Question about Samson R21 Professional Microphone
I dropped my mike (not a a big fall) and now it doesn't work.Help
I plug it in and nothing happens. I have 2 more mikes with the same story. The hit was so minor that I can't believe they don't work. Can they be salvaged? I have like $550 invested in somethin useless that I want to fix myself. Is it worth the effort?
I don't want to take them to a shop that is going to charge their price in eBay or a pawn shop.
How do I do it?
I have a multitester (volt meter) and soldering gun.
    President:
  • 1,138 Answers
Mikes are very fragile things and if you consider that the wire on the diaphragm is hair thin then you will understand that when dropped it will break easily. Also the magnetic field of the magnet is distorted by the impact. If you can get the wiring connector apart where the mike cable plugs in try testing for continuity on the 2 wires coming from the cartridge. Use a high resistance reading and work downwards. If you get nothing you will have to decide whether you want to replace the cartridge or buy a new mike. Sorry for your bad luck. I have 2 AKG mikes circa 1966 that it happened to that I still keep as a reminder.
Posted on May 23, 2009
Ho introduced John Watson to Sherlock Holmes?
Mike Stamford - The entire episode is based on the first Sherlock Holmes story, "A Study in Scarlet". Mike Stamford is an old friend of John's, and when John tells him he is in need of a roommate to share the rent with him, Mike introduces him to Sherlock Holmes, who is also in need of a roommate.
Sep 04, 2016 | Sherlock (2010)
I have a 2003 ford windstar and it vibrates profusely after 40 mph what can I do to resolve that problem, thank you very much for your help
you need to get your front wheels balanced mate the imbalance on the front wheels can be caused by a twisted tyre or simply the origanal balance weights falling off
let me know if this helps
cheers big mike
Jun 11, 2011 | 2001 Ford Windstar
My thompson modem is making klicking sound some times
we will not be able to help you since there are tons of possible reasons.
Grab it, shake, hit twice, sit and maybe it will stop (seriously, my cellphone wasn't running for 2 months, I was taking it to cell phone service when I was in food bar I took out my coat and phone drop out from pocket hitting the ground. It started working!)
Cheers,
Mike
Leave rate if I helped you, thanks!!
May 08, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
Cobra 29 nw when you key the radio the swr meter doesnt move and if you move the swicth to cal you can adjust it with out keying the mike but has good recive any help would be good thanks dwayne
To check the SWR, you put the swicth on CAL and key the mike with mike gain turned down all the way,then calabrate it to the meter on the CAL scale,then swicth it to SWR before you unkey the mike, then what ever the needle falls back to, that is your SWR reading.
Apr 26, 2010 | Radio Communications
I have a cordless mini optical mouse. i can't get it to work. it's about 2 years old. i plugged the thing in the USB drive and nothing happens. HELP!
Hello there:
first have you tried to use it on any other computers to see if they will recognize it? Also you may want to try a different usb port and see if that will help. if not you may have to totally reinstall the drivers from the manufactures website there may even be a up date for the mouse there ok also make sure that if the mouse has batteries make sure that they all are making good contact.
best regards mike
Aug 17, 2009 | Logitech Computers & Internet
Same here david! ARCHOS DVR STATION GEN 5 REMOTE NOT WORKING
Hi g tongsonmy name is Mike Houston of DISH Network and I was going over your post and seenwhere your Archos DVR is not working with the remote. If your Archos is sync tothe DISH Network receiver and all the functions still are not working you willneed to call Archos and I will give you the number. Archos (Pocket Dish),8773008879
Jun 21, 2009 | DISH Network ViP622 DVR DTV Receiver /...
External mike doesn't work
I'm assuming you have Windows Vista. If so, you may need to change the default microphone, particularly if you have a built-in microphone on the computer.
1. Right-click the speaker icon next to the clock in the system tray.
2. Select "Recording Devices"
3. Select "Microphone" or whatever item you want to record with.
There will be a VU meter showing the input level. Try talking into you mike and see if the VU meter goes up. If so, you're good to go.
If not:
1. Click the "Properties" button in the screen mentioned above
2. Move the "Volume" and "Boost" sliders up.
3. Click "OK."
4. Check your VU meter again.
If this does not work it is possible you selected the properties for the wrong device. Click on another device and repeat the last 4 steps again.
Jun 02, 2009 | Dell Inspiron 9300 Notebook
Kenmore 80 series dryer will not turn on
check the door switch,also you can remove the back and check the main white fuse,i think it's one of the two-mike
Feb 27, 2009 | Kenmore 65924 Electric Dryer
Yamaha Keyboard Microphone Not Working
Hi Simon. Has the cable to your Mike been trapped under the stand, trodden on etc. Could be a faulty plug or even Mike/switch. Did the Mike ever crackle under use?
Have you another Mike and lead to try?
Sorry for the obvious questions but I have seen this happen before and it was a faulty lead...
Dec 18, 2008 | Yamaha Full-Size Keyboard
Logiteck Qickcam IM
ok.. the problem is on the other side or maybe your friend has a problem. tell your friend to close his mike near to his mouth and tell him to speak loud. or let your friends change his mike.. may be his mike has big problem.. thanks
Nov 28, 2007 | Logitech Quickcam IM 961361-0403 Webcam
Samson R21 Professional Microphone Logo
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
