Question about LG 42PC3DV 42 in. Plasma EDTV
What are the 42pc3dv-ud tv plasma specs - LG 42PC3DV 42 in. Plasma EDTV
  • 140 Answers
SOURCE: sound but no pic
The Lg you have actually has three boards that can cause the problem you are talking about. The control board, the y-board or the z-board. Usually most technicians will change the y-board and z board together since it is usually a combination of both that cause the problem. The control board by itself can cause the problem. The part #'s are as follows and these are straight from the LG plasma tv training manuals. 1- Control board 6871QCH053G, 2- Y board 6871QYH036D, and the Z-board is
6871QZH041B. The boards can be checked by looking at the voltages and signals but as I said some of those problems for no picture interrelate between boards. Hope this helped. Also with the back cover off those boards are clearly marked. The y board is a small board on the left and the Z board is on the right. The control board is of course in between them. They have tiny white stickers with the part # and assy# on them an also directly on the board itself. Always disconnect the power cord when looking at the inside by taking the back cover off.
Posted on Jan 15, 2009
  • 187 Answers
SOURCE: WON'T TURN ON.
Powerboard damaged, if you could not see the Led light on stanby mode it means you have no power at all.
Go ahead and replace your powerboard and your TV will be Ok
Posted on May 29, 2009
  • 3 Answers
SOURCE: LG 42pc3dv-ud
Yes you need to replace the board LG 6871QYH048B. The board has a short. Check the fuses and one of them should have no continuity
because it is open.
Replace that board and problem solved
Posted on Aug 03, 2009
  • 541 Answers
SOURCE: i have a lg 42pc3dv plasma tv. it made a loud pop
Looking at it from the back, the board on the left is the ysus. You should see a big red cable coming from the power supply board in the middle of the set going to the ysus. Near the red cable plug on the ysus should be a fuse. Most likely the fuse has blown. If it is you need a ysus PCB. Check out encompassparts.com. If you get a new board be sure to set all the controls on the new board to match the old board. If you don't you will have little sparkles all over the screen when it comes back on. I hope this helps. You may want to check all fuses on the power supply and the zsus which is on the right side of the set. I have seen both the ysus and zsus be bad together. Good luck and thanks.
Posted on Oct 24, 2009
  • 8457 Answers
SOURCE: my 42
ur backlight vidoe board is dead,must replaced.
Posted on Nov 23, 2009
Half of my tv screen isnt working
Plasma sets use (in most cases) two boards: each one drives half the screen.
Dec 03, 2012 | LG 42PC3DV 42 in. Plasma EDTV
My LG plasma 42pc3DV-UD just turns off while we're watching it and then turns itself back on again. It does this sporadically, any body got the fix on this?
The tv power supply board have dying parts call the capacitors.These capacitors are dying and have leaking gases.These dying capacitors are alway bulges up on it tops or puffing up on it tops.The power supply board the board that the board,where the power a/c cord plug into it.U have tools like a soldering iron,desoldering pump or desoldering braids,solders?U can do basic soldering?U have basic understanding of electronic?Replaced these dying and leaking gases capacitors,that are bulging up on it tops or puffing up on it tops.This sporadic turn off and on will stop.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Oct 20, 2010 | LG 42PC3DV 42 in. Plasma EDTV
LG Plasma screen just went nuts
It could be any of 4 boards, either take it in for service or get a new set.
Nov 16, 2017 | LG 42PC3D 42 in. Plasma Television
LG 42PC3DV-UD turns off/on by itself. Is this a common problem? What part needs to be replaced?
Power board have dead capacitors,like puff up or burst open,these capacitors must replaced.Know how to solders?Or replaced the whole power refurbish power board.Tries Shopjimmy.com,Ebay.com.
Jan 19, 2010 | LG 42PC3DC 42 in. Plasma HDTV
Backlight video ? lg plasma 42pc3d
It is only LCD's that use backlights, Plasma TV's use a different concept to produce the picture. I assume you have no picture, this does not mean the screen is faulty. It could be either a sustain board or control board fault.
Nov 27, 2009 | LG 42PC3DV 42 in. Plasma EDTV
WON'T TURN ON.
May 28, 2009 | LG 42PC3DV 42 in. Plasma EDTV
Sound but no pic
Jan 15, 2009 | LG 42PC3D 42 in. Plasma Television
I have sound but no pic
replace display board.
if unit is under warenty
LG is very good at sending out replacment boards.
LG 42pc3dv-ud
because it is open.
Aug 25, 2008 | LG 42PC3DV 42 in. Plasma EDTV
LG 42PC3DV 42 in. Plasma EDTV Logo
19 people viewed this question
Computer Repairing
Computer Repairing
