Question about Dryers
Nothing happens when you press start
Kenmore Elite Electric dryer model 110.60956990 nothing happens when you press start
  • 10,865 Answers
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Posted on May 20, 2009
  • Joe Hogan May 20, 2009
    Door switch
    Thermal fuse
    Wiring
    Door switch
    Thermal fuse
    Wiring
Kenmore Elite quiet pak 4 will not start. Close the door and hit the power button and nothing happens. Makes the beeping sound but nothing else.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 02, 2011 | Kenmore Elite HE4 Electric Dryer
Hi,I have a Kenmore Elite HE3 electric dryer which is only about 3 months and the problem is that when I press the power button, nothing happens, even though the dryer IS connected to electricity beacause...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Oct 20, 2010 | Kenmore 82822 Electric Dryer
Kenmore Elite HE4 gas dryer won't start
I had the same symptoms and it was a bad motor relay. This happened twice within 5 years.
Apr 19, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer not starting
check drum belt it has a switch that will not let dryer start if belt has broke or came off, if belt is ok check thermal fuse
Sep 28, 2009 | Kenmore Elite HE4 Electric Dryer
Power is on but when i go to start it will not
my dryer is turning on but it does not work. what should I do?
Sep 23, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
185 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
