Question about Jl Audio 300/4 Car Audio Amplifier
JL 500/1 i have a JL500/1 I DONT NO HOW 2 FIX I CAN HOOK IT UP THE green light will come on i put the psitive speaker wire in then when i put the negative speaker wire n the amp it wont work unless i split the negative speaker wire n put half of it n the negative channel n half of it touchin the amp i really never herd anything like that
  • 631 Answers
It sounds like you have a broken output filter inductor in the amplifier. You should be aware that the speaker outputs of the amp are biased at ~40v DC and can give a good shock if you touch the speaker wire while you're grounded (touching the body of the vehicle).
When you connected the speaker as you did, I would have expected the speaker to move in or out and remain there while the wire was connected to the housing of the amp. I'll assume that the amp was screwed down to the chassis of the vehicle. If it wasn't, you may have more than one problem.
Posted on Oct 18, 2007
Wireing jl 500/1 to dvc sub
You will have to take a piece of speaker wire and put it from the positive of one voice coil to the negative of the other voice coil.....Then, with the other remaining positive and negative, hook it up to the amp.....And your good to go....If your still confused, get back to me....hope that helps.....
Mar 24, 2012 | Jl Audio 500/1 Car Audio Amplifier
I have two kicker cvr 12s how will I hook them up to hit the hardest with a jl audio 500/1
you would want to bridge them you take 2 pieces of speaker wire long enough to reach each sub and connect one side to the box and the other side of wire to the sub then you take your other speaker wire and hook it up to the sub you already hooked it to then run positive and negative to the other sub
Jul 07, 2010 | Audio Players & Recorders
Installin car systems
you dont want to connect both of those amplifiers together. You could run them separately to separate subs or the jl to your sub and your alpine to your front speakers. But you dont ever want to mix and match amps to the same sub. Even if you had 2 jl500/1's you wouldnt want to just hook them up together. Because they both have to be putting out the exact same amount of power. Which no 2 amps are ever exactly the same. Some companies make bridges to properly connect 2 exact amps together. I Hooked up 2 JL 1000/1's to each voice coil on a 13.5 W7 and i smoked the sub. So i definitely dont reccommend doing it unless the amps are conneccted to separate things.
Apr 28, 2010 | Jl Audio 500/1 Car Audio Amplifier
I hookd my jl 500/1 up i like it louddd but the bass goes in and out??? can you help .
is there a green light? does it go red? the unit could be auto-protecting from your speakers, are they old speakers?
Feb 07, 2010 | Jl Audio 500/1 Car Audio Amplifier
How do i wire a jl w3 to a jl 500/1 mono
wire the sub in series it will give you best bang
Mar 16, 2009 | Jl Audio 12W3 Car Subwoofer
500/1 problem
Hi i wish to help u but i will need more info on the type of subwoofers u want to use -are the DVC-or single ...are they 8ohm or 4ohm speakers?
Jun 22, 2008 | Jl Audio 500/1 Car Audio Amplifier
Jl 500/1
Nine times out of ten if the amp smells burnt it usuallly is. Your best bet is to hook another amp to your system and see if you get sound.
Jan 30, 2008 | Jl Audio 500/1 Car Audio Amplifier
My JL subs just dont beat like the ONES IVE HAD before as well as the ones my friends have had
sounds like they have your sub amp in mono but they put the speakers in series which totally cancels the benefit of running your amp in mono. you will probably be happier if you just hook the left speaker to left plus and minus and the right to right plus and minus. Cuz even though subs aren't directional they do pass some higher frequencies that are and that dilutes the stereo effect.
Jan 19, 2008 | Jl Audio 500/1 Car Audio Amplifier
Jl Audio 300/4 Car Audio Amplifier Logo
118 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
hoyzee1
Morne Olivier
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
