How to work a slimline creda nitestore heater
It has 2 dails under a flap on top of heater which say output and input,on the wall next to heater is the on switch and a panel which consists of time, minute,hour day and main how do i use this?
    Problem Solver:
  • 5 Answers
I have one of these heaters as well. The input/output dials are thermostats.
The higher the input dial is set, the more power the heater draws during its charge cycle (ie the "on" period that is set on your time panel). Which means a higher daily ration of heat, and a bigger power bill.
The higher the output dial is set, the more quickly the heater lets the stored heat out. So the highest setting would give you most of your daily ration of heat during the "on" period but less heat for the "off period... while the lowest setting would give you a relatively constant heat output throughout the day.
Posted on Jul 04, 2009
    President:
  • 3,433 Answers
The two dials are either fan speed or thermostats.
the clock is the the time periods in either the input or exhaust phases will active or function in. Turn on the wall switch and set your input dial to mid range, then set the time to current time. A motor/fan should kick on and possibly ignite burner for heating and the output will exhaust the the room air in its set periods. Sorta like flow through ventilation so the house doesn't get stuffy on warm days. good luck and monitor closely if it has not been fired up in awhile
Posted on May 21, 2009
My 2004 bantam pickup with the 1600 rocam engine has got a problem with the heater staying on even on cold setting.I already replaced the heater valve.Assistance would be appreciated.The heater cant be...
Check your hot and cool trim door or flap under the dashboard, the stepper motor that controls it sometimes either gets jammed or just wears out and stops working or if you won't need the heater you can put a valve in the input and output hoses to the heater core and eliminate the hot air and have it accessible whenever you need it?
If you need further help, reach me via phone at https://www.6ya.com/expert/james_8f14c50d9c6cdea8
Mar 07, 2015 | Ford Bantam Cars & Trucks
I have 2 tsr12aw creda storage heaters, one gets hotter and stays warmer for longer, the imput switch clicks much quicker on the cooler one,is there an internal adjustment to increase the time it asks
you will find that it is like that on these models, the temp sensor is just a bit of metal and it heats up and then opens the circuit then when it cools down close the circuit and starts to heat up again. over time it will turn off quicker as the bit of metal or copper depending what was fitted will cut of quicker.
Jan 25, 2015 | Creda Washing Machines
Working instructions for creada electric wall heaters modle 79351S
sounds like the electric economy 7 heaters too me, i had them and hated em.
basically the heaters work between 1am-7am or similiar.
the best way is to think of it as a battery, it needs to be charged and the output is whatever your using the power on.
the higher the number on the input the more heat is stored into the heater. the higher the number on the output the more heat that is released.
i always put mine on 5 to store the most heat and left it on about 3 so it would always release and charge.
hope that helps
Oct 06, 2012 | Heating & Cooling
I need an instruction manual for a comfy air wall heater
how do you ste up the comryfair slimline panel wall heater
Jan 08, 2012 | Heating & Cooling
I need the input voltage for ac adapter for my GE 98903 2.1 Pro Speaker System
The AC adapter input voltage is 120 Volts AC as it plugs into a wall outlet. I suspect you want to know the output voltage of the transformer. If you have the old transformer the output voltage is listed on the transformer top. May be hard to read but it is there. This system is also sold under then brand name Jasco. The Input voltage of the system should also be printed next to the power connection or on the speaker itself.
Nov 11, 2009 | Cars & Trucks
Slimline storage heaters with no switch to turn on/off - how do you turn them on? have taken off the front panel but can see no switch/override - the electric cable comes straight from the wall into the...
The principle of electric storage heaters is that they take in electricity at night through a central time switch (normally owned by the electricity supply company and usually not controllable by the user).
There should then be a main switch/ fuse box to control the heater circiuts, check for such a box and that it is switched on (This would normally be sited near the electricity meter).
There should be an isolator switch next to each heater but from what you say this is not the case.
There should be some controls on each storage heater marked INPUT with a dial from 1 to 6 or similar then another marked OUTPUT or BOOST.
When you have ascertained the fuse box is on and the heater controls are set to maximum you then have to wait overnight for the heaters to warm up.
Oct 09, 2008 | Heating & Cooling
Creda economy 7 heaters not working!
Whe you turn the heaters on again after they have been off you have to keep them on maximum for 48 hours (both input and output dials) to get the bricks warmed up for regular working
Oct 02, 2008 | Heating & Cooling
I have 26in polariod lcd im using as computer moniter
There should be an audio input next to or near the VGA connector on the TV. Usually red & white RCA or 3.5mm socket.
Connect this input to the audio or speaker output on the PC.
Feb 29, 2008 | Philips 23PF5320 23 in. HD-Ready LCD...
Operating instructions for creda storage heaters
how do you regulate the heat from creda storage heaters model No 79163 /79151 /79141 they have 2 dials on each heater,I was told the dial on the right turn up to 6 its highest point & the left dial to its lowest number 1 .But i got up this morning & its like a sauna
Jan 03, 2008 | Heating & Cooling
Heating & Cooling Logo
721 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
