Question about Logitech QuickCam Communicate STX Personal Web Camera
Installation does not go to camera setup. It aborts before going.
We connected Camera first by mistake and tried to install, then it would not work. Then realized that software should be installed first. So we disconnect the camera and tried to install. But it would not finish installing. It aborts before going to Camera setup.
After cleaning my computer, my installation for this camera was wiped-out. I need to upload pictures without the installation CD (which is gone).
Please set the "USB Connect" option in the Menu of the Camera to "Mass Storage" option.
Steps to go to USB Connect option:
Press Menu button and select Setup option.
Then select the Setup 2 and then the USB Connect option
Then connect the Camera to the Computer and the Camera will be recognized as a removable device in "My Computer".
The Computer recognizes the Camera as a Removable device just like a Pen Drive. You can access the files in the Camera in the same way you access the files in the Pen Drive.
Then copy the files and paste them to a desired location on the Hard drive of the Computer.
If this does not work, then you may select the "PTP" option and Pictbridge option before connecting the Camera to the Computer to check if they work.
Please use the supplied USB cable to connect the Camera to the Computer.
Jul 18, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
When installing webcam software (Pro 9000) the setup does not recognise my IE and aborts the setup. Have IE7 working. Thanks.
Upgrade to Internet Explorer 8 and then try installing again. You can install the newer version by running windows update (browsing to update.microsoft.com with Internet Explorer). It may be an optional update, so be sure to do a "Custom" update and manually select the Internet Explorer 8 Install.
Jul 10, 2010 | Logitech QuickCam Pro 9000 Web Cam
I cannot install my camera
insert the installation cd that came with the camera, follow the setup wizard and finish installing the cd.After installation plug the camera and you can start using your camera. goodluck.
Aug 10, 2009 | Computers & Internet
WVC54GCA camera - setup is ok with cable install but once going to wireless, no go using Belkin N1 router
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
May 16, 2009 | Linksys WVC54GCA Network Camera
Have attempted to install camera and it aborts once at install.
Normal 0 Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
video talk with your Family and Friends. Hope this helps. Bud
Apr 01, 2009 | Logitech QuickCam Communicate STX Personal...
Problem loading Webcam driver
Normal 0 You need to go to the manufactures site and download the VISTA driver for the camera. Then follow the info below to install the program.
Normal 0
Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Oct 27, 2008 | Computers & Internet
Msi starcam 370i install problem
Disconnect the camera from the USB port and reinstall the software program. When the program asks you to plug in the camera, do so and finish the install. Then look at the info below to setup your Audio & Video so it will work properly.
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Oct 16, 2008 | MSI Starcam 370i Webcam
I am not sure how to install the software
WARNING: DO NOT connect the camera to your computer before installing the software.
To install the software, insert the Logitech camera software CD into your computer's CD-ROM drive. The Setup screen should appear. If it does not, please perform the following steps:
  1. Click Start and then Run.
  2. Type D:Setup.exe and press the Enter key.
  3. Follow the on-screen instructions.
After the computer reboots, the driver installation for the camera will start. Do not connect the camera until the setup prompts you to connect the camera cable to your computer.
While the driver installation progresses, remove the camera and camera base from the packaging and mount the camera on the camera base.
When prompted, plug the camera into the USB port. You should see the following diagram to let you know where to plug the camera in:
After the installation is complete, the camera should be ready to use.
Thanks
Aug 21, 2008 | Logitech QuickCam Messenger Web Camera
Logitech installation CD error
Normal 0 Did you install the software with the camera connected to the computer? Disconnect the camera from the USB port and reinstall the software. When the program asks you to connect the camera, do so, and it should work. Hope this is of some help. Bud
Below is info for setting up Audio & Video to chat on line after you install , either Skype or a messenger program.
A. Skype Setup:
B. Yahoo Setup:
Aug 13, 2008 | Logitech QuickCam Communicate STX Personal...
Trying to talk to another computer with quickcam
Setup :
*NOTE: DO NOT connect the camera to your computer before installing the software.*
Or
You can download the latest vista drivers from here, this link will give you the instructions on how to download the drivers with the images.
http://tinyurl.com/6ruwav
Using the CD :
Type D:\Setup.exe and press the Enter key.
Using the Downloaded file :
Double click on the setup file.
We have done the drivers installation which are needed by the computer to ecognize the camera.
Setup instructions to work with the camera :
http://tinyurl.com/585der
Hope this helps.
Good Luck.
Live, Love,Laugh.
Apr 13, 2008 | Logitech QuickCam Chat Personal Web Camera
Logitech QuickCam Communicate STX Personal Web Camera Logo
63 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
