Question about Boating
Mariner 40 hp outboard
No spark on one motor. Tried switching all electrical components with running motor. right down to the stator and fly-wheel. Still have no spark. What next?
    Sergeant:
  • 456 Answers
Faulty kill switch faulty ign switch,how old is motor,is it electric start,isit ayamaha mariner or mercury mariner,if Yamaha disconnect white wire from cdi
Posted on Dec 31, 2013
5 Suggested Answers
muffteck
  • 202 Answers
SOURCE: 25 hp mariner outboard runs ok for 2klm then
does it have the old type timming advance (non adjustable) get it timming through the cd switch. if so could be this but o/b man should have ched this change your gas hose and pump bulb if you sure no electrical problems
Posted on Mar 16, 2011
alicantecoli
  • 22246 Answers
SOURCE: mercury outboard 3.5 motor stalls
not sure here as i normally answer car questions but if this engine is of the new generation and its all electronic then it has to be plugged in to locate the fault .My outboard was playing up like this with loss of power and the dealer wanted a small fortune to repair the pump which feed the fuel injection system so i took it apart and made a new valve for it out of a piece of fishing hook plastic wrapper and a bit of copper wire hook type thing i made and that was about 5 yrs ago and its still running fine
Posted on Apr 13, 2012
goldbill
  • 184 Answers
SOURCE: 1977 9.8 hp Mercury Outboard Motor Serrial # 4605112, it's an electric start with a short shaft
put it in forward gear. Drop the lower off by releasing the bolts and nuts holding it holding the lower on. (one is hiding under the back pick up screen)- some models had a plug in the back top of the exhaust/intermediate housing hiding an allen head bolt pointing down.
Once released, put a protector in a vise and clamp the lower to the bench.
2 screws or bolts will hold the water pump cover on. (the drive shaft runs thru it) Clean the carbon and rust off the drive shaft will allow the pump housing and impeller off the lower. Retrieve the funny looking key drive which runs the pump.
Inspect the shaft, the lower unit oil for water. and find all the pieces of the water pump impeller which may have gone places they shouldn't have.- including the outlet tube from the power head. Check this by putting a tube on the end and blowing- you should hear and feel the pressure in the exhaust and tell tale hole.
Now take the model number , the old pump parts to the marina for a replacement. Do a side by side comparison at the marina so you get the right stuff. Check the inside drive of the rubber impeller and see if they are exactly the same.
NOW- put the new wear plate / gaskets and drive key on, hold in place with grease. Slide the impeller on the key and spin the drive in both directions to be sure it has the impeller and will securely turn it.
Put grease in the cup of the pump housing to prevent dry start and help seat the impeller blades. Spin the shaft as you lower the housing in the pump so the blades all face in the right direction (clockwise). Screw in the bolts. Grease up the seal the watertube goes in and the spline end of the drive shaft.
Up the hole it all goes, now you only have to spline the shifter (it hasn't moved has it?) The drive shaft and the water tube all at the same time.
Check the shifter for correct position and bolt it down
Posted on Jul 29, 2012
rilaxson
  • 456 Answers
SOURCE: suzuki outboard motor dt 28 will not spark
Have you checked the kill switch,make sure all earths are grounded
Posted on Dec 03, 2013
What parts are needed to make manuel start outboard to electric? Evinrude 30 hp.1986 mod#E30RCD
Evinrude MIGHT sell a conversion kit call a reputable dealer.
Jul 24, 2017 | Boating
Why wont my 50 hp mariner start ?
renew spark plugs,mix up some fresh fuel,put choke on,throttle set at just above idle,pump up fuel bulb by hand till tight,put outboard in a water drum,try pulling or turning on starter till it fires,then push choke in and restart
Jul 25, 2014 | Mercury Gear Set, Complete, Mariner, Force...
Why won't my mercury marine engine not restart after running for 30 or 40 min.
is it cooling ok ? run on hose and check engine block and exhaust plate cool ! water inlets clear and impellor good condition ? compressions all over 100psi ? carbs clean ?
Jul 23, 2014 | Clymer Mercury/Mariner 75-225 HP 4-Stroke...
W55M Mariner Outboard wiring problem
this is the only site i could find with a wiring code, now i'm not sure it is right but let me know and i will see if i can find something on some of my old papers. but will need the serial number.
http://www.maxrules.com/fixmercwiringcodes.html
May 24, 2013 | 2003 Chevrolet Cavalier
Carburetor runs too rich
sounds like you need to get the carburater cleaned and install a new set of spark plugs
Jul 08, 2010 | 2003 Mercury Mariner
1993 40 HP 4 cyl. Mercury outboard: Running along
I solved it with no help from the professional assistant team. Thanks for no help till I send money...DON'T THINK SO!!! Thanks for wasting my time.
Sep 03, 2009 | Boating
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
1974 60hp johnson outboard won't run on full throttle under load , max 10%. New fuel and filters ect. The motor is old but has very low hours.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Apr 12, 2009 | Boating
Boating Logo
158 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
