Question about Toshiba E-Studio 225 Multifunction Copier
ERROR CODE: 4036
I am getting the printing from my system for all the files but not able to take print out for outlook mail & internet pages from toshiba e-studio 225 printer
chad7houston
  • 62 Answers
SOURCE: Toshiba studio 281C problems
You should be able to print on both, but I wouldn't advise it at all. The envelopes are going to jam a LOT and you WILL eventualy get a label stuck inside the machine. Possible....yes. But I don't recommend it. :)
C
Posted on Oct 07, 2008
  • 2072 Answers
SOURCE: Toshiba 850 e-Studio CD20 error
That code means the used toner motor is not running. That is pretty easy to emove and check. You have to take off the right 1/4 cover, normally held in with 2 screws, then remove the toner assembly, on screw on a bracket on top of the assembly and a spring loaded pin on bottom. Unplug the plug and set aside. You then remove 2 screws holding in the used toner assembly and unplug one more plug.
The moror on the top normally is the one that binds, you can try cleaning it and lubricating it lightly.
The recycled toner motor may be going bad. Possibly the auger is bound, and causing it not to run.
I have no clue about the toner you are using, But it is always best to use the toner designed for any printer. But that sounds like it is out of your control. Most of the times its like adding water to the gas tank of your can and then wondering why it doesnt run.
Posted on Jan 27, 2009
SOURCE: Print driver for Toshiba E-Studio 3511 Copier/Printer for Window
You can go to http://copiers.toshiba.com and download it.
Posted on Feb 04, 2009
SOURCE: Toshiba e studio 163 printer
driver e-studio e 163 , 203 for winxp
Posted on Mar 25, 2009
  • 643 Answers
SOURCE: Can't print or copy with my toshiba e studio 161
H2 indicates thermistor open.
U can enter simulation mode and input "14" to clear the message.
If happen again, u need to check following:
Thermistor
Control PWB
Fusing section connector disconnection
The fusing unit is not installed.
Perform the following procedure to enter the simulation mode.
"C" key AUTO/TEXT/PHOTO key
Main code Start key Sub code Start key
(Note:Perform the first four key strokes quickly allowing no more than one
second between key strokes.)
Posted on Apr 06, 2009
Whenever i try to print a pdf file longer than one page from adobe reader, my e-studio4511 will only print the first page, followed by a second blank page, and then a final page with the following error...
Send the font information for each page in the PDF file when you print.
For Adobe Acrobat Professional 9:
1. Choose File > Print.
2. Click on Advanced.
3. Choose Postcript Options.
4. Under Font and Resource Policy, select Send for Each Page.
In Adobe Reader 9: try this 1
3. Under Font and Resource Policy, select Send for Each Page.
may or may not work try it
Hopefully this will be helpful to you all
Nov 20, 2010 | Toshiba e-STUDIO 4511 Printer
Printing is not happening with Outlook 2003
when you give print command from outlook mail just see which printer you selecting if have more then one printer remove it and set the default printer .when you giving print command choose the paper type also correctly.
Sep 15, 2009 | Microsoft Office Outlook 2003 for PC
E-studio4511 won't print more than 1 page of a pdf file at once.
download the latest PS driver off toshibas website, due to adobe 9 update this is a known issue, newest driver should fix
May 13, 2009 | Toshiba e-STUDIO 4511 Printer
I CANT PRINT FROM OUTLOOK EXPRESS AND IE 7
Print an Email in Windows Mail or Outlook Express To print a message from Windows Mail or Outlook Express:
  • Highlight the message you want to print in its mailbox.
    • Unfortunately, you cannot select and print multiple messages at once.
  • Click the Print toolbar button.
    • Alternatively, select File | Print... from the menu or
    • hit Ctrl-P.
  • Adjust any printer settings you deem necessary.
  • Click Print.
Mar 31, 2009 | Microsoft MS Windows XP Professional SP2
E-Studio 450 network issue
toshiba e-studio 450 black photocopy
I have machines, but I can not use the printer properties. If there is information about how appreciate if you provide information.
Jan 12, 2009 | Toshiba E-STUDIO 450 Copier
Print Data light blinking
-try converting the PDF file
-the driver may need to be reloaded
if you print from Word does it go trough? if yes then that particular file is the problem
Jul 29, 2008 | Toshiba e-Studio 350 Copier
Graphics/jpeg visible in outlook but will not print.
Make sure that you are actually opening up the email, and not just previewing it in the reading pane.
Double click on the actual email to be sure it's open.
Kathie
Jul 18, 2008 | Microsoft Office Outlook 2003 for PC
Outlook Printing Problems
open ie, change margins in file/page setup and try it again
Apr 08, 2008 | Microsoft Office Outlook 2003 for PC
Outlook 2003
There are many problems when using different versions of Outlook and Word, especially when word is used as the software for editing emails under tools --> Options --> Mail Format
Try disabling using word as the editor to prevent problems such as this.
Mar 25, 2008 | Microsoft Outlook 2003 for PC
Printing e-mail
It sounds like their emails have a lot of blank space at the end! I would check this be exporting the email & then importing it into, say MS Word. See how many pages Word says there are. If they really are sending 4 or 5 pages worth when all the required stuff is on page 1, I would then take them to task again over it.
Dec 21, 2007 | Microsoft Office Outlook 2003 for PC
Toshiba E-Studio 225 Multifunction Copier Logo
54 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
