Osaka gas 140-9023 is not showing temprature above 16
My osaka gas heater 140-9173 is not switching on rather a green light on key is permanently on. in this case how to switch on the osaka gas heater
The green light means it's in standby mode. Make sure the child lock is not on and that it's not in timer mode. Also, check to see if the heater is dirty on the inside, unplug and clean as necessary. Make sure that the gas supply line valve open and that you have pressure in the line. The over heat thermister could be tripped and the whole unit needs to be unplugged and then plugged back in.
Jan 21, 2017 | Heating & Cooling
Osaka gas 43-564. what's the meaning of writing on panel
I need user manual (in English) for OSAKA gas heater 43-564 model
Jan 25, 2014 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
OSAKA 43-530 , Error 55 and middle green light flases in left pannel
If the gas lights & doesn't stay on, then there is a flame sensing issue. Remote sensor may have flame impingement (dirty). Clean flame rod sensor with light sandpaper or cloth.
Jan 06, 2014 | Weather King 12AJA4801AH Air Conditioner
Hi i need English Language manuals for Osaka Gas Fan Heater Model 43-659... as the operating buttons of the heater is in Japanese Language. by mis handling it i got its timer ON. now dont know how to fix...
I have gas fan heater made by Tokyo Gas, model MA-A630TFH.
on the front pannel all the language is jAPENESE. PLEASE HELP ME AND MANAGE FOR OPERATIONAL MANNUAL IN ENGLISH.
Oct 20, 2012 | Heating & Cooling
Osaka gas heater manual
DOWNLOAD LINK
http://www.dl4all.com/aka/tag/osaka+gas+fan+heater+user+manual.html
OR
http://www.osakagas.co.jp/indexe.html
Jan 24, 2012 | Water Heaters
Hi: Last week, a contractor installed the above-mentioned new 16 seer heat pump, an air handler and a heat kit. Our house has 3 levels, each about 800 square fit. Initially the house would not heat above...
That is worrysome about putting refrigerant in hap hazzardly... There is a math style process involving pressures and temperatures in two locations that dictate how much ref. goes in. Anything else shows clueless installer. Too much or too little ref. will not work correctly.
Heat pumps do not work below about 33 degrees outside temp. Above that them, aux heat should not be coming on...
You would need to verify that the system you have is rated for the space that you are trying to heat...
Heat pumps heat more slowly than gas or electric, so using set back thermostat is not recommended. True economy comes from maintaining constant temprature. System has to work to hard to raise the temprature, and eats up savings in efficiency by allowing temp set back.
Feb 14, 2011 | Heating & Cooling
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
