Question about Breville Blender Kinetix Control BBL605
Bbl605 blender flashing overload protection on startup
Blender is only ever used for smoothies and displays overload protection on startup, and won't start. Hasn't been used for days. Any ideas?
  • 10 Answers
SOURCE: Blender stops after about 2 seconds on every setting
correct - replacing the cord is suggested and simple.
Posted on Aug 04, 2009
SOURCE: breville blender bbl550 stopps after 5 seconds any setting
Mine does this as well... 5 seconds of operation and then OFF.
My guess is this is a fail safe where the blender is turning itself off to avoid overheating and what could potentially cause this overheating is the blender is struggling to turn the blades. What could cause this struggling of turning the blades I am guessing is a lack of oil in the blades rotating parts.
If you hold the circular blade part and turn it, you'll probably find that its hard to turn? Mine is... and I oiled it up a bit and found I got a bit more usage out of it... although only temporarily.
Ideally I need to pull it apart and oil it properly.
Posted on Dec 29, 2009
SOURCE: received the Breville Ikon 600
My IKON 600 Blender fuse had blown. It was located on the circuit board and can be found by removing the bottom of the blender. Fuse is Fast Blow 10A, metric 5mmx20mm. The fuse blew because the bearing in the bse of the jar froze. Bearing # 608-RS. The beraring froze because the seal in the base of the jar was leaking. Solution: Clean seak surfaces, replace bearing and fuse. Total cost of $6 with my labor.
Posted on Feb 11, 2010
SOURCE: Breville Blender
I need the blend jar for Breville Blender electronic Model BL3. I did not notice that a stainless steel spoon was in the blender. When I switched it on the crossed blade broke off.
Posted on Apr 15, 2010
SOURCE: blender will not run. the power button is lite but
There is a 10 Amp thermal fuse (SF129E) that is supposed to create an open circuit when the motor windings exceed 133 C degrees. Although this fuse should close again when the motor cools down it can become perminantly damaged. Locate the fuse by following the black leads from the coltrol board to the motor brushes. It's inside a cloth insulating sheath secured against the windings with a metal strap and two ty-raps. I bypassed the fuse with a wire instead of replacing it. It would probably just blow again sooner or later. p.s. you need a T10 Torx screw driver to disassemble (screws under rubber feet) $3 at ACE hardware.
Posted on Jul 22, 2010
Suggest the best blender under 100 for making smoothies?
There are various online platforms available for buying Best Blender Under 100. You can prefer Ninja professional blender which is the new product on the block. this product is an amazing replacement for making smoothies and for other purposes also.
Dec 01, 2017 | Blenders
Best blender brand for smoothies and juicing?
I would recommend to invest in a high quality blender that can perform all blending operations. If you're going to blending a bunch and need high speed blender to prepare smoothies and juices quickly. Vitamix will be a great option.
GroomNStyle Best Kitchen Blender Reviews 2015
Jul 29, 2015 | Blenders
What is the best blender for making smoothies with frozen fruit?
There are many types of blender available on the market which perform a different operation. Some blender is famous for specific work. I would suggest you choose the blender which can perform all the blending operation perform in the kitchen. Ninja Professional Blender BL160, BL660, BL482, Cosori High-Speed Blender.
This all is the best budget blender for smoothies. You can get the comparison of all these blenders in one place, then you can choose the best one which is suitable for your kitchen.
k2-_dc60fae0-5edf-426c-815f-45fa26bb0c57.v1.jpg-a8dba74604930421996186d49210837d5e1c6aed-optim-450x450-1idkyi3fqqfoabkjwactfx1g-2-0.jpg
Jul 28, 2015 | Vitamix Blenders
The rubber seal on my smoothie maker has been lost
You can order a new seal for your smoothie blender here:
http://www.westbend.com/catalog.cfm?dest=dir&linkid=90&linkon=subcategory
From that link, just choose the exact model of your product and order the seal that fits your smoothie blender.
Feb 28, 2011 | Back to Basics 600 Smoothie Plus Work Top...
Breville Blender Kinetix Control BBL605 Logo
75 people viewed this question
Top Breville Blenders Experts
Mike
Craig Butler
Craig Butler
Joseph Hoffmann
Are you a Breville Blender Expert? Answer questions, earn points and help others
