Question about Kettler Coach Rowing Machine
I need a foot peddle and pin for a Performax 1050 Rower! Where can I find them????
The cord to my footpedal only works in specific positions. Can I get just a new cord or do I need an entire new pedal?
you should be able to fix it yourself. Make sure the machine is unplugged from the wall socket. With the foot peddle upside down on a flat surfice, using a flat head screw driver, try prying open the foot peddle. Once open inspect the wires, one might be loose or disconnected and hardly touching the leads. Secure them if they are loose or reconnect them if unconnected. Close the foot peddle, plug in machine and try the foot peddle.
I hope this helps and saves you money on buying a new one.
Jan 20, 2014 | Sewing Machines
Rower locking pin
go to www.fitnessrepairparts.com or www.doctrotreadmill.com or www.treadmillpartszone.com
God bless you
May 25, 2012 | Exercise & Fitness
Nothng happens when I step on the foot peddle
Check the pins on the machine plug to make sure none have been pushed in, check the cables for any breaks but make sure the plug is out of the wall first, if you can undo the plug on the lead to check it all well and good, failing that take the foot control and lead into a sewing machine shop so it can be tested
Jul 10, 2010 | White Sewing Sewing Machines
Missing electrical hook-up, foot peddle, and manual
Need the make and model number if you need any help
Feb 19, 2010 | Sewing Machines
New machine, foot peddle has part of spring
1 - Unplug the power from the wall.
You can remove the top of the foot control by CAREFULLY prying the top and bottom apart with a flat screw driver at the pivot point where they hinge. Once you have it open you can put the spring back where it goes and snap the top back on. Make sure you have first put the top and bottom together at the end opposite the hinge/pin end.
Feb 09, 2010 | Brother CS6000i Computerized Sewing...
Didn't come with a foot peddle
We have all available sewing machine foot controllers available, is there a way for you to take a digital picture of the spot on the machine that the foot controller plugs into and email it to me?
Sewing Machine Foot Pedals
May 20, 2009 | Euro-Pro Dressmaker 998B
What kinds of boats are used for rowing?
The boats (or shells) are basically of two types and reflectthe two forms of rowing---sweep rowing and sculling. In sweep rowing each rower handles a single oar (about 12.5 ft or 3.9 m long) in sculling a rower uses two oars, or sculls, (each about 9.5 ft or 3 m long). The word shell is often used in reference to the boats used because the hull is only about 1/8" to 1/4" thick to make it as light as possible. These shells are also rather long and racing shells are as narrow as possible while recreational ones can be rather wide. Most shells today are made of composite materials such as carbon fiber, fiberglass, or kevlar. A few manufacturers still build wooden boats. Each rower has his back to the direction the shell is moving and power is generated using a blended sequence of the rower's legs, back and arms. The rower sits on a sliding seat with wheels on a track called the slide. Each oar is held in a U-shaped swivel (oarlock) mounted on a metal pin at the end of a rigger. The rigger is an assembly of tubes that is tightly bolted to the body of the shell.The exception to this are some european recreational boats called "inriggers" which have the oarlock attach directly on the gunwale. The subtypes of rowing shells are classified according to the number of rowers in the shell. Sweep Boats (each rower has one oar) These shells can have a coxswain---a person who steers the shell (using a rudder) and urges the rowers on. I have included in parenthesis the symbol used for each subtype along with some dimensions and weights. Coxed Pair (2+) Two sweep rowers with a coxswain. Coxless Pair (2-) Two sweep rowers without a coxswain. Coxed Four (4+) Four sweep rowers with a coxswain. Straight (or Coxless) Four (4-) Four sweep rowers without a coxswain. Steering is usually accomplished via a rudder that is attached to a cable that is connected to one of the rower's foot stretchers (this an adjustable bracket to which the rower's feet are secured). The coxless pair has a similar type of rudder setup. Eight (8+/8o) Eight sweep rowers with a coxswain. Eights are 60+ ft (~18.5 m) long and weigh about 250 pounds (~114 kg). Sculling Boats (each rower has two oars) Only in rare cases do these boats have a coxswain. Steering is generally accomplished by applying more power or pressure to the oar(s) on one side of the shell. The hands overlap (usually left over right in the US) during part of the rowing cycle, or are always left in front of right. Single (1X) One rower or sculler. Singles are about 26 ft (8 m) long and less than a foot (0.3 m) wide. Racing singles can weigh as little as 30 pounds (~13.5 kg). There are heavier (~45 to 50 pounds), shorter and wider versions often referred to as recreational singles. Double (2X) Two scullers. Most racing doubles can be also used as a pair with a different set of riggers designed for sweep oars. When used as a pair a rudder is usually added. There are also recreational versions of sculling doubles. Quadruple (4X) Four scullers. Often referred to as a `quad' and usually has a rudder attached to one of the sculler's foot stretchers as in the straight four. Most quads can also be rigged as a straight four using a different set of riggers. Octuple (8X) Eight scullers. This is rarely seen, though is used in the UK, at least, in junior competition where sweep rowing is not allowed. Weight Classifications There are basically two weight classes for rowers---heavyweight (HWT) and lightweight (LWT). Men (M) For team LWT boats, there is a 72.5 kg (~160 lbs) individual maximum, and the boat must average no more than 70 kg (~155 lbs). Women (W) The individual maximum for team LWT boats is 59 kg (~130 lbs), and the boat must average no more than 57 kg (~125 lbs). In the US, the women have an individual max only; no average. In some regattas in the US (usually head races late in the season) these limits are increased by 5 lbs. A rowing shell is usually built with a particular weight class of rower in mind. Until just recently the Olympics effectively had only HWT classifications.
Dec 01, 2008 | Sevylor Fish Ranger 280
Sewing machine foot peddle
if this is a kenmore try this site...
http://www.kenmore.com/shc/s/c_10154_12604_Kenmore_Sewing+Machines+&+Accessories?adCell=AH
under featured item scroll right till you find the foot peddle. price 19.99 +s/h
Oct 17, 2008 | Kenmore Sewing Machines
Kettler Coach Rowing Machine Logo
47 people viewed this question
Top Kettler Exercise & Fitness Experts
Jim London
Jim London
ray gallant
Steven's...
Steven's...
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
