Question about Staples SPLP500 Scientific Calculator
Spl-p500 not printing - Staples SPLP500 Scientific Calculator
Why doesn't the equal button work when I do additions and subtractions?
Your calculator is fine. It is an adding machine first, so it uses adding machine logic and you hit the star button to print the total on the tape. The equals sign is only used when multiplying and dividing.
Adding machine logic is as follows:
5+ total 5
3- total 2
7+ total 9
* print out total
Good luck,
Paul
Sep 13, 2016 | Staples SPL-P500 Printing Calculator
Hei, need help when printing from Samsung Galaxy Tab 10.1/Polaris Office app to Samsung printer SL-M2070W: SPL error code 11-1113 position 0x0 system h6fwsim/xl_image line 398 version spl 5.73. Thanks in...
I am trying to print via wi-fi direct, and it gives me:
SPL ERROR -Please use the proper driver
POSITION 0x0
SYSTEM h6fwasim/x1_image
LINE 398
VERSION SPL 5.73.04 06-10-2014
ERROR CODE 11-1113
Any help?
Oct 10, 2013 | Office Equipment & Supplies
SAMSUNG CLX-3185FW SPL-C ERROR - INCOMPLETE SESSION BY TIME OUT
try printing with the right driver and make sure if ur computer is 32 bit or 64 bit...
Mar 30, 2013 | SAMSUNG CLX-3185FW COL LASER MFC Projector...
Spl-c error insufficient memory
Insufficient memory seems to be caused by printing large, complex images. Printing slightly smaller will often fix the problem.
Mar 05, 2013 | Samsung CLP365W Color Laser Printer
How to change ink rollers in calculator
How do you change ink in the Staples SPL-P500?
Jan 17, 2013 | Staples SPLP500 Scientific Calculator
Setting date on Staples SPL-P500 calculator
You press TIME and then you have a button = (it's also written SET on it) press for few second, it will flash, you can now set the date, DD-MM-YYYY than =/SET than TIME again then, =/SET you can now set the time ( the button X / AM-PM to set am or pm) you press =/SET when you're done, and you're set !
Oct 22, 2012 | Staples SPLP500 Scientific Calculator
Where can I get instruction on a spl-p500 calculator
Go to a web search page and type in spl-p500 calculator instruction manual.
May 02, 2011 | Office Equipment & Supplies
Spl-c error - including corrupted data (printer Samsung)
SPL-C -Incomplete Session by time out
Position : 0xddde (56798)
System : src/os_hook
Line :1646
Version : SPL-C 5.35 11-20-2007
Any one can help me how to fix this Error please.
Oct 15, 2009 | Samsung CLX 3160fn All-In-One Printer
Staples SPLP500 Scientific Calculator Logo
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Randy Schumann
Randy Schumann
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
