Question about Xerox Hp 4300/4345 Series With Chip
Error 009-936 xerox 4300
How to clear code
What does error code 99,013.00:49569 mean xerox 8570 color cube?
Process Drive Fault"
Do you have another kit you can take from another printer.
Switch the printer off.
Swap out the kit with the one from the other printer.
Turn it back on. If it clears the fault when the printer is ready put back the new kit
Aug 14, 2015 | Xerox Office Equipment & Supplies
Samsung Printer SCX 4300 message "Open Heat Error"
on printer, in menu there is clear setting, find it and do ""clear setting" , "all setting", then will be fine
May 29, 2011 | Samsung SCX-4300 Monochrome Laser...
SAMSUNG SCX-4300 PRINTER GIVE ERROR OF XEROX
Please go through the given mentioned link.
http://www.samsung.com/us/consumer/office/printers-multifunction/black-and-white-multifunction-printers/SCX-4300/XAA/index.idx?pagetype=prd_detail&tab=support
Sep 21, 2009 | Samsung SCX-4300 Monochrome Laser...
Xerox XC 1045 has a flashing H 4 error.
elem_1_spacer.gif Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Jul 01, 2009 | Xerox Office Equipment & Supplies
Xerox XC1875 U4 Error on Startup
Give this a try. it may clear you code. Use program 14
To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: ‘Clear’, ‘Exposure Mode’, ‘Clear’, ‘Exposure Mode’ (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the ‘Print’ button, then the second part of the code followed by the ‘Print’ button again.
To exit diagnostics: Press ‘Clear’ repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select ‘14’ followed by ‘Print’… exit diagnostics.
**To Clear a U2 code:(16) Enter diagnostics, select ‘16’ followed by ‘Print’… exit diagnostics.
May 04, 2009 | Xerox Office Equipment & Supplies
Xerox Phaser 8500N Printer Error 09,037.45:9085
Hi Signrite: This should help out. It looks like you are having a problem with yellow.If you are using a third party ink (non Xerox) then you may be having a printhead.
9,035.4x through 9, 038:
Fault codes associated when ink count flags are stuck
after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5
for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to
Step 2.
Advise
customer. Run
clearISCfault
test to clear the
error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to
Step 3.
Remove any
blockage and/
or replace the
ink stick.Run
clearISCfault
test to clear the
error.
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace
the
printhead.
Replace the ink
loader
assembly. Run
clearISCfault
test to clear the
error
Nov 24, 2008 | Xerox Phaser 8500N Printer
Xerox Hp 4300/4345 Series With Chip Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
