Question about SNK Magnavox 32MD357B_37 32 in. LCD HDTV/DVD Combo
Tv dvd combo standby light and dvd - SNK Magnavox 32MD357B_37 32 in. LCD HDTV/DVD Combo
My friend took out the dvd player so the light stay on an when i tuurn it on it waits a sec then does red then green screen an goes to standby
The TV is indicating that a part of it is not working, like the dvd player that is missing. Modern electronics go through a set of tests and if a fault is found the stop working. Replace the dvd player, or get the set to a repair shop.
Apr 30, 2015 | Emerson LD190EM1 19 in. LCD TV/DVD Combo
More detail --- Toshiba md20q42 tv/dvd combo not powering on, initially when it happened i Hit power button and lite came on and blinks for about 3 seconds then turns off--- now when i push power button...
Hi
It is probably a power supply problem associated with standby circuit. If this circuit is bad the set hardly comes on and fails. This is a task for a technician to trace the fault through the whole power supply.
Sully
Sep 22, 2013 | Toshiba MD20Q42 20" TV/DVD Combo
I have a sanyo 31.5 tv dvd combo when pluged in the red light appears but does not turn on no green light
No green light means set is in standby because it cannot make it on.
Either a short or a open exists.
On Combo units it can also mean the mechanism for the DVD is jammed etc.
Apr 03, 2012 | Sanyo Televison & Video
I just got a new TV and when I hooked up our DVD Vcr combo it would not play the DVD. The standby button is on
The machine has a power supply problem, usually a filter capacitor that is open causes the issue. But just to check, unhook the cords from the new tv, now turn on the dvd/vcr combo to see if it will power up, if it does please let me know, if there is no change you will need a shop technician to check it.
Jan 09, 2011 | RCA DRC8300N DVD Recorder/VCR
TV/DVD unit locked in Standby mode
Did you check the casing for a reset button (sometime it an itty ***** hole)
Hope this helps
Trap
Jan 25, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
RCA D52W136D 52 in. TV/DVD Wont turn on
Does the standby light flash in a set pattern? Some tv have a error code system which pinpoints the fault by flashing the standby light a certain number of times. Other than that my best guess would be a fault on the power supply or a fuse blown internally. Good luck.
Apr 08, 2008 | RCA D52W136D 52 in. TV/DVD Combo
TV in standby mode
Hi iducher the tv power supply is faulty have a tech repair your tv.good luck
Apr 26, 2007 | Supersonic SC-999TDVD 13 in. TV/DVD Combo
Toshiba MW24FM3 24 in. TV/VCR/DVD Combo
A common problem with this model are leaky transistors in the relay drive circuit that powers on the TV. That is electrical leakage, not anything physical you can see. The transistors should be labeled Q1701 and Q1702, and would have to be replaced by soldering, so a trip to a repair shop may be necessary. The DVD uses a standby power supply I believe, which is why it appears to work OK.
Feb 11, 2007 | Toshiba MW24FM3 24 in. TV/VCR/DVD Combo
SNK Magnavox 32MD357B_37 32 in. LCD HDTV/DVD Combo Logo
Top SNK Televison & Video Experts
matt martin
matt martin
Are you a SNK Televison and Video Expert? Answer questions, earn points and help others
