Question about Dryers
I can't remove the heating element case.
How to remove heating element case to test if the element still works in whirlpool dryer (LEV5634AW0)
    President:
  • 1,136 Answers
HI, you need to rea=move the back panel to locate the element. It will be on the right side (looking at the back) in a housing. Check continuity on the element terminals. If it checks out ok, check all thermostats.
If I can assist you further, please let me know. I can also get you parts off my web site www.whirlpoolpartssurplus.com
Vic
Posted on May 20, 2009
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
I have a whirlpool dryer that won't heat. I removed the heating element and there were no breaks in the coils. I had the thermal cutoff tested and it was bad so I replaced it as well as the part
check the little 1"long x 1/4" wide white plastic fuse located on the dryer blower housing in the lower rear area,its held in place with 1 hex head screw,if its open dryer wont heat
Mar 11, 2012 | Whirlpool Dryers
My dryer whirlpool still blow cool air but do not heat please tell me what the problem henry le
Bad heating element or bad thermo fuse.
You will have to unplug the dryer and remove the back to access the heating element. The thermo fuse is located on the side of the heating element.
If you don't have a meter to test the element and thermo fuse or just don't know how simply remove them from the dryer and take them to your local appliance repair shop and they can test them for you.
Aug 03, 2011 | Whirlpool LER4600 Electric Dryer
I HAVE A RED4340SQ1 ELECTRIC DRYER WHERE IS THE HEATING ELEMENT LOCATED
The heating element is located at the rear of the dryer behind the rear access panel. Disconnect power then remove the screws attaching the rear access panel to the cabinet and remove the panel.
Your dryer seems not heating but it doesn't mean the heating element is busted. The problem is obviously in the heating circuit which is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on the link below for the detailed procedures.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 27, 2011 | Whirlpool LER4634J Electric Dryer
My dryer works - BUT it no longer is hot- I am sure it just the heating element and I am sure i can just replace that and it will work just fine again. WHirlpool Supreme. model LER7646EQO serial MG4337952...
IT DOES NOT HAVE TO BE THERMOSTAT PROBLEM. REMOVE BACK PANEL . THERMOTATE IS LOCATED AT THE BOTTOM OF THE HEATING PANEL . IF YOU ARE ABLE TO TEST RESISTANCE OF YOUR HITTING ELEMENT DO SO AND THAN TEST YOUR THERMOSTAT
Blowing air no heat open up dryer at the bottom on the heating element there is a burnt looks like a small relay that be the problem for no heat
This problem is usually a blown thermofuse. Whirlpool Dryers usually have two thermostats or thermofuses on the heating element case. Unplug Dryer, remove one wire from the thermostat, and with an electrical tester you need to test for continuity or resistance between the two terminals on each thermostat. If you have no continuity on either thermostat, order new ones, they usually will only sell as a set. If their is any burned wiring you have to cut out the burned section and put on new wiring terminals. 99% of the time this is caused by a venting restriction, so make sure your vent is clean and not smashed or restricted, otherwise this problem will reoccurr. If your thermostats have continuity, test for continuity across your heating element terminals. If this doesn't take care of it let me know and I will walk you through other tests
Dec 10, 2009 | Whirlpool Dryers
Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
Jul 30, 2009 | Whirlpool GEW9250 Electric Dryer
All the vents have been cleared inside and outside, however, the dryer doesn't heat up, cold air blows and clothes don't get dried. Whirlpool LGR8620PG0
Sounds like your heating elements are not working. I would check to see if you have power to them first. To do this, the back of the dryer needs to be removed. If you have power to the elements then check for continuity by removing the power leads and connect the test leads, one to each end. If there isn't any continuity then replace the elements.
May 17, 2009 | Whirlpool Dryers
Whirlpool dryer not getting hot mod# lev5634aw0
REMOVE THE FILTER AND THE 2 SCREWS UNDER THE FILTER LID THEN PRY THE TOP OPENED AT THE FRONT EDGES BETWEEN THE TOP AND FRONT PANEL THEN OPEN AND LOOK AT THE TOP OF YOUR HEAT ELEMENT HOUSING REMOVE THE 5/16 HEX HEAD AND PUSH IT TOWARDS THE REAR TO DISENGAGE IT FROM THE BACK OF THE REAR BULKHEAD THEN LIFT UP AND OUT IT COMES. cHECK YOUR THERMAL FUSE FOR CONTINUITY. GO TO www.repairclinic.com SCROLL ALL THE WAY DOWN AND CLICK THE RED 100 AND CHECK THESE PARTS AS WELL. 2986, 2821, AND 2893. THE ELEMENT IS 3367. 2986 NEEDS TO BE CHECKED FOR CONTINUITY.
Apr 14, 2009 | Dryers
Dryer all is working but not heating
Hi!
First of all please check the thermal fuse. If it is out okay (by-passed or tested with an ohmmeter), then check the heating element. This can be checked by removing one of the wires on the heater and testing it with an ohmmeter. Or,removing the element and visually inspecting it.
Thanks
Rylee
Mar 18, 2009 | Whirlpool Dryers
Dryers Logo
64 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
