Question about Jenn-Air JCD2389G Side by Side Refrigerator
Drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
Water keeps leaking onto floor. had repairman out and he replaced condensor because refridgerator part stopped getting cold and frost built up in freezer. once he left we noticed water leaking and took off back freezer panel to expose coils. we saw a bunch of ice was building up on the inside coils and also iced up at the tube entrance at the lower part of the back freezer, that i assume leads to the drip pan. now, drip pan is full and keeps overflowing, even though the tube entrance is clear. how can we empty drip pan?
  • Anonymous May 20, 2009
    yes, but HOW do you remove the pan? that is the question
  • 585 Answers
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
Posted on May 20, 2009
  • 1 more comment
  • Bruce Volkers
    Bruce Volkers May 20, 2009
    The pan is usually accessed by removing the grille under the door(s). Plastic grilles usually just pull off, metal ones require you to depress the catches at the top openings on each side. The pan is plastic and rests on rails but requires some lift to get it to come out (that's how the mess is made). It's about 6 or 8 inches wide and the depth of the box from front to back. You could get the water out with an old turkey baster without the mess.
  • Bruce Volkers
    One more thing: rest assured that no matter what anyone else says, the defrost system is working, that's where the water comes from!
  • Bruce Volkers
    Bruce Volkers May 22, 2009
    Did you find and empty the pan?
    President:
  • 2,559 Answers
This is due to the fact the condenser was not bad,None of the symptoms you posted are due to condenser failure,But instead the defrost system failed.
Parts that should have been checked and replaced if needed are
  1. The defrost timer,
  2. defrost element,
  3. defrost thermostat
  4. condenser fan.
Water is dripping into pan under fridge and overflowing onto floor. looks like water is dripping from filter at bottom. what can i do?
Check to see looks like the container is already full. You have to remove the tray full of water and then insert it again. It will happen again and again ( overflowing water) so you need to periodically check the container pan if water is full.
Also by checking periodically that pan, you will minimize rust build up. You will need to wipe around it with soft cloth or rags so the body of your refrigerator will not decaying due to rust built up. This will destroy the metal parts of the fridge.
Good luck.
Jun 25, 2011 | Kenmore Side by Side Refrigerator
There seems to be a drip pan under the fridge, it is full of water, however i can not figure out how to get it out to empty it.It is overflowing an leaking onto the floor. What do you suggest?
If you have an automatic ice maker, turn off the water valve so no more water goes to the refrigerator.
If you don't have a water line to the refrigerator, the water is coming from all the humidity inside he unit. Normally, the pan is large enough so the humidity pumped out of the unit (as water) has time to evaporate and you never have to empty it.
For now, get a large terry-cloth towel and put it on the edge of the pan, the water will wick into the towel over time. You can also try a turkey baster to **** the water out like a syringe.
A few things cause excessive humidity in the unit.
1) Make sure the door is closed and you have no damaged seals all the way around the unit (check hinge side of door(s).
2) Do not leave open containers of liquid in the fridge.
3) Do not leave door on fridge open very long.
May 06, 2011 | Refrigerators
Drip pan is full and overflowing onto floor
If the temperture behind the compressor is not so hot the water will not evaperate. the heat from the compressor dry out the water.
Jan 03, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
A small amount of water is leaking out of the front of the refrigerator onto the floor every day and I can not fine the source of the water. Is there a drain pan and if so where is it? If it is not the...
older fridges drained water into a pan with the compressor in it, thus cooling the compressor and evaporating the water, this is located at the bottom back of the fridge. if this fridge has a water and/or ice dispensor, the water could be leaking from many a place.
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge 102H, R600a now about 12 yrs old leaks water onto floor. I have checked the outlet pipe from the fridge and the receiving dish. The pipe is clear. The receiving dish has water in it although it...
The pan will continue to have water in it. The defrost system water drips in the pan where it is evaporated by the condenser fan blowing on it.
Does this pan overflow? Is the water on the floor coming from this pan? Or could it be coming from the water inlet valve where the water supply comes in? Does the water come out the freezer or fridge door at the bottom?
Aug 25, 2009 | Refrigerators
Water leaking from freezer into fridge
there are several things to check for. The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. Some fridge's have a humidity switch inside the fridge that should be turned on to prevent sweating on the center bar between the fridge and freezer section. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchangertubing can separate and also sweat and drip on the floor. A kit to repair a separated heat exchanger line, comes with instructions as well. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
click this link for more help  http://www.applianceaid.com/refrigerator.html
Mar 31, 2009 | Kenmore Refrigerators
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Fridge is leaking water all over the place.
The defrost drain opening or drain hose is plugged up with ice or crud. If the drip pan is bone dry, it's a sure sign that the drain opening or drain hose is clogged. Trace the drain hose back to see where it pick up the condensate in the refrigerator cabinet. Remove whatever pieces you need to to clean that sucker out. Door gaskets are torn or not making good contact with the cabinet. No? Well then where's all that water coming from, Einstein? It can only come from the humidity in the outside air--your fridge can't make water, dontcha know
May 10, 2006 | Maytag MBF2256H Bottom Freezer...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
1,158 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
