wheels get deeper over time until they don't work anymore. In a pinch a rubber band or two doubled up in the grove will make it work till you get the parts. Clean and replace the rim of the wheel once a year, replace the wheels once every few years and the thing will last 20+ years. The real reason they don't make them like this anymore is they would be missing out on the income of selling everyone wicks all the time. It's a far superior design. I kept a few of them running for my parents for years. I'm watching for one for my house, I'd pay tripple the cost of a modern new one for one of these in decent condition.
Posted on Feb 01, 2010
SOURCE: abs light stays on also speedo stops working
you probably have a wheel bearing that needs replaced
Posted on Jan 03, 2012
bobwstacey
  • 12 Answers
SOURCE: looking for manual LG Roboking Vacuum Cleaner
you tube shows operation and parts on video
Posted on Oct 02, 2012
sigi284
SOURCE: barracuda g3 works and then stops
Replace the diaphragm.
Posted on Oct 13, 2012
Looking for manual LG Roboking Vacuum Cleaner
Oct 02, 2012 | Vacuums
Yardman 26cs starts briefly then stops.
check the vent on the gas cap
May 23, 2012 | Garden
I have a 1991 ford f150, just changed dist cap, wires, plugs, tps, egr coolant temp sensor & the battery. started briefly then stopped. it cranks but won't start. cant afford to take it to the shop....
Make sure all your wires and connections are correct. Make sure everything is put back on. If everything is, it may be a cam sensor, crank sensor, ? Double check everything.
Mar 06, 2011 | Ford F-150 Cars & Trucks
I have an LG dryer Model # ddle7177rm/dlg7188rm.when we start the dryer it starts to heat then stops and it blows cool air. the ducts are all clean.
Hello
As everything in your dryer is working fine apart from it heating properly so the recommended repair will be thermal fuse/thermostat replacement. However, you can also test its continuity before replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | LG Dryers
I am having an issue with my LG front loader washing machine model number WM1815cs. The water will not drain and the clothes will not spin out. Everything works fine until the rinse/spin cycle and it just...
Hi
Thanks for using FixYa. OE is a Drain Error which indicates that the water was not fully drained within 10 minutes. To start with check the drain pump filter for any clogs/foreign materials and try to clean the filter. Also if you have already checked the drain hose for any blockage then check the pump for any blockages, if still its not resolved then it seems to be the pump that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | LG WM1815CS Front Load Washer
When starting up the 1997 Blazer the service engine soon come on briefly. Could you please explains why does that happen or is there a sign of in the reason why does the light appear when starting the...
The ces light comes on briefly until the system does it's self checks and verifies everything is ok then it's shuts it off. If it goes out, that's a good thing. The very fact that the light illuminates is telling you the system is working. Let me know if you need anything else.
Jul 07, 2010 | 1997 Chevrolet Blazer
Exactly the same
clean all the sensor rings and check for damage.
Jul 10, 2009 | 2002 Buick Century
LG TD-C700E/40E/41E/45E Condenser Dryer
sounds like your condensin pump is leaking and triggering the over flow micro switch not a job 4 a novice call an engineer good luck
Jul 25, 2007 | LG DLE2512W Electric Dryer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
