Question about New 2006-2010 Chrylser 300 Chrome Grille Oem Mopar
IMPLAUSIBLE FUEL VOLUME SIGNAL RECEIVED - New 2006-2010 Chrylser 300 Chrome Grille Oem Mopar
    New Friend:
  • 26 Answers
Fuel pump weak...
Posted on Dec 31, 2013
After replacing a fuel pump on 2006 jeep liberty 3.7 code U1411 is showing. How serious is that?
Here is what the troubleshooting guide says:
WHEN MONITORED
Ignition on.
SET CONDITION
The fuel volume message the PCM is receiving is implausible. The circuit is continuously monitored.
POSSIBLE CAUSES
  • CAN B open or shorted
  • Cluster module
  • Front control module
  • PCM
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding.
Theory of Operation
The Front ControlModule isn't receiving a fuel volume signal over CAN B from the ClusterModule. The FCM has to send the PCM a fuel volume signal over CAN C. The signal the FCM sends over CAN C is implausible.
DIAGNOSTIC TEST
1. ACTIVE DTC Ignition on, engine not running.
With a scan tool read DTCs.
Q: Is the DTC active at this time?
YES: Go To 2
NO: Refer to the INTERMITTENT CONDITION Diagnostic Procedure. Perform the POWERTRAIN VERIFICATION TEST.
2. CAN B BUS HARDWARE DTCS ALSO ACTIVE
With a scan tool check for DTCs in the FCM. Q: Are any CAN B Hardware related DTCs active at this time?
YES: (Refer to 8 - ELECTRICAL/ELECTRONIC CONTROLMODULES - DIAGNOSIS AND TESTING) for the appropriate diagnostic procedures. Perform BODY VERIFICATION TEST - VER 1.
NO: Replace and program the Powertrain Control Module per Service Information. Perform the POWERTRAIN VERIFICATION TEST.
Sorry, but it looks like it could be a computer problem.
Nov 14, 2017 | Jeep Cars & Trucks
2006 Jeep Grand Cherokee U 1411
05 WK jeep in usa?
no engine stated, of like 5 used world wide, tuff no>? hard row to hoe....
ill guess 3.7L
u1411
the book is posted here 300+ times
here we go 1 more time,
the SM is clear, on all codes. read them first
then ask questions on tests no clear
the PCM is not artificial intelligence yes, all the pcm does
is run tests, and tells you what tests is failing
like your dr. says, your red blood count is low, same deal
more tests for the same reasons....
U1411-IMPLAUSIBLE FUEL VOLUME
SIGNAL RECEIVED. . . . . . . . . . . . . . . . . . . .9-1118
all this is in CHAPTer 9
The Front Control Module isn't receiving a fuel volume signal over CAN B from the Cluster Module. The FCM has
(means data is corrupted or out of valid range)
try using a real scan tool this time
and forget that cluster toy
the the cluster is like the tip of and iceberg, x10 worse.
click wk and only in USA, ok
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
the whole ****** book in one DRINK (love it)
Feb 26, 2017 | Jeep Grand Cherokee Cars & Trucks
ENGINE LIGHT IS ON AND CHECKED IT WITH A CODE MACHINE AND THE CODE IS U1411 U1403
OP: Posted by Barbara Frye on May 11, 2016
Barbara. get car serviced? at an ASE shop or dealer?
you cant fix this lacking tools, ill not try to guess.
did you first erase those errors (push reset on tool)?
and see if they return, ???? this is first.
have you had work on the pump/tank area.
in a collision?
here is why.
first check fuses. any blown.?
then do the cluster self test, no tools needed.
posted here 100s of time, need that?, or the free link to the test in the FSM book? posted that too 100s of times here. (ask or search)
next is scan it, see all errors, not just the 2 you see now.
a real scan tool shows all errors and for sure those that might be related, and any CAN-BUS errors.
a real scan tool can see all JEEP extended DTC errors.
also post if the instrument cluster is acting odd. in any way.
does the fuel gauge work? can you tell?
needle steady and correct for reality,
QOD: questions of the day,
does engine run?
does car drive, correctly day and night with bright head lights?
does any other feature of the car fail. any at all.
no charge lamp failures in cluster, nor volt meter below 14v in the cluster meter of same name (volts)???
1411
Theory of Operation
my guess is 1403 is the real error. (primary)
the fuel sender might be glitching,
here is that sensor,
in the tank , part of pump, part of fuel rack. in tank.
May 11, 2016 | 2007 Jeep Grand Cherokee Overland
Answer u1411 report jeep 5.7 grand cherokee
Implausible fuel volume signal received that is the meaning but don't know what that means
Apr 24, 2015 | Jeep Grand Cherokee Cars & Trucks
What U1411 code means?
U1411 Implausible Fuel Volume Signal ReceivedPossible Causes Setting Conditions
CAN 'C' Bus circuit is open or shorted to ground
Cluster module has failed
FCM has failed
PCM has failed
Key on or engine running; and the PCM determined that the Fuel Volume signal it received was implausible.
This code sets in 1 Trip(s).
This code will turn on the MIL (Malfunction Indicator Lamp) Vehicle Application: 2005 Jeep Grand Cherokee Laredo 4.7L, Vin N, Eng Cfg V8
Customer Concern: Has 11 codes. U0101, U110C, U0121, P0480, U1120, U0103, U1411, U110E, P000B, U0100, U0002. At this time there is a no crank condition.
Tests/Procedures: 1. Clear the codes and see what comes back. These are all communication codes.
2. Disconnect the modules one at a time when it is acting up and see when the communication comes back.
Potential Causes: Controller Area Network (CAN) C Module
Tech Tips: On this vehicle it turned out the Occupant Restraint Controller (ORC) which is on the Controller Area Network (CAN) B bus was actually causing the problem. It was also taking down the Controller Area Network (CAN) C bus at times. I hope this helps.
Apr 01, 2015 | 2006 Jeep Liberty
Code u1411 jeep liberty 2006
wow , no engine options stated, or type of driveline.... wow.
this is covered in the FSM, read that.
it states
U1411-Implausible Fuel Volume Signal Received that means to get the car fully scanned,
using a real scan tool that sees all 2006, jeep DTC errors.
including BCM codes.
the manual tells you what to do.
here is just small expert from the Factory.serv.manual
quote
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING)(Refer To List 1).
Theory of Operation
The BCM has to send the PCM a fuel volume signal over CAN C. The signal the BCM sends over CAN C is implausible.
Diagnostic Test
1. ACTIVE DTC
Yes
  • Go To 2
No
Refer To List: 2. CAN C BUS DTCS ALSO ACTIVE
With a scan tool check for DTCs in the BCM.
Are any CAN C related DTCs active at this time?
Yes
  • (Refer to 8 - ELECTRICAL/ELECTRONIC CONTROL MODULES - DIAGNOSIS AND TESTING) for the appropriate diagnostic procedures.
  • Perform BODY VERIFICATION TEST - VER 1. (Refer to 8 - ELECTRICAL/ELECTRONIC CONTROL MODULES/FRONT CONTROL MODULE - DIAGNOSIS AND TESTING)
No
that word CAN , means the vehicle network communications buss called CAN.
if the PCM can not TALK to the BCM. this can cause the
data to be wrong. and the
Implausible , data.
greek ,huh,
get it serviced by any ASE shop in town or if desperate JEEP.
Oct 03, 2014 | 2006 Jeep Liberty
What does u1411 mean
U1411 - Implausible Fuel Volume Signal Received
Theory of Operation
The Front Control Module isn't receiving a fuel volume signal over CAN B from the Cluster Module. The FCM has to send the PCM a fuel volume signal over CAN C. The signal the FCM sends over CAN C is implausible.
Possible Causes
CAN B OPEN OR SHORTED
CLUSTER MODULE
FRONT CONTROL MODULE (FCM)
POWERTRAIN CONTROL MODULE(PCM)
Jul 30, 2014 | 2004 Dodge Durango
What is code u-1411
u1411-Implausible Fuel Volume Signal Received
1st google hit.
use google to see others with this error, read that and then ask questions.
this engine has a fuel basket ( you need to learn that first)
how that works , compared to the loop system.
Nov 03, 2013 | 2006 Jeep Liberty
I have a 2005 Jeep Cherokee Laredo. Diagnostic
This usually points to a bad PCM (powertrain control module).
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Sep 14, 2009 | 2005 Jeep Grand Cherokee
New 2006-2010 Chrylser 300 Chrome Grille Oem Mopar Logo
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
