Question about Vacuums
Roboking keeps stopping and saying to check the wheels. Have done this numerous times with same response.
Our Roomba makes little gouges in the woodwork about 11" - 12" apart, what causes this?
Is it literally ripping through the varnish on the floor and tearing into the wood? Two gouges 11-12" apart sounds like the space for the wheels. I would look to see if there is anything wrong or missing from the wheels. Aren't the wheels rubber though? Also check the white/black ball wheel at the front. The axle for this can get clogged up with hair and it will stop turning. Then you're just dragging or pushing a locked wheel. I can see this might scrap the floor. Insert a small standard screw driver in the gap at the right or left and this ball wheel can be pried out. Then remove all the hair wrapped around and into the axle. Pop back into place when done.
Jun 29, 2014 | iRobot Roomba 560 Robotic Vacuum
Looking for manual LG Roboking Vacuum Cleaner
you tube shows operation and parts on video
Oct 02, 2012 | Vacuums
Brush has stopped rotating
Be sure to remove all threads,hair and debris from all parts of the brush. Also check the wheel well where the brush attaches. Sometimes threads, hair and debris will build up in this area and keep the roller brush from rotating. You will need a firm brush and perhaps even tweezers to remove any stuff you find. Once this is done, if you still have problems there might be a connection problem and you should take it to a professional.
I hope my first suggestions solves your problem. BE SURE YOU UNPLUG YOUR VACUUM BEFORE STARTING ANY REPAIRS!
If my advice works, please come back and rate my solution!
Jun 07, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
Roomba 560 won't run correctly
Hey
if it's 5 beeps it says: Drive wheel is stuck
You should clean both , push both in and out and confirm it turns freely
Good luck
Avi
Feb 24, 2010 | iRobot Roomba 560 Robotic Vacuum
It only spins in one place then stops
As said, if it beeps 9 times after stopping, than this is known issue and if your bumper moves freely, you might be facing a sensor fault caused by poor quality of components.
Here is a guide to fix it
Have fun
Avi
Nov 22, 2009 | iRobot Roomba 560 Robotic Vacuum
The belt keeps on slipping off causing the brushes to stop
Over time the belt stretches and gets to big to stay put all of the time. Get a new Hoover belt and install it. That will solve your problem
Jun 16, 2009 | Hoover S3755 WindTunnel Bagless Canister...
Brushes cleaned thouroughly and wheels as well. Does not appear to be suction.
Start troubleshooting here. If that doesn't help, call customer support at 1-877-855-8593. Be sure to have your Roomba with you when you call.
May 21, 2009 | iRobot Roomba 530 Robotic Vacuum
Miele S758 stops working for no reason
The problem on mine was as described by others. Miele s758 stops for no apparent reason. The first time it happened I had the hose assembly replaced under warranty. Two years later, same problem. I have found that contacts at BOTH ends of the hose were intermittent. I dismantled both ends, extracted both sets of contacts, immersed both sets of slip-rings in methylated spirits and cleaned all the black gunk away. The three PCB mounted contacts were similarly cleaned, retensioned and lubricated with Electrolube. After re-assembly the problem has disappeared. I imagine a repeat procedure will be required in a couple of years.
CAUTION: The procedure is a bit tricky, so unless you know what you are doing, it would be preferable to have it done by someone who does. It is worth fixing as the replacement assembly is $AUD400.
GeeJayL
Sep 02, 2007 | Miele S758 Bagged Canister Vacuum
Vacuums Logo
22 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
