Question about SMC Computers & Internet
Limited access I have a smc barricade router 2804 I want to connect to the Internet and reads is limited I wanted to know how can I solve this problem
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
Easy put all settings on dhcp and reboot system
Posted on Dec 31, 2013
5 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: SMC barricade g and timing out
just a few things that can be checked, firstly in the routers settings look at the transfer speed of the router(not the connection speed) and see if it's set at 108MBPS, if so your wireless network cards on your pc's may only be able to connect at a maximum speed of 54MBPS, unless you have the latest 108 or 125MBPS g type cards. Secondly you should be able to check the wireless signal strength by the icon in your task bar or software you use, as if you have thick walls or objects in the line of the signal from router to pc's, the strength drops and can read low and therefore cause you to lose internet connection entirely. You can also try changing the channel at which the router runs, normally this is channel 2, but trying channel 11, which is the farthest away from appliance interference may give you better results, but both router and network card channel numbers will have to be changed.
Posted on May 13, 2007
marked
  • 6487 Answers
SOURCE: SMC Barricade g SMCWBRT14T-G router
You need to open the port that Utorrent is using check this link for the step by step way on how to do that on the utorrent and on the router http://portforward.com/english/routers/port_forwarding/SMC/WBR14T-G/Utorrent.htm
Hope that helps..............
Posted on Aug 08, 2008
  • 9 Answers
SOURCE: Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Posted on May 01, 2009
SOURCE: Need password for log in to SMC Barricade 7004 VWBR Router
The username could be: admin
and the password could be: passoword
the password could be: admin
Posted on Jan 01, 2010
I want to change my security setting on my network so that my psp will support it. How can I do it without the disk
Welcome to Fixya. To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.2.1 The Default password is smcadmin. Password is case sensitive. Click on Wireless and then select Security. You can now change the security settings of your router. You can also refer to the manual below.
SMC Barricade SMC2804WBR Manual
Thanks for using Fixya.
Mar 12, 2011 | SMC Barricade g SMC2804WBR Wireless Router
I have forgotten my password on my smc 7004vwbr and need help to reset
I assume this is your wireless KEY
The user manual is here http://www.smc.com/index.cfm?event=downloads.doSearchCriteria&localeCode=EN_GBR&knowsPartNumber=false&productCategory=1&modelNumber=955&partNumber=3552&downloadType=8&os=0
you can choose the exact model from here http://www.smc.com/index.cfm?event=downloads.searchCriteria&localeCode=EN_GBR&knowsPartNumber=false&productCategory=1&downloadType=0&os=0
You should be able to see how to view or reset the wireless password.
Connect your PC to the Router with a LAN cable:- You will need to login to your router- you do this by typing a number into a web browser, Internet explorer, is best as some routers do not work with other browsers The way to log into the router is usually to use the IP address, thats a number which will be in the manual - Page 29 on the manual (33 on pdf screen) To access the Wireless Barricade’s management interface, enter the Wireless Barricade IP address in your Web browser http://192.168.2.1. Then click LOGIN. (By default, there is no password.) Goto the wireless section - secruity and you should be able to see the KEY - IF its all * - the you can type in a newone
I would also remove the wireless profile from your PC - to do this have a read of this link. Remove the wireless profiles from your PC http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 25, 2010 | SMC Barricade 7004VWBR Wireless Router
Smc setup cannot be accessed but have network
login to your router and go to wifi and check for the mac address of your laptop, if its require to change anything do it according to it.
To know the mac address of your laptop go to command prompt and type --> getmac
Mar 11, 2010 | SMC Barricade g SMCWBR14-G (662698582192)...
No connection, cant install the software
You said that when you connect the computer to the modem, you get limited or no connectivity. make sure that your computer will be able to go online when you connect it the modem directly.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 07, 2010 | SMC Barricade 7004VWBR Wireless Router
Using the SMC100 Barricade as a Wireless Access Point
use the wrt310n router as the router for the internet (where dsl modem is connected) then just connect the ethernet port (not wan port or internet port) of the SMC to the ethernet port of wrt310n
Oct 31, 2009 | SMC Barricade SMC7404WBRA (SMC7404WBRA EU)...
How do I make my SMC Barricade router go to a startpage
It sounds like what you want to do is have your web browser display a page when you open it... this is called setting your home page...
If you use MS Internet Explorer then
1) Go to the tools menu
2) Go to internet options
3) at the top set your home page
4) Press apply and ok
5) Now press the home button - this is the page Internet Explorer will display whenever you open it
IF this helped you then please help me and vote kindly.
Oct 09, 2009 | SMC Barricade g SMC2804WBR Wireless Router
Problems with SMC2804WBRP-G not detecting/connecting with Windows Vista
i have a similar problem with SMC7904WBRA2 Barricade router. I can only intermittently connect from my Vista Home Basic PC to the router. Most times I am unsuccessful.
Feb 19, 2008 | SMC Barricade g SMC2804WBRP-G Wireless...
May 13, 2007 | SMC Barricade g SMCWBR14T-G Wireless...
How do I configure my SMC router for a DSL Internet connection?
* Check for restrictive Firewall settings. * Clear the cache of your web browser. * Try with a different web browser (e.g. Mozilla Firefox, Opera) * Try to access the router from a different computer.
Feb 19, 2006 | SMC Barricade Turbo Router
Computers & Internet Logo
46 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Larry Maranto
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
