Question about Flat Panel Televisions
Grey stripe on screen Hitachi 32ld7200 lcd
Hello, i have recently noticed a vertical stripe on my screen in the middle, it shows the picture fine but is just a bit lighter than the rest of the screen. Is there a part i can have replaced to sort this?
Many thanks.
5 Suggested Answers
SOURCE: brand new Vizio 42 in from Sams has a 5 inch vertical grey stripe from top to bottom-any help removing it?
take it back!
Posted on Jan 22, 2008
  • 440 Answers
SOURCE: Black Vertical Stripe
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
Posted on Feb 03, 2008
  • 10 Answers
SOURCE: Blank screen except for a vertical grey line through the middle
This is a lcd. there is no yoke. it's a bad panel.
Posted on May 01, 2008
  • 6 Answers
SOURCE: Vertical black bar down the middle of hitachi plasma tv
The tv is shot. This occurs when pixels on the top row of the screen break, which blocks current from moving through the rest of the pixels in that column. But don't worry this problem is common and is covered in your tv's warranty.
Posted on Jan 05, 2009
SOURCE: 6 equal white to black Vertical bars over picture,
my colour is green why?
Posted on Aug 31, 2010
0 characters
1 Points
5 inch wide blue vertical stripe on lcd
It can be but rarely the main board, most of these sets have either one or two boards that drive the image on the screen, different names like T-con or Y out etc. the right side board could be the problem or a bad connector or ribbon cable for that side of the screen unit.
Several possible cures and none are a snap to find in most cases.
Dec 06, 2012 | Toshiba 46LX177 46 in. LCD HDTV
Black Vertical Stripe Our Hitachi plasma TV has just started displaying a vertical black stripe about three inches wide right down the middle of the screen. This stripe comes and goes every hour or so,...
Feb 03, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Lcd half darker than the other
your always welcome here in fixya..
May 18, 2012 | Samsung Flat Panel Televisions
Black vertical stripe on screen
hello,if the stripe goes completely thru the screen top to bottom,you most likely have a defective plasma panel. Other instances will require substitution of the drive boards(c boards) and rarely the control board.
Jun 02, 2010 | Hitachi 55HDS69 55 in. Plasma Television
Hitachi 60v500 tv has split screen with white vertical stripe down side
Good Day, poandflo;
After removing the power from TV remove the back of the TV (bottom only): Repair: Re-insert PDM connector on both Main Digital module and Drive PWB.
Good Luck, big IRISH. ps. remove cables one at a time and plug back in ensuring that they are seat properly.
Aug 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
My picture looks like cartoon characters from new commercials
I had recently noticed the same thing happening with mine.Then the left half of the screen turned black and has various red, green, and blue vertical lines. The right half of the screen shows has the picture just fine. It's exactly right down the middle of the screen.
Nov 18, 2007 | LG DU-42PX12XC 42 in. Plasma HDTV
Flat Panel Televisions Logo
144 people viewed this question
Top Flat Panel Televisions Experts
Jaime Hernandez
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
