Question about Norelco Arcitec Electric Shaver - Gray/Black
How i clean my razor
I have a norelco arcitec razor and no instructions on how to clean the heads
I have this razor as well. Just flip the heads open, dump the hairs in the garbage and rinse the heads (while open) under hot water. Keep the heads open until dry and close on up.
Posted on Aug 31, 2009
How to change blades on norelco arcitic razor
Replacements for Arcitec models can be found at shaveroutlet.com using the link below
http://shaveroutlet.com/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Removal and replacement is simple. See diagram below
Jun 26, 2014 | Norelco Arcitec Electric Shaver -...
I need a users manual for my philips norelco arcitec razor users manual so I can remove the cutter blades for cleaning
The user manual will not help you with this because the Arcitec models were designed so that the cutters could NOT be removed to be cleaned. This is a major disadvantage with the Arcitec models as you can not disassemble the heads to thoroughly clean them. This causes you to have to replace them more frequently.
You can try running the shaver head in a dish of rubbing alcohol to try to loosen the build-up and rinse it out but that's about all you can do.
If you need to replace them, you will find at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Oct 30, 2011 | Norelco Arcitec Electric Shaver -...
I need directions on changing the head on the Arcitec razor head
Changing the head on Arcitec models is very easy. It doesn't come apart like older models. For the Arcitec model you simply pull off the entire head assembly and snap on a complete new assembly. See diagram at the link below
http://shaveroutlet.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/f/i/file_34_1.jpg
You can purchase replacement heads for this model at shaveroutlet.com. See link below
Aug 17, 2011 | Norelco Arcitec Electric Shaver -...
I have a Norelco arcitec 1050 electric razor and I have lost my instructions. What does it mean when the red light starts flashing (picture of razor heads)?
Means that the the replacement heads indicator flashing, it's time to replace new heads. That Norelco RQ10 heads for Norelco arcitec 1050 electric razorreplacement parts.
Aug 15, 2011 | Health & Beauty
Need instructions for changing Arcitec razor head
You look at Manual Norelco Arcitec Electric Shaver.
http://download.p4c.philips.com/files/1/1050x_22/1050x_22_dfu_aen.pdf
And you need to Norelco Arcitec Electric Shaver replacement heads is Norelco RQ10 shaving heads.
Nov 20, 2010 | Norelco Arcitec Electric Shaver -...
How to remove the blades on a norelco arcitec razor
On Arcitec shavers, the blades can not be removed from the head assembly. This makes it difficult to thoroughly clean them and they must be replaced reqularly because of this.
If needed, you will find replacements at shaveroutlet.com.. See link below
Nov 18, 2010 | Norelco Arcitec Electric Shaver -...
How long should heads last on Norelco Arcitec razor
Norelco suggests changing the shaver heads every 12 months for best performance. If you need to buy some, you will find them at shaveroutlet.com. See link below
Aug 20, 2010 | Norelco Arcitec Electric Shaver -...
My shaving Head has locked up. How do I replace the Blades or can i replace the entire head?
1. You cannot takes the individual heads off. 2.. You can use a stiff brush or toothbrush to clean the heads and then use an air compressor to blow the debris off of the heads at an angle. The heads will spin very fast and the debris will fly off. The rinse and spray a lubricant on them. 3. You can replace all the heads at once by pulling the whole head straight up off of the razor. Then buy a replacement head package and "click" it on the base.
Aug 05, 2010 | Norelco Arcitec Electric Shaver -...
My razor blade heads no longer rotate but when removed the mechanism underneath is spinning normally - the razor is clean and fully charged.
It sounds like your heads are damaged and need replaced. You can not repair theheads if damaged. You will find replacements for Arcitec shavers at shaveroutlet.com. See link below
May 06, 2010 | Norelco Arcitec Electric Shaver with Jet...
Norelco Arcitec Electric Shaver - Gray/Black Logo
394 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
