Question about Kobalt 350 ft-lbs Air Impact Wrench SGY-AIR134
Kobalt 350 impact runs without trigger pressed
    Habit-Forming:
    Scholar:
  • 102 Answers
Sounds like a problem with the throttle valve.
you will have to remove the air inlet (item# E) then pull the spring out (item# 37) and look to see if you find any foreign objects, if not the proceed to pull the throttle valve (pin cover) (item# 37) and check the seal (item# 34) for wear.
Follow this link for the parts manual:
http://pdf.lowes.com/useandcareguides/879686002796_use.pdf
Posted on Aug 26, 2014
Fixing a trigger on an old impact wrench.
You will need to find a spring for the trigger, parts are hard to come by new unless it is a Snap-on or MAC brand.
Sep 07, 2016 | Impact Air Tools & Compressors
Kobalt 1/2in air impact wrench will not take off any nuts. It will hammer 1 or 2 times then air will by-pass out the exhaust. It works good putting nuts on.
Make sure that you have 90 psi of supply air. If you are not running an inline oiler run some air tool oil through the gun.
You could even try running some gum solvent through the gun to clean it. If it still does not work you may have to replace the two o-rings and bushing on the reverse switch shaft.
May 22, 2015 | Impact Air Tools & Compressors
Ir 231G 1/2 impact runs w/o trigger pressed
Mine does the same after trying to break some over tightened lug nuts. Did you ever get a solution?
Aug 03, 2013 | Ingersoll Rand Tools & Hardware - Others
STUCK TRIGGER
The I.R. 2135Ti or TiMAX has some known issues with the trigger o-ring (item# 22A) swelling, the throttle valve (item# 28D) bending or breaking, and the throttle valve seal (item# 28E) wearing out or deteriorating. Procedure wise you should not be able to remove the trigger without first removing the inlet bushing assembly (item# 26) the reason is that the reverse valve (item# 24) keeps the throttle valve from tipping forward and releasing the trigger, there is a slot for the stem of the throttle valve to slide into.
Follow this link to the parts list:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45534070_ed3.pdf
When reassembling the tool first install the inlet bushing assembly and then install the trigger, make sure to lube the o-ring before inserting.
Oct 17, 2012 | Ingersoll Rand 2135Ti Air Impact Wrench
I have a craftsman model 919.165300 compressor 5 hp 30 gallon.It runs it builds pressure and shuts off like its suppose to. The problem is when I attach my impact wrench to the airline and press the...
first I hope that you drain the water out of the tank regularly. It seems as though you might have an air hose collapsing but in any case there is something apparently restricting air flow too the gun. try opening the petcock and see if you have steady air discharge or not and if you have another air hose try it. Also, are coming directly off the compressor to the tool or do you have an oiler or drier in line? if so, eliminate the accessory. Let me know how you do....I'm curious.
Feb 17, 2011 | Craftsman Air Tools & Compressors
Kobalt air compressor starts and stops after maybe a second or less. Need to reset my wall outlet every time it stops.
sounds like it is drawing too much power. either the breaker isn't sized correctly or the motor has a bad winding causing it to draw too much amperage. remember, electric motors draw up to 3 times the juice briefly when starting up
Aug 07, 2010 | Socket Communications Decal For Kobalt...
My air impact runs without squeezing the trigger.
if u take the tail outa ur gun u will see that da gause filter inside has broke up.it gone inside and holding da valve open pick it out wit a seal pick r somethin
May 27, 2010 | Ingersoll Rand Air Impact Wrench 1/2in....
Throttle valve is rotten and tool runs when you plug in the air without pulling trigger
there is a neoprene O ring in the trigger area ,that breaks down ,it needs a service by an air tool repairer ,it is not expensive. dont use wd40 or the like if dont have airtool oil use auto transmission fluid and this wont happen too often
Oct 18, 2009 | Craftsman 1/2" Impact Wrench
Air Wrench Question
An impact wrench works in the manner suggested by the name of the tool: through the principle of impact. In order to understand how an electrical or air-powered impact wrench works, it helps to know first how a manually powered impact wrench operates. A manually powered impact wrench looks like a fat screwdriver; on the end where the screwdriver blade normally goes, you can snap on screwdriver bits or sockets.
Aug 27, 2008 | Ingersoll Rand 271 Super Duty 1 Inch...
Kobalt 350 ft-lbs Air Impact Wrench SGY-AIR134 Logo
237 people viewed this question
Top Kobalt Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Kobalt Air Tool and Compressor Expert? Answer questions, earn points and help others
