Question about Graco Pack 'n Play
Pack and play bottom lock is hanging out - Graco Pack 'n Play
Items PY86992, how do u lock the short size?
Pack N Plays have a rule. The bottom floor MUST BE UP to raise OR lower the sides.
Raise the floor using the teather or round locking mechanism on the floor. Now raise the sides
up to locked position and then push the floor down. This is a safety for ALL Pack N Play play yards.
That should do the trick.
Apr 04, 2011 | Baby Gear
Cannot get the grayco pack and play sides and ends to raese back up
did you read the directions? the bottom part needs to not be all the way down when the sides lock open try and pull the sides up with the bottom not locked down then after the sides are up the bottom can be pushed down.
Mar 12, 2011 | Graco - Pack N Play with Newborn Napper -...
I have a pack and play that will not lock at the bottom and i was wondering if there was any way someone could help me
the center of the pen must be up the do the sides while the middle is up then push the center down.
Jan 26, 2011 | Graco Pack 'n Play
I cannnot get the gRECO PACK N play sides to stay up
I have the same one, its quite difficult.
It needs to click & lock in on both sides of the release buttons. Sometimes having somebody put their foot in the bottom of the play yard while you pull up on the release button will help lock it in.
You also need to have the shorter sides lock in first before trying to lock the longer sides in.
Oct 18, 2010 | Graco Pack 'N Play® Playard 9447mch
How do you put up a graco pack play
Hi, to set up the pack and play, first latch each of the four sides together. (Each side rail latches together in the middle -- just straighten the rail.) Once all four sides are locked and straight, push down on the center of the pack and play bottom (it's probably red) until it snaps into place.
To fold the pack and play up, just follow these instructions in reverse -- pull the bottom up first, then press in the button on each side rail to fold up each side.
Always make sure the pack and play is completely set up and locked before putting a child in it!
Aug 02, 2010 | Graco 9445DOH Crib
How do i get the sides to lock/ stay up on my Graco Pack and Play?
I think the problem is the way that the safety feature prevents the locking mechanism from moving while the bottom is flat Be sure that the bottom is raised about half way and the rails should lock (or unlock) for you. Hope that helps. wdeblancjr@aolcom
Jun 13, 2009 | Graco Pack 'n Play
I bought a pack and play at a rummage sale and
Believe it or not, the rails will not lock unless the bottom is slightly raised up. Then you can flatten the bottom. Unlocking works the same way, be sure that the bottom is lifted up partially. Hope that helps, I had the same problem.
Jun 12, 2009 | Baby Gear
Need help
Be sure that the bottom is not flat. The rails will not lock (or unlock) with the bottom flat. I great safety feature!
Jun 11, 2009 | Graco Pack 'n Play
Directions to set up a pack n play crib
you have to pull the sides up and lock them before you push the bottom down
Dec 27, 2008 | Baby Gear
Graco pack and play sport
I saw the solution on the Graco site. I was putting the bottom of the Pack and Play down first, I found out you need the do the sides firstl
Apr 27, 2008 | Graco Ultra Deluxe 5-in-1 4605 Crib
Graco Pack 'n Play Logo
49 people viewed this question
Top Graco Toys Experts
Shehu Pro
Shehu Pro
ray gallant
George Persico
George Persico
Are you a Graco Toy Expert? Answer questions, earn points and help others
