Question about Jensen VM9725BT Navigation receiver
Parking brake bypass jensen vm9725bt
I've been trying what you guys suggested on my jensen vm9725bt go into setup go to language And enter 543210 but it's not working
SOURCE: bypass brake for a jensen vm9311
Don't pay for it....Just read it:
The code is a permanent way of disabling the brake override on the jensen units.
There are two ways of doing this:
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing.
I tried to make this as clear as possible. If you have questions, private message me or post here.
This code DOES work.
Best of Luck!
By the way, this is for informational purposes only and I will not be responsible for anything bad/stupid/ignorant you do with your Jensen unit.
(Sorry Jack Sap, but this stuff should be free...)
Posted on Dec 14, 2007
j_del
  • 1586 Answers
SOURCE: bypass the parking brake on the vm9022
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Jul 23, 2008
SOURCE: jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Posted on Sep 11, 2008
SOURCE: bypass the parking brake for vm9412 jensen
Hit Setup On Remote.
Select Language.
Get Remote And Hit 5,4,3,2,1,0.
Listen For Beeps. Touch “Hammer/Screwdriver” Logo.
Select Brake Override
Switch To Brake Override “ON”
Now Hit Setup On Remote.
this works thank you for posting this.
derek
Posted on Nov 16, 2008
jpk528
  • 95 Answers
SOURCE: how to bypass a park switch for a jensen model VM9212N
go to settings menu, and highlight language button. and on your remote enter 543210 in sequence. then another menu will pop up. Go to the settings menu and then the second one down will be the brake option. then click which setting you want
Posted on Feb 16, 2009
How do i by pass parking brake wire for indash dvd jensen vm9312 i'm puting it in old car no p.b.
Hi jason
To answer your question;
You do not need to connect that wire but you need to bypass the parking brake function in the menu.
Here`s the parking brake bypass procedure:
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number
entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
Hope this help Cheers
Apr 20, 2010 | Jensen's VM9312 Car DVD Player
Wrong region on Vm9512. any know how to fix this
1; insert a DVD
2;in your remote control push setup
3;select "language"
4;in your remote control press 543210
5:A secret menu will apear
6; Change the region code, bypass the parking brake, etc etc.
7: Adios!
Nov 15, 2009 | Jensen Car Audio & Video
When I try to play a movie, I only see the warning sign on the screen. I can hear the movie playing, but the warning will not go away. This is even when the vehicle is in park. Any ideas what may be wrong?
Bypass Code
1. Go into Am/Fm mode
2. Hit "setup" on the remote control
3. Enter 543210 on the remote, listening for the beep for each number entered
4. A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen
5. Select Brake bypass to "ON" and hit the "X" near the bottom of the screen
Aug 18, 2009 | Jensen's VM9312 Car DVD Player
Need to bypass parking brake feature on Jensen VM9512HD
3: Enter 543210 on the remote, listening for the beep for each number entered
Apr 19, 2009 | Jensen VM9510 Car DVD Player
How to bypass a park switch for a jensen model VM9212N
Feb 15, 2009 | Jensen Car Audio & Video
go to language with the control remote, 543210 the rest is your.
Nov 13, 2008 | Jensen VM9510 Car DVD Player
Pioneer 4000 making it work without brake on
Press setup on remote control.
After enterning the setup screen:
1) Select the "Language" tab
2) Once in the language selection menu, press: 543210.
3) A menu "secret" screen will appear, select the "Hammer and Screwdriver" button
4) Select "Brake Override"
5) Select "On"
6) Press "Setup" on the remote again to exit screen.
Oct 17, 2008 | Jensen VM9510 Car DVD Player
Jensen VM 9022
Access the setup menu and while there put in security code on remote, 012345, or 543210. Once entered you will gain access to the secret menu, scroll down to the braking option and select the brake off option. Enjoy....
Nov 30, 2007 | Jensen Car Audio & Video
Bypass brake for a jensen vm9311
the wire is pink and say parking on the wire.
Nov 24, 2007 | Panasonic CQ-C3300U CD Player
Jensen VM9412 Video BYpass
The solution that was givin for vm9412.
going to SET UP
Then Language.
Then on your remote push 543210.
Press the Hammer & Screwdriver symbol.
Click on praking brake overide and turn it on.
Then hit the X at the bottom of the screen.
And say good bye to the pink wire bs & ground.
This solution was awsome it only took one try very easy!
I Give total props to FixYa.
TTTHHHAANNKK UUUUUUUUUUU !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 30, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9725BT Navigation receiver Logo
19 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
