How to unlock HT-E320 - Audio Players & Recorders
Mercedes e320 stuck in park
With most cars that use keys, the key must be turned to unlock the shifter and steering column.
Jul 17, 2014 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
My alarm wont lock car and car wont start E320 1998
may be you should make a diagnostic and you can do it in a garage or you can do it by yourself if you want to do it by yourself you need some tools and you can find some good ones here: chinasinoy.com
Apr 02, 2013 | Cars & Trucks
Unlock code for acer e320
Hi, You can get the unlock code for an ACER LIQUID EXPRESS E320 from www.unlocking4u.com/acer-liquid-express-e320/rs6wp9/ at affordable cost.
Here are the steps for unlocking an ACER E320,
1. Switch on your Acer Liquid Express E320 with a NOT ACCEPTED* SIM Card,
2. The Acer Liquid Express E320 will prompt you to enter the Unlock Code,
3. Enter the Unlock Code and press OK.
Sep 10, 2012 | Acer liquid express e320 unlocked gsm...
2004 E320 FOB replaced battery doors will still not lock/unlock
have you re programed it there is a system for each car my friend had to go to main dealer to get his focus pad sorted
Aug 24, 2012 | Mercedes-Benz Cars & Trucks
E320 key won't start 1st try
It is a key issue most likely, try unlocking the car and taking a little more time to insert key into igniton than you normally do to see if that works. It can be a coding/timing issue in the anti-theft logic and most times replacing the key is all that is needed. otherwise it is the EIS acronym for electronic ignition switch which is a major control unit for the starting and anti-theft system.
May 17, 2012 | 2005 Mercedes-Benz E320 Sedan
2005 Merceds E320 wont start
Did you try starting it in neutral? There is a safety interlock for starting the car in park or neutral. Have them check that.
Jul 28, 2009 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Samsung HT x20 region code
For Samsung HT-X20 the region code unlock listed workd perfectly. Just hit 8,4,2,6,9 then ENTER (do this twice) and it will play your DVD which it did not before.
Abe
May 11, 2008 | Samsung HT-X20 Home Cinema 600W Theater...
24 people viewed this question
 Grubhead
Grubhead
