My motherboard doesn't specify input for computer case cables
My Motherboard does not specify where do the computer case cables from the front pannel goes on. I have managed to plug in the usb and audio but I am having problems with the other cables, CAN I GET SOME HELP PLEASE,,,and no I don't have a manual for my motherboard.
  • wcbzero May 11, 2010
    What is the make and model of your motherboard?
  • 3 Answers
First you need to know the model of your motherboard. Next visit manufacturer's site if can't find the manual, Google it.
Posted on May 20, 2009
Power supply diagram for ht 2000 motherboard
http://www.ebay.com/itm/ECS-HT2000-AMD-AM2-Socket-mATX-DDR2-800-Motherboad-w-NVidia-Graphics-/251260314586?pt=Motherboards&hash=item3a804823da
1) Uses one 24-pin ATX main power cable.
Motherboard installed in computer case, the motherboard connector for the 24-pin ATX main power cable; is to the Right of the Blue IDE (PATA) connector.
(Right side of motherboard)
General example. Note that color does NOT matter of connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
2) Uses one 4-pin ATX +12 Volt power cable,
Motherboard installed in computer case, the whitish square 4-socket hole connector, to the Bottom/Left corner of the Processor socket; is the 4-pin ATX +12 Volt power cable's motherboard connector.
General example. Note color does NOT matter of connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
THAT, would be considered a Power Supply diagram of the motherboard.
They are the only two power cables that plug into the motherboard.
The front of your desktop computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
Power On switch, Power On LED, (Light Emitting Diode), Harddrive activity LED, and a Reset switch IF used.
Regards,
joecoolvette
Apr 15, 2013 | ECS HP MCP61PM-HM Nettle3-GL8E 6150SE AM2...
Removing a Dell Dimension L600r Motherboard
Power unplugged from computer, and all cables;
1) Look at the back of the computer. ONE of the Side Panels remove.
There will be screws vertically along the edge of the Side Panel, that removes. Either Philips head screws you remove, or Thumbscrews that you just loosen.
Once screws are removed, or Thumbscrews loosened all the way, look for a bulged formation in the back of the Side Panel.
This is a fingerpull.
Pull back on the Side Panel. It may only pull back so far, then stop.
This is because the Side Panel has hooked tabs that protrude from it, and go into slots in the metal frame of the computer case.
The Side Panel is then slid forward a tiny bit, and removed straight out from the computer case. You have to get the hooked end of the tabs, to clear the slots in the metal frame.
STOP!
Now FOLLOW Anti-Static Precautions!
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer, and/or before taking any new parts out of their anti-static bags, or cartons.
Computer On a table, computer unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
I then lay the computer on a static free towel, on the table; and computer case opening -> UP.
Makes it SO much easier to work on.
2) Next remove all power cables going to the motherboard, and peripherals. (Harddrive, Optical drive/s, Card Reader, Floppy Drive, etc)
Flop, and/or tie the power cables out of the way, to the outside of the computer case.
If the Power Supply power cables are still in the way, remove the Power Supply.
Look around the outside edges of the motherboard, for motherboard mounting screws; and to the inside.
When removing the screws look to see if fiber washers are used.
Save these washers. The new motherboard may need them also.
(Rule of thumb is;
If the motherboard mounting holes have NO metal rings, fiber washers are used.
Metal rings? No fiber washers )
The motherboard is tilted up to remove. Tilted up on the OPPOSITE side of the I/O area side.
Input/Output area.
This is the area on the back of the computer, that the mouse, keyboard, monitor, audio cables, etc. is.
Components plugged in here plug directly TO the motherboard.
The metal shield that surrounds the I/O area, is the I/O Shield.
If installing a new motherboard, and it is not an original OEM motherboard replacement, use the I/O Shield that comes with the new motherboard.
That is; IF it comes with one; and IF it fits the rectangular hole in the metal framework; of the computer case.
Dell Support shows no documentation; and reviews are sparse.
WAIT, hold the phone!
http://www.ebay.com/itm/Broken-Dell-Dimension-L600R-MCM-Computer-Desktop-Parts-/140517075990
OH, I see now said the blind man!
The lever on the Top/Back is depressed, or pulled up on, or pulled back on. This releases the half side of the computer case; that removes.
Also;
The front of the computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front panel go to, is the Front Panel header.
Power On switch, Power On LED light, HarDDrive activity LED light, and Restart switch; IF used.
BEFORE you do ANYTHING, make notes, and a drawing as to what pins on the motherboard; that those wires go to.
I DO NOT have a pinout chart available for the Front Panel header.
Power cables from Power Supply I can guide you on.
For additional questions, (And I expect many), please post in a Comment.
Regards,
joecoolvette
Happy New Year to you, and yours!
Dec 29, 2012 | Dell (E210882) Motherboard
Proper installation of tower wires
According to Gateway Support, the Gateway 505GR desktop computer uses an Intel (Ausberg) 915G motherboard,
http://support.gateway.com/s/PC/R/3724/3724iv.shtml
http://www.ascendtech.us/itemdesc.asp?ic=MB4GWAUGSBURG
Scroll down to the photo with the sections marked in red.
In the top link, looking at the motherboard with the computer case open, the USB and Firewire (1394a) cables, can be seen attached to the motherboard near the letters D, E, and F.
In F that red cable is a SATA cable. One end attaches to the back of the SATA harddrive, (The angled end), and the other end of the SATA cable attaches to one of those SATA headers on the motherboard.
(SATA header = SATA connector on motherboard)
Preferred SATA header for the Harddrive is SATA 1.
DOESN'T matter though. That's the beauty of SATA. You can plug the SATA data cable into ANY SATA header on the motherboard, and BIOS will find the harddrive.
In the second link, looking at the motherboard photo shown, and comparing it to the view of the motherboard as mounted in the computer case, the Front Panel header is at the very Bottom Right.
Two rows of pins in a White rectangular shaped header,
(S points to Front Panel header)
[ The plastic front of a desktop computer is the Front Panel.
The area of pins on the motherboard, that the Front Panel wires go to, is the Front Panel header ]
A) Top row has Even numbered pins
B) Bottom row has Odd numbered pins.
http://www.intel.com/support/motherboards/desktop/sb/CS-009016.htm
1) Power LED = Power On LED light
2) Hard Drive Activity LED = LED light that flashes (Usually red in color) when your harddrive is active. Being used.
3) Reset switch = Reset Button. The Reset switch is behind the Reset button. (IF the computer uses a Reset switch)
4) Power Switch = Power On switch
5) Forget about Pin 9. That's for 5 Volts DC - Out. Used by factory.
Which wires coming out of the Front Panel, are the Power On wires, Harddrive LED light wires, Power On switch wires, etc.?
Remove the Front Panel, and trace where the wires end.
IF, the wires already installed coming from the motherboard to the Front Panel, are Too short, you should make notes before you remove them from the motherboard.
Note what color pair of twisted wires, went to where, in the Front Panel.
Compare to the chart of the Front Panel header given above.
(IF any wires are still connected to the Front Panel header on the motherboard)
Once the Front Panel is removed, it's usually pretty easy to trace the two wires up to the Power On switch.
Same for the Power On LED light.
Again, same for the HarDDrive activity LED light.
The SATA harddrive requires a DATA cable, and a SATA power cable.
The connector for a Data cable has 7 contact pins. It is the shorter connector.
http://en.wikipedia.org/wiki/File:SATA_Data_Cable.jpg
The connector can be at a 90 degree angle as shown, or a straight connector.
IF the data cable has an angled connector, it plugs into the Harddrive.
Straight connector goes to the motherboard.
The connector for a SATA power cable has 15 contact pins. It is the longer connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Note the L shape of the connectors for the SATA data cable, and SATA power cable.
Also;
This is a 4-pin standard Peripheral power cable. Commonly misnomered as a 'Molex' power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
IF, the SATA harddrive has a provision for a SATA power cable, AND a 4-pin standard Peripheral power cable, ONLY use just the SATA power cable.
Using both power cables will burn up the harddrive.
May not happen immediately in some cases, but WILL eventually happen.
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 17, 2011 | Gateway 505GR PC Desktop
I cant find the case wireing connections on the motherboard led hhd rw led power and sound were do they go ...and can u send me a pic of how the wires look and were they go thanks
from the Compaq case / cabinet front pannel a single connector will connect to the board.
there will be set of pins / connector with mark" pannel SW / " on the board
It may not mention each seperatly.
May 19, 2011 | Compaq (277500-001) Motherboard
I have P5KPL-AM/PS motherboard. How can i activate my audio front pannel
First of all check if your front panel is connected via cables to motherboard. I am biding that is not connected.
Oct 30, 2010 | ASUS P5KPL-AM SE Motherboard
How to connect front usb to motherboard
First need to check front usb cable attached on mother board usb plug or not if its not attached so plug in to this pannel and then after you can access it.
May 09, 2010 | ASUS P5PE-VM Motherboard
I have a p3 computer but i can't understand how will be front pannel connection setup in mother board
If you have the manual for the motherboard you'll find how to connect the front panel jumpers from you're case. Provide the model number of the MB and I'll be able to help you further. The model number should be marked on the MB.
Apr 09, 2010 | Intel Motherboard
I have installed windows 7 series now my
Your front audio panel needs motherboard or computer case specific drivers.
Go to the manufacturers website and get the board or chipset drivers that are compatible with Windows 7.
Mar 16, 2010 | Intel DG43NB Motherboard
Front pannel connection regards
there are small input adapters lying unused in your cabinet.just connect them to the incoming adapters and you are done.
Oct 24, 2008 | Mercury P4VM800M7 Motherboard
USB
The USB ports on the front panel allow convenience for devices which you might connect and disconnect from time to time (like portable media card readers for example, or USB-camera cables) so you don't have to reach to the back of your case. If you are going to use the front panel USB ports, make sure they are connected to the motherboard inside if you are not using a store-bought computer.
Let me know if that answers your question.
Jan 11, 2008 | Zerus Intel Desktop Board D815EEA...
Computers & Internet Logo
194 people viewed this question
David Payne
David Payne
