How to know if the washer drum is dislocated?
In the last spinning circle ,my front -loading samsung washer made a large noise ...i think the washer drum is dislocated but not sure..how to know tht the srum is dislocated?
SOURCE: maytag spinning loud noise
bearings are bad need to replace
Posted on Mar 14, 2007
  • 25 Answers
SOURCE: load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Posted on Feb 16, 2008
  • 184 Answers
SOURCE: Front Loading Washer LOUD NOISE
IF IT ROARS LIKE A JET PLANE TAKING OFF, THE SPIN BEARING IS FAILING. PROBABLY, THE REAR SEAL HAS FAILED ALLOWING WATER TO GET INTO THE BEARING.
THE BEARING HAS LOST ITS LUBRICATION SO IT IS GETTING DRY. IT WILL CONTINUE TO GET LOUDER AND LOUDER THE LONGER REPAIRS ARE PUT OFF.
THE ENTIRE BACK HALF OF THE OUTER TUB WILL HAVE TO BE REPLACED. THE BEARING IS PART OF THAT ASSEMBLY. CAN BE A COSTLY REPAIR.
Posted on Apr 05, 2008
SOURCE: Squeak in Kenmore HE 2plus front load washer when drum spins
We opened the top of the washing machine and there are some suspension springs.
All it needed was some lubrification. Prior to putting the top back on we put a load in
and watched it and there was no more noise.
Posted on Jan 21, 2009
SOURCE: front loading washer won't spin
my amana washer wont spin and does not drain
Posted on Sep 12, 2009
Samsung front load washer, jerks and makes noise when it first starts spinningthen it smooths out, and works fine.
on many machines that is normal, the shaking continues until the load is distributed relative evenly around the spinning drum. It is also possible it is the main bearing but I am not sure. The noise I am talking about would have been there since new. These links may help. Washer has noise during spin cycle Whirlpool Maytag Sears GHW9100LW1 Washer is Making Loud Noise
How To Fix Washing Machine Making Noise During The Spin Cycle
http://www.partselect.com/Repair/Washer/Noisy/
May 28, 2016 | Samsung Platinum Front Load Washer -...
When i load my washer drum in washer will not agitate or spin off tract.
if noisy like plane taking off bearings gone check play on drum by pushing drum back and forth look for large gap between drum and door seal and listen for scratching noise when turning also some machines wont spin if the load is uneven
Dec 12, 2014 | Samsung WF330ANW 4.3 Cu. Ft. Front Load...
My fridgedaire front loader washing machine has been making weird noises when it spins or washes, making sounds like there is loose metal inside somewhere rubbing and clanking around. As of last night...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Frigidaire Washing Machines
On my spin cycle there is a large banging noise. I thought it was due to the fact that the load was too large or collected in one area of the drum but after doing a much smaller load the problem persists....
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
heatman101
Dec 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Machine making a loud noise in spin cycle. We
Inspect the outer drum to see if one of your springs has popped off. You can also inspect the lower drum area to see if your vibration dampener has worn out or broken free. Also you may need to check your rear bearing just between the large pulley and the drom to make sure is hasn't separated from it's mount.
Mar 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Excessive noise/vibration
Vibration problem occurs on dryer/washers because of bad dampers generally. When drum is loaded, the load is distributed randomly, so its create vibration when drum spin in certain revolution. The dampers are supposed to take this vibration and minimize them.
There are more possibilities like drum dislocation or bended drum etc.
Jun 28, 2009 | Kenmore 73932 Gas Dryer
An object is caught behind the drum of our Kenmore
remove the back and check if large pulley is wobbely on shaft. common problem. replace pulley.
Jun 12, 2009 | Kenmore HE2 Plus Front Load Washer
Squeaking noises are hard to find unless u open it and pin point where its coming from.. you can open the back cover if you are comfortable doing so.. let it run to see if you can heard... sometimes the bolt holding the pulley to the drum is loose and need to be tighten. Other possible is the shocks came loose or when install new.. the shipping materials were not remove..
Dec 13, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer
My Kenmore front-load washer starts to make the huge noise. The noise happens during the wash cycle, but is mild. During the spin cycle, the noise becomes really loud. It looks like the drum is getting loose and hitting other part of the machine.
I checked the drum, and I can sway the drum easily with my hand. So it looks some supporting structure is broken. I don't know if it is easy to open the washer to check what has been broken.
May 20, 2008 | Kenmore 44072 Front Load Washer
Washing Machines Logo
189 people viewed this question
Top Washing Machines Experts
