Sony projection tv model number kdf e52a10 tv comes on for a while then no picture and green light flashes about 50 times and comes back on
  • 38 Answers
You have a bad projection lamp assy. Do not buy a cheap one..
Posted on Jan 01, 2014
SOURCE: Problem with Sony Wega 50 in kdf-50we655 light blinks 55 times
I fixed my problem by removing the lamp and vacuuming the hell out of the hole where the lamp lives and also getting all of the dust out of the rear ventilation grids with my vacuum. I put the old lamp back in and what do you know the TV has worked perfectly ever since. My lamp was over a year old and did not show any signs of hazing on the lens that you might see on a lamp that has a ton of hours on it. I just thought I would try to put it back in before I spent a couple of hundred bucks on a new lamp.
TA DA problem fixed.
Posted on May 05, 2009
SOURCE: Sony 55" rear projection tv
TIGHTEN THE BULB --AFTER YOY CLEAN THE DUST OFF THE BULB VENTS ON THE BULB ITSELF. PROBLEM SOLVED. EASY--CHEAP. Hey it worked for me. My picture was turning off blinking 29 times for picture 37 times for audio. This was the first issue with my KDF-55WF655 since I unwrapped it almost 5 years ago......... ITS STILL ON!!! I hope this helps someone.
Posted on Sep 12, 2009
SOURCE: Sony Wega kdf-55wf655 rear projection set keeps turning on and off
Had exact same problem with my KDF-55WF655 and put in new projection bulb assembly and no more cut out plus picture is much brighter even on standard. Next time will just by bulb and install in old assembly as it looks straight forward now that I know what assembly looks like. Got about 7200 hrs. out of OE projection lamp and almost 4 years service.
Posted on Oct 01, 2009
welcomejee
  • 10594 Answers
SOURCE: Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Posted on Oct 21, 2009
  • 380 Answers
SOURCE: I have Sony tv model KDF-42WE655 which stopped
Its not the green light that you should be count but the red. How many times is it blinking? Here is a quick update of the errors that are most common.
3x - Lamp switch not engaged
4x - Fans issue
5x - Lamp
6x - Thermal fuse
Posted on Dec 15, 2009
I have KDF -4=50 E2000 LCD that the picture turn off and the green light flushes sometimes the picture will come back and sometimes it does not so i just turn the TV off
bzohar,
The number of flashes could be helpful to diagnose your problem. I have tips for all the Sony problems. Just do a search for "Sony TV Error Code" and the number of flashes written out and you should find what you need.
Thanks for using FixYa and for the great rating.
hardrocko
May 14, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
I need help. My Sony 50 inch tv is a 2006. The warranty ran out in June 2010. I heard a pop and then it shut off. Now the green light flashes 25 times and turns to the red lamp light. I can't reference...
Pop sound was broken lamp in tv, replace lamp to solve tv issue.
Please recheck model number as KDF-50EA10 seems invalid/ incorrect model number and nearest match is KDF-E50A10
If model number is KDF-E50A10 then required lamp part number is as follows...
F93087500 ... LAMP BLOCK ASSY XL-2400
and available with Sony Accessories Store for $200
Let me know if you have addition question or tv model number is other than above said (KDF-E50A10).
Thanks.
Mar 10, 2011 | Sony Televison & Video
Hi There. On my Sony 50" rear projection TV, i
You need to Replace the Lamp.
Encompass Parts Distribution 1-800-638-3328
Look on Ebay for Lamp onced you know the Part number.
Jan 22, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a sony tv model kdf-50e2000,and it has a problem with the picture going blank,the only light that on or flashes is the green (POWER) light. when turning the set on the green light blinks as it...
You tv used lamp XL-2400 or also known as F93087500. It is very common for this bulb to fail and have the exact symptom you are experiencing. I cant count how many times I have seen it.. Replace the lamp with either the exact Sony or an OEM and you will be back in business..
Good Luck!!
Dec 28, 2010 | Sony KDF-50E2000 50" HDTV
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Symptom shows that TV needs Lamp replacement.
Sony TV Lamp is available in Part Store and lamp replacement procedure is written in user manual of TV.
Mar 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
