Question about Kenmore Dryers
Kenmore 90 series dryer makes noise and does not want to turn. I can make it spin by hand holding the door switch in, grab it and spin it, and get it to spin again. It keeps doing the same thing when
Kenmore 90 series dryer makes noise and does not want to turn. I can make it spin by hand holding the door switch in, grab it and spin it, and get it to spin again. It keeps doing the same thing when it stops though. Sometimes it will just make the noise, and then shut off. I have to wait for it to reset, or something, and then I can try again.
  • 1 more comment
  • jergungarlan May 20, 2009
    Thanks for your response. I appreciate it. Too bad it was the motor. :-( Probably cheaper to buy another dryer than to pay someone to come out and fix it right?
    I was looking and new gas dryers are really expensive. I might be better off having the motor changed out......?
    I live in Dallas so, it's probably $400 around here. I'll see what I can find out. Thanks!
    Scholar:
  • 85 Answers
Your motor is worn out. Bearings worn and not enough power to start it. Motor is not repairable it must be replaced or new dryer. Sorry
Posted on May 20, 2009
  • shinn8
    shinn8 May 20, 2009
    New Dryer is probably the wisest way to go.
  • shinn8
    shinn8 May 20, 2009
    I would call around and get some prices then decide.... I usually charge around $180-$200 to change a motor but I am in a small town and that is probably low on the range of what you might be charged.
Kenmore 11062612101
From your description, the dryer belt could be in need of replacement. The burning smell could come from the motor pulley spinning and trying get a grip to turn the drum.
Dec 20, 2013 | Kenmore series 70 80 90 Dryer Motor...
My dryer makes a buzzing noise when i try to turn it on, but it won't turn on at all. What could the issue be?
The motors centrifugal switch may be stuck. Try having someone start it while pressing in the door switch while you rotate the drum with your hand by grabbing one of the drum vanes. I don't know which direction your drum rotates. Try both. This may start the drum turning on its own and resetting the switch.
Sep 20, 2011 | Kenmore 62722 Electric Dryer
Have a Kenmore 90 series gas dryer. When I press the button to turn it on, it makes a noise but won't start
Assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem. Check the blower fan and motor for any obstructions.
Jan 09, 2011 | Kenmore Dryers
Kenmore 90 Series, 10 years old; Dryer was making funny noise and stopped in the middle of a cycle. There was a burnt smell when it stopped. Cannot turn drum manually either. What are possibilities?
OF COURSE SOMETHING BURNT INSIDE THE SYSTEM. YOUR MOTOR MIGHT BE BURNT. 90 SERIES, YOU MUST HAVE THE LINT FILTER ON TOP CORRECT? TAKE FILTER OUT, UNSCREWS THE TWO SCREWS, PULL TOP PANEL TOWARDS YOU AND LIFT UP. DISCONNECT LID SWITCH CONNECTOR, UNSCREW TWO SCREWS HOLDING FRONT PANEL ON, REMOVE FRONT PANEL, TAKE DRUM OUT AND CHECK THE UNIT. GOOD LUCK
TIMOTHY DO 714-334-1998
Aug 04, 2010 | Kenmore Dryers
I HAVE A KENMORE 90 PLUS SERIES DRYER. IT DOES
check the door switch and also check the belt,if the belt breaks there is a switch inside that turns the dryer off
Mar 19, 2010 | Kenmore Dryers
Kenmore Series 90, just buzzes when you hit the start button even though the cycle dial is in the center. What's broke or what can I test?
It sounds like a defective motor. You may be able to hand start to confirm this. You will need another person for this. With cycle selected and door open, hold in door switch lever. Have second person press start button. While button is pressed, give the drum a spin by hand and see if it starts up. If it does you may be able to dry a load or two. The motor will need replacement.
May 10, 2008 | Dryers
Kenmore 90 series noise after spin
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
Oct 02, 2007 | Washing Machines
Dryers Logo
352 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
