Question about Dryers
Dryer will not turn off
Sears Kenmore model 80 series. Drys clothes, but timer doe not move. Keeps on drying clothes to the point of getting hot. Must open door to turn off. Tried other settings same problem .
  • 10,865 Answers
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Posted on May 20, 2009
  • Joe Hogan May 20, 2009
Kenmore 400 series gas dryer doesnt dry clothes
Replace timer, if you are sure that it is not working.
Do an internet search for kenmore driver parts and get dozens of hits.
Aug 03, 2014 | Kenmore Dryers
After dryer shuts off, timer continues to run. Kenmore model #110.86181810, part # I think is 692032 and sears says it is no longer in stock. Anyone still have one?
I assume you're talking about the buzzer. Many high end dryers do that until you remove the clothes. heated clothes can set wrinkles if kept in the same position for a long time. it's a feature, not a problem, unless it keeps buzzing after you remove the dried clothes!
Apr 15, 2013 | Kenmore Dryers
I have a Kenmore 110 60812990 80 series dryer
bad heater box fuse,get the model number from inside the dryer door,and go to your local appliance parts store and give them the number and they will get you a thermal fuse kit,remove the back of dryer and you will see the heater box on the right side
Feb 02, 2010 | Kenmore 64742 Electric Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
GE Dryer timer doesn't work
Replace the timer . If model number given , could give the part number .
Aug 09, 2009 | Kenmore 800 6983 Electric Dryer
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Sears Kenmore 80 Series Electric Dryer - starts, kicks off in 5 min
sound like a motor problem it does not have a resetable limit if it was over heating then it would blow the limit and it would not heat, or the blower limit if it sences overheating would not allow the machine to run at all
get ready for a new motor, or a new dryer
200 plus to replace the motor
May 08, 2008 | Dryers
Timer Does not Move
FIRST CHECK YOUR VENT IS CLEANED OUT THEN SEE IF TIMER MOVES WHEN PUT TO A TIMED CYCLE. IF SO MEANS VENT CLOGGED UP. IF STILL NOT MOVING MEANS TIMER CONTROL BAD. COST ABOUT 80-100 FOR PART. YOU COULD DO YOURSELF IF SOMEWHAT HANDI.
COULD BE ORDERED FROM SEARS PARTS DIRECT BY YOU.
OTHER WISE CALL SERVICER AND MAY COST 200.00 TO REPAIR. HOPE THIS HELPS
Feb 22, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
414 people viewed this question
Top Dryers Experts
