Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
Water buildup inside of refrigerator
Water inside of refrigerator
  • majrdf May 11, 2010
    The water is running down back on the inside. Not sure about how to check the drains or tubes.
I have water in the bottom of the frig on the inside, what should I check
Posted on May 31, 2013
  • 11,896 Answers
It may be the fact that your evaporater pan is not working. The freezer and fridge have drains inside them. The water inside and condensation go down tube that you see on backside of your fridge. This tube goes into a drainpan in the bottom and than evaporates.
You should also check to make sure your fridge and freezer are cold enough.
Posted on May 20, 2009
3 Suggested Answers
SOURCE: Water leaking inside refrigerator
Its the clogged defrost drain. I have the same problem. I just cant find the drain
Posted on Jun 07, 2008
aasc
  • 1606 Answers
SOURCE: Water buildup inside refrigerator. Source back or
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Posted on May 26, 2010
My freezer door wont open, feels locked on one side. water is leaking underneath
Just answered a similar question about this but with the water leaking in this one, I think the door got wedged open slightly and you now have an excessive ice buildup on the inside of the freezer causing the door to stick from the ice buildup. You may need to pull hard to break loose the ice and when you get the door open clean all excessive ice from around the door seal area. Packages inside may need to be re- arranged so door closed properly.
Mar 05, 2015 | GE Profile Stainless Bottom-Freezer...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 06, 2011 | KitchenAid Refrigerators
Jenn Air JTB2488AE Freezer Top refrigerator. Water puddles inside the refrigerator space beneath the vegetable crispers. The ice maker has been turned off and the water still appears. The amount of water...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 04, 2010 | Jenn-Air Refrigerators
Ice buildup from water feeding the ice maker
Are you certain that the ice build-up is actually originating from the water flow into the icemaker? If ice is built-up on the rear freezer panel, then your problem is more than likely a defrost component issue (defrost thermostat or defrost heater(s). If the ice is built-up on the side wall of the freezer near the icemaker, then water is probably being diverted inside the water inlet tubing that goes into the icemaker. This diversion is usually caused by an accumulation of ice inside the water inlet tubing. You will probably need to remove the icemaker in order to glance inside the water inlet tubing to see if ice is in fact inside the tubing. If so, take a screw driver or other object that won't puncture the tubing and remove the ice.
Contact an appliance service company if the ice is on the rear freezer panel.
Feb 17, 2010 | GE GSH25JFR Side by Side Refrigerator
No ice instead water dripping down into freezer making icicles
If you have icicles, where are they forming at? If on the front of the ice bucket, then look at the dispenser shoot door is closing all the way. The way to check that is to look into the shoot while holding a flash light (or bright light) up into the dispenser from the front side of door. You should see no light.
Now if you have ice buildup around the inside of bucket, mainly from the ice maker to the bucket then you either have an ice maker that is leaking water or you have a water valve that is not shutting off all the way. Suspect water valve if you have ice buildup within water inlet tube on top of ice maker. Frozen water within tube is good indication that water valve is leaking.
Look inside refrig side of refrig, usually located on right top side of wall, you will find a tag with model number and serial number. Need both to get you the right part number for ice maker or water valve.
Oct 08, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice buildup in vegetable bins - otherwise OK Not model shown below (top freezer, too old) but listing one only way to get past screening
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 27, 2009 | Whirlpool GS6NBEXR Side by Side...
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Water dispenser keeps dispensing water when not pressed
If you can pull on the lever to make water flow stop, chances are there is a mineral buildup inside the valve, or the seat in the valve has failed. Either way, the valve normally needs to be replaced as they are not usually serviceable. Leave the Model number of the refrigerator so that I can check what to replace.
Dec 28, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Jun 06, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
181 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
