Question about Maytag MBF2256H Bottom Freezer Refrigerator
Not cold enough
Freezer is cold  has some frost on top of drawer when opened  refrigerator section not as cold as should be coils are clean underneath
  • 1 more comment
  • Don Malbrough
    Don Malbrough Oct 19, 2007
    i did some research on my own and used control panel diagnostics  to force defrost cycle seems ok now but now question is  was it a fluke? or will it happen again. time will tell.
  • muniman Dec 08, 2007
    How do you force the defrost cycle to turn on? I have the same proble.
  • sparky7979 Feb 09, 2008
    i have similar problem. freezer is colder than usual but refrigerator is not working at all. any ideas?
    Problem Solver:
  • 8 Answers
Posible defrost not happening, air is not sirculating down to bottom compartment due to frost buil up
Posted on Oct 19, 2007
Frigidaire refrigerator/freezer side by side--compressor keeps running
Most problems with side by sides frosting up is due to failure of the defrost heater in the bottom of the freezer section behind the panel inside.
Jun 16, 2012 | Refrigerators
There is a drip coming into the refrigerator from the ceiling , but the freezer is not frosted
I suggest that you remove the bottom layer of the freezer - you'll see its just a piece of plastic to allow cold air to circulate underneath. There is a metal tray in the back of the freezer there that has a drain in it - I'll bet its frozen solid and the condensation from the defrost cycles are dripping down into the fridge part.
Nov 16, 2011 | Haier HTE18WAA Top Freezer Refrigerator
Bottom section does not cool,top freezser partial cooling
A refrigerator not cold enough is a hassle, because you are at risk of spoiling the foods you store in there. Most often, this problem is caused by something easy to fix.
1. Faulty Door Gaskets
The door gaskets in a refrigerator ensure a sealed closure every time you shut the door. Torn or loose gaskets on the door of the refrigerator can result in a leak in the cold air. As a result, the refrigerator is warmer. Repetitive and frequent opening and closing of the refrigerator is also a possible cause, because the warm air from outside replaces the cold air in the refrigerator every time you open it.
2. Dirty Condenser Coils
Dirty condenser coils can result in improper functioning of the refrigerator. These coils are located on the back or the underside of refrigerators. If you find this to be the cause of the problem, unplug the refrigerator before you attempt any cleaning.
3. Frost-free Feature not Working
If the frost-free feature fails, it causes a buildup of frost around the evaporator coils in the freezer. This causes a malfunctioning of the evaporator fan that blows cold air around. The fan can also be damaged if it hits the frost.
4. Faulty or Incorrect Temperature Control
A faulty thermostat can lead to a refrigerator that is not maintaining the desired coldness. Check for this problem and also ensure that the temperature is set to the correct level. Normally, refrigerators are set to a temperature of about 0°C, whereas the freezer sections are around -17°C.
5. Inadequate Air Flow inside Refrigerator
A refrigerator that is loaded with too many food items can fail to maintain an adequate level of coolness across all the items kept in it. The surface items tend to be colder, and the items underneath do not become as cold. A refrigerator that has very few items in it can also fail to function efficiently. Try to ensure that your refrigerator has enough food in it at all times, but is not so loaded that the air flow gets constricted.
6. Vents between Freezer and Refrigerator Clogged
The vents between the freezer and refrigerating section blow cold air from the freezer across to the refrigerator. If these vents are clogged with ice, the air is blocked and the refrigerator does not cool down. If this is the case, you can unplug the refrigerator, wait for the ice to melt and then connect it back to the power supply.
7. Faulty Door Switch
The door switch is found on the bottom of refrigerator doors. It turns off the light in the refrigerator and resumes cooling action when you close the door. If this switch is not functioning properly, the refrigerator will not be cold and it will also be affected by the heat of the interior light.
8. Refrigerant Leak
A refrigerant leak is very unlikely. This problem can cause malfunctioning of your refrigerator. If you suspect this to be the cause, contact a service technician.
Good luck in solving the problem....
Jun 19, 2011 | Hotpoint Refrigerators
The upper portion of the freezer turns off, causing the ice to melt. And the cooler side bottom drawer turns into a freezer. I can't figure out what's going on.
You have a frost blocked evaporator. Translation: The cooling coils, located behind the back wall inside the freezer section, have plugged up with frost (usually caused by a burnt out defrost heater, located at the bottom of these coils) which prevents the cold air from circulating inside the freezer, and into the top of the fresh foods section. At the same time, this blocked air flow allows very cold air at the bottom of the freezer section to migrate back into the bottom of the fresh foods section, and thus freeze item in the bottom bins of the refrigerator. Unload the freezer, take the shelves out and remove the back panel. Melt the frost with a hair blower, and change out the heater at the bottom.
Jul 08, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Side by side thermostat set low seems like it runs a lot more than it use to freezer and fridge are boyh cold
Check your coils underneath the fridge to be sure they are clean.
Check your condensor fan (bottom rear of fridge) to make sure it is blowing air freely.
Make sure you have a good supply in the freezer, All of your cooling comes from the freezer section and a mostly empty freezer will result in more frequent running as ther is not enough stock to help maintian and hold freezing temperatures.
Check your freezer section to make sure there is no visible frost on the back wall of the freezer (down low on the panels behind and slightly above the lowest freezer basket. If you see frost starting to develop it means you have a defrost issue starting and will want to adress it rather quickly. Either a problem with the defrost control board (inside fridge/freezer control compartment) or the defrost thermostat (behind the freezer back panel on top of the evaporator coils).
Hopefully this helps!
Jun 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Cold water collects in the bottom space below the drawers
this is just condensation as the fridge is not frost free.try placing a sheet of tissue in the bottom of the salad drawer and one under it, take out about once a week to keep dry
Mar 08, 2010 | Frigidaire FRT21H8 Top Freezer...
Freezer works, fridge does not. It's not cold. We've cleaned the coils underneath & checked under the crisper luck
Last year I had a similar problem, but with a different unit. Mine was a side-by-side. The freezer was cold, but the refrigerator was not. Since there's typically only one cold source in these systems, that told me that the problem had to be air flow from the freezer compartment to the refrigerator. In my case it turned out to be the "diffuser". This is a small "breezeway" between freezer and refrigerator that opens and closes as cold is needed by the refrigerator. Anyway, I replaced that and everything got better.
Jan 13, 2010 | Maytag MFI2568AE Side by Side French Door...
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Both the freezer & refregirated section are not getting cold enough.
look on the backside of the freezer for frost. You might have a bad defrost more
May 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Maytag MBF2256H Bottom Freezer Refrigerator Logo
103 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
