Question about Porter Cable 332K Quicksand Random Orbit Sander W/ Case
Porter Cable Random Orbital Sander rotates but does not "orbit"
My Porter Cable Random Orbital Sander model 333 pad rotates at a high speed but does not appear to randomly "orbit". This results in immediate circular scarring on the surface to be sanded.
  • fretdancer May 25, 2009
    I read the above answer but there is no part listed as an oscillating bearing in the schematic. The problem started when the rubber belt broke so I replaced it but the diagram shows it slipping over a pulley which is actually just a flange that is screwed down and does not rotate. This does not seem to restore the randomness of the pattern
Just solved my problem with Porter Cable 333 orbital sander which just groaned. I thought the worst. I carefully took it apart on the garage floor and immediately suspected it needed lubrication as the motor turned hard. I used my flexible long plastic tube lubrication and put some on the bottom bearing shaft the best I could. I worked it around and around. I began to feel it turning easier. I applied more oil and kept moving and it became completely free. I put a drop on the top bearing even though it was loose. I put it all back together and it works like new. Lesson: do not look for the worst when a tool quits. Suspect the culprit to be lack of lubrication!!!
Posted on Aug 15, 2011
  • 420 Answers
It is likely that the oscillating bearing is frozen.
Posted on May 20, 2009
Porter cable model 333 will not orbit and spins at a very high speed. I do not have a manual.
there is a belt from the motor to the pad that has apparently broken. Go to dewaltservicenet.com and you can download both the parts breakdown and the operators manual. If I have helped you would you please vote accordingly and thank you
Sep 06, 2011 | Porter Cable 332K Quicksand Random Orbit...
I have a Mastercraft random orbital sander Model 54-7206-2 and need a dust bag. Is it available, how much, and how do I order it in Canada?
I just had the same problem. I couldnt find any information online.
call the toll-free help line
1800-689-9928
Tell them the make of the sander and what kind of part you need. They will look it up and ship it to you in 7-10 business days
Feb 20, 2011 | Porter Cable Porter-Cable Variable Speed...
Porter Cable random Orbital Sander (Quicksand) Model 333, Double insulated When sanding, it stops and starts, it sounds as thogh it is stuck and then gets going for a short while
Hi, Sanders are prone to getting lots and lots of dust inside the unit. The cooling fan makes this problem inevitable. The only way to fix this is to take it apart and and blast it with a pressurized air tool. Hopefully this will bring back some life to your sander. The effectiveness of this procedure is dependent on how well you can remove all of the dust. hope this helps.
Nov 16, 2010 | Porter Cable 332K Quicksand Random Orbit...
My 5" random orbit sander model 333 is spinning out of control. What do I do?
I may not have the whole picture, but all random orbits spin wildly if they are not pressed onto the wood a little. Do you mean it is not oscellating, but just spinning when it is on the wood? That would be an issue requiring cleaning or repair, otherwise, just don't turn it on until you have placed it on the wood to avoid marring.
Farmerbear:)
Sep 07, 2010 | Porter Cable Random Orbital Sander, 5"
Orbital sander doesnt orbit!
Never start the Sander without first placing it against the surface to be sanded. In free air the Sander will not osolate.
Jun 12, 2009 | Makita BO5010 5" Random Orbit Sander
Makita 5010 will not work in random orbital mode
It sounds like the bearing in thee bottom plate is seizing. If you turn the pad by hand does the motor turn. It should be smooth. I would look at that. The bearing number for Makita is 211236-8 or if you can get a generic bearing it is 6002DDW. Let me know
Jan 11, 2009 | Makita Tools & Hardware - Others
7336 orbital sander
If you are talking about the actual sanding pad itself it should just pull of .If you are talking about the backing pad it should un screw
Sep 10, 2008 | Porter Cable 7336 6 Inch Variable Speed...
Porter Cable 332K Quicksand Random Orbit Sander W/ Case  Logo
842 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim Parker
Jim Parker
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
