Question about Electrolux Vacuums
Lg roboking keeps stopping and saying to check the wheels . Wheels are checked also brushe s and dustbin. It is very annoying .
It goes briefly. Will stop and restart with the remote but still keeps stopping. Needs to be closely babysat.
4 Suggested Answers
SOURCE: Brushes are clean, but Roomba stops and says clean brushes
I decided to take it apart and see if I could fix it because even if something inside went "SPROING" and I couldn't get it back together, it wouldn't be any worse than it was already.
FIrst, remove the dust bin part and the brushes. Then, there are four screws on the bottom gray panel which have to be removed first in order to get to the gears which hold the brushes. I did not remove the little sweeper brush on the front, but I just slide it through the hole in the gray panel.
Then in order to get out the orange section which actually holds the brushes, there are four screws which must be removed. The orange section is attached to a blue section. This entire unit comes out by sliding it toward the area where the dust bin goes, being careful not to tear the light gray rubber gasket which covers the side.
Once that section is removed, there are two screws on each side. These screws hold the orange thing to the blue thing. Once the screws are removed, lift up only the side which has the white squares into which the brushes are inserted. These are actually the back side of little gears. There is a face plate on the outside of the orange part on this end. The other end contains a bunch of wires and I was careful not to disconnect any of them.
The face plate has six screws which must all be removed. Use caution when removing the face plate. Hold it up so that all of the stuff doesn't fall out. It has a bunch of gears, little brass looking fittings and grease. Take care to only remove the gears which have the squares which hold the brushes AND do it one at a time unless you like working jigsaw puzzles. I used tweezers and a pin to clean the "gunk" consisting of hair, fuzz, etc., out of the little gears.
Reverse the process to put it back together. Hazel, my little Roomba, played me a happy little song and immediately went back to work. She seems as good as new.
Posted on Nov 20, 2008
SOURCE: roomba keeps saying clean brushes yet are clean!
Remove the Yellow connectors on the end of the brushes and clean around the pin well. If there is too much there, the roomba thinks there is something stuck and goes into clear mode (as if there is a chord stuck).
Posted on Feb 24, 2009
Make sure you take off the little cap at the end (the one that spins -- just grab it and pull it straight off) and clean under it too. The rest of the brush may look perfectly clean but what happens is that hair gets stuck under spinning cap and, like a slowly growing washer, it pushes the whole brush toward the gear box. When it gets pushed over enough, the large yellow ring starts to rub against the side of the brush deck making it harder for the motor to turn the brush and you get that "remove and clean brushes" message.
Posted on Mar 10, 2009
My Dyson DC35 stops after the first minute. Then it keeps stopping every few seconds. I checked for obstructions, washed the filter and cleaned the brush. Is it the batterie?
In the inlet pipe, there is a small valve that can get jammed shut with debris this causes them to pulse start, stop, start, stop, and so on. Ensure this is floating free, not jammed shut, it works purely on gravity... The other possibility is the cyclone needs cleaning. Remove the filter and check no dirt is lodged there. Remove the top torx screws and keep them safe. Carefully remove the top check for damaged seals gaskets etc (this can cause a malfunction). Again keep safe. The cyclone can then be inspected for dirt and dust clogging holes and airways. Clean thoroughly and reassemble, make sure all components are dry if they have been washed to clean them. Hopefully, this will restore the machine to working order
Feb 09, 2018 | Dyson Vacuums
The Dyson v6 goes in 5 second spurts then stops, then goes again. Does this 3-4 times then stops altogether. The battery is fully charged. Why does it do this?
Hi, this happens when the PCB detects a blockage. Take the filter out and then try it. If it no longer goes for only 5 seconds then your filter needs washed. Wash the filter in your washing machine .
Apr 18, 2017 | Dyson Vacuums
Lux classic vaccume keeps stoping
check all filters are clean, if ok check for blockages in pipes, it will stop if the motor overheat then restart when it cools down click on the link beloe to download manual if you don't av one,,
http://www.aerusvacuums.com/support/manuals/
Mar 26, 2013 | Electrolux Lux 5500 Canister Vacuum
When I am playing a DVD and want to stop it over night, what button do I push on the remote?
You can just press the stop button, but make sure you keep the DVD player on overnight. In the morning just hit play and the movie should resume where you left off.
Jul 28, 2011 | Vacuums
Hi my dyson keeps stopping and starting
It is stopping probably because it has a blocked filter. Down on the right of the machine is a filter. Press the coloured button to get it out. Wash and dry it and see how that goes.
Jan 25, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My roomba 400 series keeps stopping on its own
Take off the grill on the back of the bin. The round vacuum impeller is behind it. Make sure that's clean and free of debris. Run the Roomba with that little grill still off the bin-- is the impeller turning? If yes, you may have fixed it. If not, your Roomba needs a new vacuum bin.
Aug 26, 2009 | Roomba Robotic Floor Bagless Vacuum
LOUD NOISE FROM HOOVER POWERMAX ii
These vacs can stop up in almost inaccessible places. That sound means that it has stopped up somewhere and the electric motor is in a strain. Keep it running like that long enough and the motor is toast. I have one that seems to prefer the hose area where it goes by the motor and into the bag. The tube from the motor to the bag also is prone to stop up. To take these apart requires that you start at the beater bar area and work you way inward. In certain areas if you look closely, you'll see little arrows pointing to the screws. These are the ones that will allow you to get closer to the innards of these. When you get to where the motor is, look for blockages from the attachment hose. It takes only small items to completely block it off which will effect performance from both the beater bar/normal intake and also from use of the hose itself. The b***ards can be a pain to keep functional. I've personally removed rather sizeable wads of dog hair from mine that mucked up the works rather than went into the bag. Belts for the beater bar are notoriously short lived in these as well. When they break, the vacuum is only good as a floor sweeper. Stock up on both belts and bags for these. Good luck!
Oct 20, 2007 | Hoover Powermax U5242-930 Vacuum
Vacuums Logo
662 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
