Question about Sony STR-DE935
Hi, I have a Sony STR-DE 935 and there's no sound that came out from the speakers as I open the unit I found two blown fuse and every time I replace the fuse and plug the cord the fuse blown right awa
Here's my email add. leunamme76@yahoo.com. I want to keep this receiver and fix it. Can anyone help me please. Thanks. Manny.
    Genius:
  • Sony Master
  • 1,054 Answers
There is a short in the amplifier that is causing the fuse to blow. Most likely shorted output transistors.
Posted on Dec 31, 2013
3 Suggested Answers
  • 118 Answers
SOURCE: I have a Sony STR-D965 receiver that has worked
its a common problem when the amplifier outputs are shorted and need to be replaced. put tinfoil on the fuses and watch it smoke
Posted on Nov 04, 2009
  • 652 Answers
SOURCE: Sony STR DE-445 unit powers up but no sound
Check the fuse, Sony is known for its random problems with sound. The one I have you must tap it on the side. Its a flicker switch inside.
Posted on Feb 14, 2010
Headphone jack on old sony amp silent
Maybe there could be a loose wire inside try taking it apart and searching for any thing loose do you have a warranty on it
May 06, 2014 | Sony STR-DE675 Receiver
No sound fuse replacement
checa el fusible de la are de sonido si no esta malo seguramente se dano el circuito integrado del sonido.
Dec 16, 2013 | Sony STR-DA2000ES Receiver
Sony STR DE835 receiver - no sound from speakers and headphone jack
The problem is in the audio output semiconductors, they have shorted causing the fuses to blow and it is in auto protect mode to prevent further damage. I recommend a professional to assess.
Mar 10, 2012 | Sony STR-DE835 Receiver
Feb 13, 2010 | Sony STR-DE445 Receiver
Sony STR DE 197 Reciever with No Sound
I have the same unit. My best recommendation would be to remove all speaker wiring, and try new wiring with another pr of speakers,since the "outdoor " speakers were rained on. the protect mode that the unit went into sounds like it did because the speaker outputs were shorted due to the rain, so ensure that the speaker output terminals are not shorted and dry...also see if output is still availalable at the headphone jack...if it is, the pre-amp section is still good , in which case the protect mode and no volume output out of the speaker jacks may mean that youve blown the ouput trasnsistor finals.
I hope this helps.
bobbymaximus
Jul 28, 2009 | Sony STR-DE197 Receiver
RECIEVER TURNS ON THEN OFF FOUND BLOWN FUSE STR-DE625
Disconnect all speakers, then test power. if it cuts off, your receiver needs serviced. If it stays on, Check all your speaker wires for shorts and connections at speakers. If they seem ok, re-install one speaker wire at a time and test power. once you find the speaker that's causing the problem, replace the wire and connect a different speaker (that you know works) and test again. If it cuts out, the problem is in the receiver and needs serviced. If it plays, put the original speaker on the new wire and test again, If it cuts out, it's a bad speaker or internal crossover depending on the model. Unless you are very proficient with a meter, this is the easiest way to check your connections. If you still have questions, post a comment and I'll help some more Hope this helps
Jun 23, 2009 | Sony STR-DE625
No sound out of left speaker
did the left channel work when u switched speakers, if so then the left speaker or wiring is a fault.if not then the output circuits on the amp are blown or the fuse is blown some amps have internal fuses in the output to protect the output transistors. unplug the power cord and take the cover off, look to see if u can find any fuses and check these for continuity u can hold these up to the light and u should see a fine filiment in one piece and not broken. these fuses sometimes blow just from age and use at high volume like a regular light bulb.If the fuse is blown replace with the same value else the output transistors will need to be replaced most likley along with the drivers.
May 19, 2009 | Sony STR-DE135 Receiver
No output on main speakers
I have experienced a similar problem with my Sony STR-GX57ES and took it to a certified tech only to find it needed the power supply replaced. I opted to hunt down a compatible power supply but have been unsucessful thus far. That being said I picked up an STR-D665 for next to nothing and found the power supplies to be quite different (you would hope so any, with the ES meaning Elivated Standard and all) but with the D665 working flawlessly I'd rather have something working than nothing. Good luck!
Dec 06, 2006 | Sony STR-D665 Receiver
Sony STR-DE935 Logo
159 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
