Question about Garden
Craftsman 25cc edger has trouble starting. once started it will run for 5 - 10 minutes and then shut shut off. Will not start again until it cools down. Changed the spark plug , but it has the same pr
Craftsman 25cc edger has trouble starting. once started it will run for 5 - 10 minutes and then shut shut off. Will not start again until it cools down. Changed the spark plug , but it has the same problem.
  • 10,865 Answers
Dump the fuel in the tank, get new gas and new oil and start over. Get a carbeurator cleaner additive for the gas as your carb. is dirty resulting in the sporatic operation.
A spray carb. cleaner that you squirt into the air intake by removing the air filter will also work for you. In fact, when you are getting the carb. cleaner get a new air cleaner and a new spark plug. get back and let me know how u make out.
Posted on May 20, 2009
Why wont my craftsman 25cc start
99% of the time its a carb or fuel problem. Always run premium fuel and store the machine in a cool place less than 100 F
Might can put a drop or two of fuel down the carb and revive.
Jul 18, 2014 | Craftsman 25cc Gas Line Trimmer
My Craftsman Weedwacker, (Model # 358.791010 ) does not start. originally it took about 5 - 10 minutes to start and once it was running, I'd hit the switch from "START" to "RUN" and...
Sounds like a carb problem. You may need to rebuild it. Check to see if your fuel lines inside the tank have rotted. Common problem on Craftsman.
Nov 01, 2010 | Craftsman 25cc Gas Line Trimmer
Wont start when hot
might be coil ? you can test it with and ohm meter should be within specs on both primary and secondary sides ? but try this first to see if its a vapor lock or fuel hose issue ? when it wont start get you a can of starting fluid and spray the air filter see if it restarts then ? this will tell you its fuel not spark ? then you can recheck hoses and primerbulb ? hope this helps
Aug 27, 2009 | Craftsman 25cc Gas Line Trimmer
My Cratfsman 25cc 17in trimmer heats up after a
the rings are whorn out replace them.take compresstion test to see if compresstion is bad bet it is.let me know
Jul 28, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32 cc
Your gas cap is probably clogged with dirt. The next time you run the trimmer and it begins to stall out, loosen the gas cap, it should start to run good again. Gas cap must be able to breathe in order for gas to flow properly.
Jim
Jun 04, 2009 | Craftsman 25cc Gas Line Trimmer
Runs fine when first start. Dosen't want to start after warmed up.
Have you checked or Changed the Fuel Filter.
It will be in the tank hooked to the fuel line. I suggest a small pair of Hemostats for this job.
May 25, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman lawn will not start
your carbeurator is crudded up. Get some carb. cleaner spray and remove the air filter to shoot a couple of squirts into the air intake. repeat until it starts and runs smoothly.
May 20, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
395 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
